pfoyle Posted April 7, 2013 Share Posted April 7, 2013 More pics Link to comment Share on other sites More sharing options...
pfoyle Posted April 7, 2013 Share Posted April 7, 2013 Even moar pics! Link to comment Share on other sites More sharing options...
Nrw Posted April 7, 2013 Share Posted April 7, 2013 Finishing up editing the pics. Will start dumping them. For now.. http://farm9.staticflickr.com/8254/8627547469_ceca9b41e3_c.jpg Link to comment Share on other sites More sharing options...
V8Bait Posted April 7, 2013 Share Posted April 7, 2013 V8Bait's beast! Glad I didn't get closer when filming this video... might have lost my eyebrows! Awesome!! Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted April 7, 2013 I Donated Too Share Posted April 7, 2013 Tell me more about the spearco with the big turbo the I've read that they're too big for vf52/16g Link to comment Share on other sites More sharing options...
BigBlack-V Posted April 7, 2013 Share Posted April 7, 2013 I actually saw that 5th gen in CT last week on I84 it was very stealth looking I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
pfoyle Posted April 7, 2013 Share Posted April 7, 2013 I actually saw that 5th gen in CT last week on I84 it was very stealth looking The silver one? Belongs to Minnucims... Great looking car, I want his offset! Link to comment Share on other sites More sharing options...
Nrw Posted April 7, 2013 Share Posted April 7, 2013 Tell me more about the spearco with the big turbo the I've read that they're too big for vf52/16g It's basically a top mounted fmic Link to comment Share on other sites More sharing options...
robitrice Posted April 7, 2013 Share Posted April 7, 2013 its a monster, it actually looks smaller when its mounted to the car....I saw it before it was mounted and it just looked like it would not fit, but once on the car it looked really good. Link to comment Share on other sites More sharing options...
Dujo Posted April 7, 2013 Share Posted April 7, 2013 ^ The hoodscoop needs to be bigger. I've got a sledge hammer and a crowbar if you want help with that Sig. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted April 7, 2013 I Donated Too Share Posted April 7, 2013 Hood scoop is plenty big enough. No hammers dujo!!!! The tmic is too big for smaller sized turbos - the 16g definitely fails to operate well on such a big core as was discovered when fahr_side dyno'd and lost power and they couldn't bring it back until the smaller tmic was replaced. It happens. This is definitely for bigger flowing turbos and as nrw said it really is an fmic sized core (much deeper actually) on the top. Just a bit bigger than the process west. I was able to get all the air from the hood scoop into the spearco as it sits up at an angle almost right into the airflow - looking through the hood you see it facing right at the opening (once I opened up the entire width of the opening by removing all the inner material. Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted April 7, 2013 I Donated Too Share Posted April 7, 2013 Hood scoop is plenty big enough. No hammers dujo!!!! The tmic is too big for smaller sized turbos - the 16g definitely fails to operate well on such a big core as was discovered when fahr_side dyno'd and lost power and they couldn't bring it back until the smaller tmic was replaced. It happens. This is definitely for bigger flowing turbos and as nrw said it really is an fmic sized core (much deeper actually) on the top. Just a bit bigger than the process west. I was able to get all the air from the hood scoop into the spearco as it sits up at an angle almost right into the airflow - looking through the hood you see it facing right at the opening (once I opened up the entire width of the opening by removing all the inner material. Does anyone have any info on a minimum required size to use efficiently? Hta68? 20g? Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted April 7, 2013 I Donated Too Share Posted April 7, 2013 I am not sure how to answer that exactly as you ask but I am sure others can. Bren may even chime in as he has a wealth of experience of course. So go look at my dyno plots earlier in this thread. The first was with stock TMIC and then the second was on the Perrin TMIC, the only change. It was an efficient and beneficial change and allowed Bren to up the boost by 1psi for a near 40whp gain and lots more torque... My HTA68 was fine on the Perrin TMIC for 335whp/375wtq but when I asked Bren about turning up the boost more than 20/21psi as I would supplement with Meth he said no more for the Perrin/becomes a toaster was his choice of words* - Meth or no Meth - so you can figure where all the crazy started with the Spearco for me. The HTA68 can make plenty of boost but it's getting to the end anyway as it's known to be a 'good' 350whp Turbo and I had it at 335whp - I am sure Bren has got more whp on 68's under different conditions but I was advised I was heading towards FMIC territory - the Spearco is because I don't like doing what I am told! So the other way to answer this is, there's not a lot of choice for TMIC's and the Spearco is as good as it's going to get - the Process West is slightly smaller - neither are without their problems - then the AVO/Perrin - and all the knock off's - so what's your pleasure is more the question? *and you know what... he was right! The Spearco gets RED hot at full boost on the hot side! I can't imagine what the Perrin would have done, oh yes - it would have become a toaster. Link to comment Share on other sites More sharing options...
Nrw Posted April 7, 2013 Share Posted April 7, 2013 Perrin/AVO is good till like 330whp then they turn red hot. PW/Spearco is better for more. PW cars have been fine with vf40/vf52/16gs. This is the only Spearco I've seen on one of our cars. They're STI fitment stuff works fine on many turbos I've seen. Link to comment Share on other sites More sharing options...
Nrw Posted April 8, 2013 Share Posted April 8, 2013 Photo dump time. Sigma, I still need to work on yours to see if I can pull it off. http://farm9.staticflickr.com/8122/8628657510_08c175a187_c.jpg http://farm9.staticflickr.com/8250/8628656840_b7736b5593_c.jpg http://farm9.staticflickr.com/8524/8628656128_12bd144031_c.jpg http://farm9.staticflickr.com/8403/8628654768_15f008fe25_c.jpg http://farm9.staticflickr.com/8394/8627546427_8eaae87a87_c.jpg I have more pics, just wasn't happy with them. Sorry if your car wasn't shown. Next step is making the videos of the 4 lucky "tuniees". Link to comment Share on other sites More sharing options...
wrxwhit Posted April 8, 2013 Share Posted April 8, 2013 Thanks for the pics NRW!! Wish I could have been part of the seen with my RRP and support the LGT's. I am sure there will be another tune day in the near future.... Link to comment Share on other sites More sharing options...
eckseleven Posted April 8, 2013 Share Posted April 8, 2013 shame all that bulk steers like a carnival cruise line.. All that bulk still weighs less than a spec b and corners just as well. I've never heard anyone say they handle like a cruise liner Looks like it was a good time. Nice cars and nice numbers. Maybe next time I'll make the trip and join in. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted April 8, 2013 I Donated Too Share Posted April 8, 2013 All that bulk still weighs less than a spec b and corners just as well. I've never heard anyone say they handle like a cruise liner this banter about 5th gens I give out is all in jest, partly something pfoyle and I go back and forth about purely for a joke. There's no actual truth in what I say and I think you understand that with the winky face there... but you are saying weigh LESS than a spec b? Since we know these 5th gens are a whopping 47lbs heavier than the LGT and the SpecB has weight saving aluminium parts that the regular LGT's don't - must be the 6 speed gearbox/R180 then I guess? Otherwise if it's a 2006 SpecB I don't think the puke red interior adds that much over it being almost identical to the LGT with the 5spd/R160? Link to comment Share on other sites More sharing options...
Firepuma Posted April 8, 2013 Share Posted April 8, 2013 Like the weight loss of having small hands sigma? Link to comment Share on other sites More sharing options...
Nrw Posted April 8, 2013 Share Posted April 8, 2013 You guys and all your luxurious leather seats, sunroofs, power seats, and navi systems Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted April 8, 2013 I Donated Too Share Posted April 8, 2013 Like the weight loss of having small hands sigma? what the hell are you going on about? LOL! Link to comment Share on other sites More sharing options...
JermTheElf Posted April 8, 2013 Share Posted April 8, 2013 You guys and all your luxurious leather seats, sunroofs, power seats, and navi systems Check, check, check and check Link to comment Share on other sites More sharing options...
BigBlack-V Posted April 8, 2013 Share Posted April 8, 2013 Check, check, check and check mate I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
BrenTuning Posted April 8, 2013 Author Share Posted April 8, 2013 Thank you to everyone who came out! Link to comment Share on other sites More sharing options...
V8Bait Posted April 8, 2013 Share Posted April 8, 2013 Thank you to everyone who came out! No, thank you for the awesome tune. Did a quick run with my buddies 6.0 mildy cammed gto yesterday in Mexico and pulled a car on him Link to comment Share on other sites More sharing options...
