USA 79S Posted July 28, 2005 Share Posted July 28, 2005 I have an 05 STI, and the wife has an 05 LGT. I've been an impreza guy since 2001 but know nada about the LGT. What parts off my STI would be a compatible trade/upgrade on to her LGT 5MT? Thanks Dan Link to comment Share on other sites More sharing options...
USA 79S Posted July 28, 2005 Author Share Posted July 28, 2005 I'm looking to do 2 for 1 mods if that is possible. Link to comment Share on other sites More sharing options...
mkalbarc Posted July 28, 2005 Share Posted July 28, 2005 up-pipe I believe... not sure whatelse. Link to comment Share on other sites More sharing options...
jsalicru Posted July 28, 2005 Share Posted July 28, 2005 lets see... Intake manifold swaps right in... turbos too right after the intake manifold. This also requires the STi TMIC. Brakes swap too.. you can slap on STi Brembos. DPs work as long as you get them extended slightly... and it also depends on the brand/design too. Wheels do too, even the wide ones. The only issue is that you have a 05 STi... so no suspension/brake parts would ever be compatible unless you convert the hubs on the legacy to 5x114. "some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose." Link to comment Share on other sites More sharing options...
mkalbarc Posted July 28, 2005 Share Posted July 28, 2005 "The only issue is that you have a 05 STi... so no suspension/brake parts would ever be compatible unless you convert the hubs on the legacy to 5x114" ^^ and what does that involve? Link to comment Share on other sites More sharing options...
rao Posted July 28, 2005 Share Posted July 28, 2005 The downpipes may or may not fit, most do not without some work. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
USA 79S Posted July 28, 2005 Author Share Posted July 28, 2005 basically if it's not a bolt on mod then it will be aftermarket. But knowing I can do the turbo, intercooler, intake manifold is nice. My brakes are gonna stay stock, and only the springs are coming off. Mostly I guess I am looking at the engine parts. It would be nice to buy a 600 dollar part for the STI and then swap the stocker to the Legacy for another power gain there. What about my injectors. Link to comment Share on other sites More sharing options...
mbacis Posted July 28, 2005 Share Posted July 28, 2005 Injectors are already the same. Link to comment Share on other sites More sharing options...
Beanboy Posted July 28, 2005 Share Posted July 28, 2005 Injectors are the same. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Beanboy Posted July 28, 2005 Share Posted July 28, 2005 Wow, I'm an echo! -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted July 28, 2005 Share Posted July 28, 2005 "The only issue is that you have a 05 STi... so no suspension/brake parts would ever be compatible unless you convert the hubs on the legacy to 5x114" ^^ and what does that involve? I have no experience at all with it, but I can't imagine that it is much more than a hub change. Possibly wheel bearings, and maybe axles, if the hub ends are different. That is taking for granted that you'd be doing the Brembo brake change over (disks for the different bolt pattern) and STi or aftermarket 5x114.3 pattern wheels. I wish Subaru would change that pattern over across the line, anyway. That would increase the possible choices of aftermarket wheels, as 5x114.3 is a much more popular specification. On the engine side, I love the look of the red krinkle-coat intake manifold, but it is aluminum, heavier than the LGT plastic peice, and the LGT has a cover over it anyway. I am not sure if the STi peice flows any better or not. The only reason to change the IC and manifold would really be to get an STi or Twin Scroll turbo that wouldn't otherwise fit the Legacy's intercooler inlet position. Link to comment Share on other sites More sharing options...
USA 79S Posted July 28, 2005 Author Share Posted July 28, 2005 there is a write up on iwsti.com that discusses the 04 - 05 swap for wheels and such. It seemed to very lengthy and expensive. Much more than you'd think, or I'd think anyways. Link to comment Share on other sites More sharing options...
juss 22b Posted August 23, 2006 Share Posted August 23, 2006 does the STi intercooler fit under the stock LGT hood? Link to comment Share on other sites More sharing options...
Th3Franz Posted August 23, 2006 Share Posted August 23, 2006 I heard the 07 Spec B's will have the 5 x 114 bolt pattern. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
700watts Posted August 23, 2006 Share Posted August 23, 2006 I always thought the injectors were smaller..thats good to know...BTW the dealer told me that the injectors were smaller......I knew that didn't sound wright. Link to comment Share on other sites More sharing options...
juss 22b Posted August 24, 2006 Share Posted August 24, 2006 what about the gas pump? is it the same gas pump too? and does the STi intercooler fit under the hood without modding? Link to comment Share on other sites More sharing options...
wukindada Posted August 24, 2006 Share Posted August 24, 2006 If memory serves me correctly it's a different pump.......Yes the int. fit's!! Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
JDM-STI Posted August 27, 2006 Share Posted August 27, 2006 I always thought the injectors were smaller..thats good to know...BTW the dealer told me that the injectors were smaller......I knew that didn't sound wright. Your dealer doesn't know what he's talking about. Same exact injectors. 05 STI CGM~520whp/463wtq...more to come! 08 STI Aspen White/Gold BBS~305whp/365wtq:D Both tuned by Scott Siegel! Link to comment Share on other sites More sharing options...
red beast Posted August 28, 2006 Share Posted August 28, 2006 cd's work in both Link to comment Share on other sites More sharing options...
AirSix Posted August 28, 2006 Share Posted August 28, 2006 cd's work in both Dang it, I was going to say that! I tell myself that an N/A Forester is just an STI without all the fluff like, power, handling, style, racing heritage, and curb appeal. Link to comment Share on other sites More sharing options...
team23jordan Posted August 28, 2006 Share Posted August 28, 2006 STi DP fits but it is bit shorter than LGT DP so u need to go to muffler shop and get a pipe that extends it it should be around like $50 or so Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
700watts Posted August 28, 2006 Share Posted August 28, 2006 Your dealer doesn't know what he's talking about. Same exact injectors. Ya I kinda figured that out..when they couldn't figure out y my fan wouldn't shut off....I had to tell them what was wrong..... Link to comment Share on other sites More sharing options...
