GranTourer Posted July 10, 2004 Share Posted July 10, 2004 Just got my WRX deadpedal from Autospeed today. I finished up installing all the WRX pedals including the accelerator pedal today and boy was it a lot easier than I thought. Since we get electronic throttle in the '05 Legacy, there was no need to pull an accelerator cable or anything like that. Thankfully the throttle springs are attached to the whole pedal assembly, so to remove the stock pedal assembly you simply unplug the electronic harness (thumb squeeze-and-pull deal) and undo two 12mm bolts. Slide the assembly off and one can then follow Scoobymod's directions from there. Here are some pics: Link to comment Share on other sites More sharing options...
SC GT Posted July 10, 2004 Share Posted July 10, 2004 Dude, you are awesome! That looks great. Thanks for being the guinea pig for everyone. Now no one's going to buy the STi pedals. Link to comment Share on other sites More sharing options...
gtguy Posted July 10, 2004 Share Posted July 10, 2004 Those look much better integrated with the rest of the car than the STi pedals. Congrats. Kevin Link to comment Share on other sites More sharing options...
axis008 Posted July 10, 2004 Share Posted July 10, 2004 Dude, you are awesome! That looks great. Thanks for being the guinea pig for everyone. Now no one's going to buy the STi pedals. Yeah thanks! Although it doesn't have the cherry red all over it (which would be nice to have), it looks a lot cleaner than the STI pedals. There is no unsightly screw panel on the side of the pedals, if you know what I mean. -ben Link to comment Share on other sites More sharing options...
bemani Posted July 10, 2004 Share Posted July 10, 2004 Seeing that throttle assembly gives me an idea to put spacers underneath to raise it for easier heel-toe. Would there be any problem with doing that? Link to comment Share on other sites More sharing options...
Dr. Zevil Posted July 10, 2004 Share Posted July 10, 2004 Nice work, I would have to agree that those are much more subtle than the STi pedals. Very nice. I need to install a dead pedal when I get my car. Of course mine will have to be in cherry red to match my pedals. Nice work! Link to comment Share on other sites More sharing options...
powbmps Posted July 10, 2004 Share Posted July 10, 2004 That looks great. Did you get all of the pedals from Autospeed? Thanks, Chris S. Link to comment Share on other sites More sharing options...
Th3Franz Posted July 10, 2004 Share Posted July 10, 2004 Yeah is there a cherry red dead pedal to match the STi ones? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
GranTourer Posted July 10, 2004 Author Share Posted July 10, 2004 Thanks for the kind words everyone Seeing that throttle assembly gives me an idea to put spacers underneath to raise it for easier heel-toe. Would there be any problem with doing that? There would be no problems putting some spacers under the bolts b/c the protruding thread is fairly tall (~6mm). That looks great. Did you get all of the pedals from Autospeed? Only the deadpedal was from Autospeed as they don't sell the factory WRX pedals. I ordered the clutch, brake, and accel pedals from Subaruparts.com for ~$50. Yeah is there a cherry red dead pedal to match the STi ones? Unfortunately no, unless you buy the JDM STi pedal set, but even then the deadpedal wouldn't fit b/c it's for RHD. Also the STi deadpedal, dimensions wise, doesn't fit the USDM deadpedal area. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted July 11, 2004 Share Posted July 11, 2004 Awesome! After seeing the silly rubber pedals in my Outback XT, I've been thinking about this- what a great solution! And it doesn't have to have the pink rubber thingies like what they offer at the dealer! Link to comment Share on other sites More sharing options...
Dr. Zevil Posted July 11, 2004 Share Posted July 11, 2004 We can get a dead pedal for the STi pedals: http://www.rallispec.com/images-pageinfo/thumbRSTA360.jpg from http://www.rallispec.com/product-acc4.htm Don't know if you can buy just the dead pedal though. Link to comment Share on other sites More sharing options...
Dr. Zevil Posted July 11, 2004 Share Posted July 11, 2004 Just read this though: Note: due to LHD/RHD differences the dead pedal cannot be installed as intended (use self tapping screws instead). Link to comment Share on other sites More sharing options...
brady_bunch Posted July 11, 2004 Share Posted July 11, 2004 Just out of curiosity, is there better grip or other functional benefit or are these just bling? They look sweet. I have that same interior so I now know exactly how it would look. Thanks! Link to comment Share on other sites More sharing options...
dimil Posted July 11, 2004 Share Posted July 11, 2004 Thanks, that looks like first mod for me Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted July 11, 2004 Share Posted July 11, 2004 Just out of curiosity, is there better grip or other functional benefit or are these just bling? They look sweet. I have that same interior so I now know exactly how it would look. Thanks! I'd say it's just bling. In fact, I'm re-considering doing this, as my WRX pedals always seemed really slippery when wet. I do, however, want the deadpedal- that plasticky dead pedal does not look like it belongs in a 30 thousand dollar car. Link to comment Share on other sites More sharing options...
Xenonk Posted July 21, 2004 Share Posted July 21, 2004 I assume the brake and clutch pedal is not swapped out the same way as the throttle pedal? Keefe Keefe Link to comment Share on other sites More sharing options...
GranTourer Posted July 21, 2004 Author Share Posted July 21, 2004 Correct, they're replaced quite easily by slipping the original pedal covers off and slipping the WRX ones on with the help of a small flat-head screwdriver. Link to comment Share on other sites More sharing options...
brady_bunch Posted July 25, 2004 Share Posted July 25, 2004 Hey, GranTourer, This doesn't quite look like what you installed: http://www.autospeed.com/shop/category_1652/product_1002100039/browse.html Do you have a link to the product on the Autospeed site? Link to comment Share on other sites More sharing options...
mccorry Posted July 26, 2004 Share Posted July 26, 2004 I couldn't find it either.... Did find one at http://www.kastleskorner.com/store/product_info.php?products_id=406 , but this one looks longer that the one listed in the picture at the beginning of the thread... http://www.kastleskorner.com/store/images/dead_pedal.jpg Where did you buy your dead pedal? Link to comment Share on other sites More sharing options...
mccorry Posted July 26, 2004 Share Posted July 26, 2004 Ah... found it.... http://www.autospeedperformance.com/Subaru/dpedal.htm http://www.autospeedperformance.com/Subaru/DPedalOEM.jpg Mine's on order! :wink: Link to comment Share on other sites More sharing options...
mccorry Posted July 26, 2004 Share Posted July 26, 2004 Doh...double post..... Link to comment Share on other sites More sharing options...
GranTourer Posted July 26, 2004 Author Share Posted July 26, 2004 Wow, that's funny, Autospeed magazine Yep, the last link you posted is for the Autospeed that makes Subaru parts. I actually ordered mine through MastroWRX so I wouldn't pay tax. Same product same price. Link to comment Share on other sites More sharing options...
brady_bunch Posted July 26, 2004 Share Posted July 26, 2004 Wow, that's funny, Autospeed magazine Yep, the last link you posted is for the Autospeed that makes Subaru parts. I actually ordered mine through MastroWRX so I wouldn't pay tax. Same product same price. Great... now I feel doubly goofy. :oops: I couldn't find Autospeed dead pedal via Google except for MastroWRX so I ordered it from there earlier this evening. I wonder why it never showed up at Autospeedperformance.com? FWIW, MastroWRX got pretty good feedback on nasioc. Link to comment Share on other sites More sharing options...
Opie Posted July 28, 2004 Share Posted July 28, 2004 I got all of my pedals today from Mastro! It helps that I work there and Parts is about 6ft away from my desk! Link to comment Share on other sites More sharing options...
Opie Posted July 29, 2004 Share Posted July 29, 2004 And between that last post and now, I installed them all! http://www.subaruchallenge.com/Wills/Photos/pedalsnsills.JPG Thanks for the tips GranTourer! Link to comment Share on other sites More sharing options...
