robitrice Posted December 31, 2012 Share Posted December 31, 2012 worst case just trailer it to WBM my buddy does that alot with his 600hp wrx that is always broken lol Link to comment Share on other sites More sharing options...
spc2125 Posted January 2, 2013 Author Share Posted January 2, 2013 I am approaching 90k miles and looking at the routine maintenance at 105k i believe. However... my situation is a little different. Previous owner.....At 72k miles the turbo blew and the engine was replaced with an oem one with 70k miles. He replaced all belts and clutch. My question is... whats my maintenance schedule now? Link to comment Share on other sites More sharing options...
06specb366 Posted January 2, 2013 Share Posted January 2, 2013 Do whatever your not sure was already done. Can't hurt it. Link to comment Share on other sites More sharing options...
Firepuma Posted January 2, 2013 Share Posted January 2, 2013 Buy a new short block. Link to comment Share on other sites More sharing options...
spc2125 Posted January 2, 2013 Author Share Posted January 2, 2013 Do whatever your not sure was already done. Can't hurt it. I know everything was done. He had shown me the paperwork. But my question is what is the new intervals now? Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 2, 2013 I Donated Too Share Posted January 2, 2013 same intervals as before... they don't change. Regardless you should be inspecting and replacing when needed and do what maintenance is needed when you detect problems, especially as you have a tuned car and you beat on it. Take care of it and it may make it... but you can't go by the interval numbers alone... Do what's needed to be done and stay ahead of it or you'll just fill this forum with more 'oh dear' threads. Link to comment Share on other sites More sharing options...
spc2125 Posted January 2, 2013 Author Share Posted January 2, 2013 So your saying i must change my tbelt at 105k even though it was changed at 70k? Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 2, 2013 I Donated Too Share Posted January 2, 2013 no. I'm saying 105k is the interval... so 175k is when it is due again but if it was my car... I'm not sure I'd 'trust' the other driver... especially since they sold you a car that was beat on with a bad center diff. I'm with 06SpecB366 on this that early changes on important maintenance won't hurt. Honestly, if you believe it was done properly at 70K then I'd most likely in my head be saying at 150K I'd want that out... but I'd be looking, what parts were used, was the water pump changed... I'd be like "Hey Alberto... eyeball that timing set for me please?" Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 2, 2013 I Donated Too Share Posted January 2, 2013 Remember the intervals are for a normal average driven vehicle and even then it's still a guide. I know money is tight for you but the BEST use of that money is in prevention if you intend to keep the car. You're not going to get flamed by anyone on this forum for spending money to do the timing set again but they'll sure as hell quote where you were told to consider being careful when you start a thread "Spc2125 Help thread #85 Something wrong with my valves after I heard a snapping sound while revving the tits off my SpecB going up a hill J turning in front of some 14 year old girls" - they're like that around here... Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 2, 2013 I Donated Too Share Posted January 2, 2013 Oh... and don't skimp on flushing that gearbox oil. Since you're risking it anyway with the 'glitter' in the oil... spend a little on getting as much of it flushed out as possible. Otherwise you will be looking for a transmission still... remember your new center diff is bathing in all that debris too! Link to comment Share on other sites More sharing options...
fahr_side Posted January 2, 2013 Share Posted January 2, 2013 Listen to sigmafour... wise words. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted January 2, 2013 I Donated Share Posted January 2, 2013 If you have paperwork saying the timing belt in particular was changed, and hopefully the water pump, leave it alone until 175k. But keep in mind that 90k is a major service in and of itself. Depending on what was replaced at 70k, you may be able to push the 90k off to 100k, but check air filter, make sure plugs were changed, etc. Link to comment Share on other sites More sharing options...
spc2125 Posted January 2, 2013 Author Share Posted January 2, 2013 I plan on changing the trans oil again in a week or two. And ill most likely adress this in further detail as 100k comes around. But if im in good financial standing to do so, i might go ahead with the normal maintenance at that interval. But at the very least ill do the smaller stuff (water pump, spark plugs, air filter) Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted January 2, 2013 I Donated Share Posted January 2, 2013 You know that you have to pull the timing belt off to do the water pump right? If you're in there you might as well put a new one on... Link to comment Share on other sites More sharing options...
spc2125 Posted January 2, 2013 Author Share Posted January 2, 2013 You know that you have to pull the timing belt off to do the water pump right? If you're in there you might as well put a new one on... Touché Link to comment Share on other sites More sharing options...
Firepuma Posted January 2, 2013 Share Posted January 2, 2013 You may want to get that panel gap between your drivers rear door and fender addressed too. Link to comment Share on other sites More sharing options...
ripemeat Posted January 2, 2013 Share Posted January 2, 2013 so, it was in an accident too? Link to comment Share on other sites More sharing options...
Firepuma Posted January 2, 2013 Share Posted January 2, 2013 I dunno, but the gap looked suspect Link to comment Share on other sites More sharing options...
EJ25subie05 Posted January 2, 2013 Share Posted January 2, 2013 i think its the picture quality that makes it look like it was wrecked, and the paint matches which on a silver car is almost impossible to do unless you paint the whole car. Link to comment Share on other sites More sharing options...
spc2125 Posted January 2, 2013 Author Share Posted January 2, 2013 You may want to get that panel gap between your drivers rear door and fender addressed too. Link to comment Share on other sites More sharing options...
ripemeat Posted January 2, 2013 Share Posted January 2, 2013 i think its the picture quality that makes it look like it was wrecked, and the paint matches which on a silver car is almost impossible to do unless you paint the whole car. Firepuma saw it in person. Link to comment Share on other sites More sharing options...
robitrice Posted January 3, 2013 Share Posted January 3, 2013 my front bumper is hanging on by a zip tie, if you wanna see gap and an awful looking bumper i win lol Link to comment Share on other sites More sharing options...
EJ25subie05 Posted January 3, 2013 Share Posted January 3, 2013 Firepuma saw it in person. my bad thought he was looking at pics. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted January 3, 2013 I Donated Too Share Posted January 3, 2013 @robi3x - fixit. you know it makes me unhappy. LOL Link to comment Share on other sites More sharing options...
robitrice Posted January 3, 2013 Share Posted January 3, 2013 i do everything to spite you sigma.....it will be buttoned up soon i bought quick disconnect pins for the front bumper and in spring a new painted rear w a i <3 Sigma sticker Link to comment Share on other sites More sharing options...
