katalyst Posted March 25, 2012 Share Posted March 25, 2012 I feel your pain. Just went through that 20K miles ago. Decided to do timing belt and the whole shebang at once. I lucked out on a promo $50 hr shop rate. yea me too, since it's all apart anyways. Link to comment Share on other sites More sharing options...
jbrscot Posted March 25, 2012 Share Posted March 25, 2012 Oh noes What's the estimated repair cost? I just know it's a problem with the older gens, but I never looked into how costly it really is... I had mine done a few months ago. Dealer wanted $1700...I had it done for less than $1000 including OEM parts. Many great people on the boards who do great work at great prices! Link to comment Share on other sites More sharing options...
katalyst Posted March 26, 2012 Share Posted March 26, 2012 just an FYI for anyone who does need to replace their headgaskets in the future. the STi headgaskets also fit on our blocks so if you want to consider an alternative that can be an option. Link to comment Share on other sites More sharing options...
katalyst Posted April 1, 2012 Share Posted April 1, 2012 update -- i received my car back from the shop (new headgaskets and timing/accesory belts. runs well. except it is struggling to start, turns over quickly after a short crank but the battery seems to be very weak, i'm losing all my radio presets. i thought maybe cause it was sitting in the shop disconnected for a week or so the charge was low so i drove the car to the mountains this weekend (about 2 hrs one way) and the next day, same symptoms still. the battery is about 16 months old, so i don't believe that's the issue. i'm wondering if i have a parasitic drain somewhere? i figured if the alternator was bad, the battery would be completely dead by now since i've had the car back for 3-4 days now and it's been able to start each time but it just struggles a lot. ideas? Link to comment Share on other sites More sharing options...
stevenva Posted April 1, 2012 Share Posted April 1, 2012 Katalyst: It sounds like your battery had been deep cycled, AKA completely drained. If you do that just one time to a regular car battery you have just cut it's life in half. In your case it is so bad that you are even losing the radio presets. Your battery is roached. http://mgaguru.com/mgtech/universal/ba103.htm RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
katalyst Posted April 2, 2012 Share Posted April 2, 2012 i'm not really certain how the battery could have been deep cycled unless there was something causing it. i go out of town frequently and leave my car sitting for a week and it usually starts without the hesitation it has now. prior to replacing my battery i had similar symptoms in the cold. can a poor ground somehow cause the circuit to draw current while the car is parked? Link to comment Share on other sites More sharing options...
Leviman Posted April 2, 2012 Share Posted April 2, 2012 No. A poor ground would cause less of a draw. It could however, make it crank slow. May sound silly, but have you checked your battery connections? Link to comment Share on other sites More sharing options...
katalyst Posted April 2, 2012 Share Posted April 2, 2012 yea i have. they are tight. Link to comment Share on other sites More sharing options...
2manysubies Posted April 2, 2012 Share Posted April 2, 2012 There are a bunch of grounds to check, main one on top of the engine behind the throttle body, also one coming in from chassis to drivers side head area, may also have one going to exhaust on Pass side, Good news, they are all 10mm, if the bolt fights you coming out, ground is most likely marginal, start car and disconnect battery, still running?? Alternator is putt'in out, with ALL accessories on, brights, defroster, blower fan, anything elect4ric, you should still get around 13.6VDC while connected to the battery(multimeter), seriously, head gasket's are simple in it's self, but I rather pull the motor to do them, just easier for me, LOTS of grounds, check around, you'll find it and good luck!! (I keep thinking Ground, can't help it), unless someone dropped your starter, get it checked. R/Mac Link to comment Share on other sites More sharing options...
katalyst Posted April 3, 2012 Share Posted April 3, 2012 ^ thanks for the advice. i did pull the battery today to have it tested, apparently it was fried, so i got a replacement. i'll wait and see if there's a drain in the system or not. Link to comment Share on other sites More sharing options...
stevenva Posted April 3, 2012 Share Posted April 3, 2012 Katalyst, After reading your opening statement, "update -- i received my car back from the shop", I knew instantly why it drained. The mechanics were just careless and did something stupid like leave the ignition on. I've seen it done sooo many times. Pisses me off and some of them could care less. I wish I could fire them just for not having common sense or caring. The job done was not electrical related so you can stop chasing questionable grounds. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
2manysubies Posted April 3, 2012 Share Posted April 3, 2012 Put a 12v simple test light(probe type you'd check for power with, NOT a Power pack probe) Under "normal usage" one would connect the alligator clip lead to a ground or NEGATIVE on battery and of you put the pointy end on the positive, it lights(please at this point notice how bright it is with a new battery)! Here something I would try, Disconnect the NEGATIVE battery terminal, clip a test lead to the disconnected terminal, put the pointy end of the tester on the Negative battery terminal, how bright is the test light now, a small glow is OK, there are some residual drain from clock amd some powered circuits etc... You can use a ANALOG multimeter to see how much voltage is drawn, but hopefully your problem is fixed already! R/Mac Link to comment Share on other sites More sharing options...
mi-n-bi Posted April 3, 2012 Share Posted April 3, 2012 2009 Legacy with 5700 miles...<------ i know, right!?!?!?!? Link to comment Share on other sites More sharing options...
FUIAAE Posted April 3, 2012 Share Posted April 3, 2012 Rolling up to 160,000miles. Been slappy piston for the last 15,000. Going to get a new engine in here tonight. EG33 FTMFW Link to comment Share on other sites More sharing options...
awalegacy Posted April 3, 2012 Share Posted April 3, 2012 Just about 2,500... Don't think I want to go another 2,500 Link to comment Share on other sites More sharing options...
Malmond24 Posted April 3, 2012 Share Posted April 3, 2012 My 99 Legacy I purchased yesterday has 377,xxx Kilometers Yes it is a canadian beast. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 3, 2012 Share Posted April 3, 2012 2009 Legacy with 5700 miles...<------ i know, right!?!?!?!? 106K on a 09 2.5i Link to comment Share on other sites More sharing options...
2manysubies Posted April 3, 2012 Share Posted April 3, 2012 Looks like I have to press RESET on the 2001 LegOBL... Mileage reset on engine to 54,000?? http://i41.tinypic.com/174vg3.jpg Link to comment Share on other sites More sharing options...
cluesblues Posted April 5, 2012 Share Posted April 5, 2012 137,800 kilometers on an 05 Link to comment Share on other sites More sharing options...
rywhat Posted April 13, 2012 Share Posted April 13, 2012 2012 5,900 Link to comment Share on other sites More sharing options...
Dwreck Posted April 16, 2012 Share Posted April 16, 2012 78331 and DONE on my 2009. It was previously wrecked, believed to be related to my problem. Lost the motor this morning on a 1.5 hour drive, about 5-10 miles from my destination. I'm going to have a hard time buying another used vehicle ever again. My trust in other people is gone out the window at this point. Link to comment Share on other sites More sharing options...
NORULZleggy Posted April 16, 2012 Share Posted April 16, 2012 94K on the 08, I love this car. the STI will come soon. Link to comment Share on other sites More sharing options...
subiebeast22 Posted April 19, 2012 Author Share Posted April 19, 2012 78331 and DONE on my 2009. It was previously wrecked, believed to be related to my problem. Lost the motor this morning on a 1.5 hour drive, about 5-10 miles from my destination. I'm going to have a hard time buying another used vehicle ever again. My trust in other people is gone out the window at this point. Im sorry to hear that. yeah you really gotta be careful who and where you buy a used car from. It does suck that no matter what its still risky. i bought an 06 with 48,485 on july 1,2010 and the thing runs amazingly and still does with 70,700. Have some faith though there are good ones out there and subies are usually great and dependable. Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted April 19, 2012 Share Posted April 19, 2012 108k miles now, on my 2006 SE. I only have one moderately irritating problem at the moment, a lack of power steering at idle Other than that, everything has been routine maintenance. I've been spending much time mending little things over the past week, like the glovebox rattle and cabin air filter replacement. I'm getting my LCA bushings replaced with AVO bushings next week. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 20, 2012 Share Posted April 20, 2012 108k miles now, on my 2006 SE. I only have one moderately irritating problem at the moment, a lack of power steering at idle Other than that, everything has been routine maintenance. I've been spending much time mending little things over the past week, like the glovebox rattle and cabin air filter replacement. I'm getting my LCA bushings replaced with AVO bushings next week. Failing PSP? Any leaks in the rack, return lines , reservoir ? Link to comment Share on other sites More sharing options...
