PearlBlueGT Posted January 15, 2012 Share Posted January 15, 2012 Have estimator come out to your house and check it out, he'll give you estimate (which of course is just an estimate) once they start tearing car apart they might find additional parts/labor so estimate will be more after actual tear down. Link to comment Share on other sites More sharing options...
ruggerheist Posted January 15, 2012 Share Posted January 15, 2012 i almost lost my backend today in the twistys, then i stomped on the throttle and it was fine... jus sayin dawg Link to comment Share on other sites More sharing options...
csbrown28 Posted January 15, 2012 Share Posted January 15, 2012 Hey is that Plasti-Dip on those wheels, looks like it held up great! Link to comment Share on other sites More sharing options...
MasAyinde Posted January 15, 2012 Share Posted January 15, 2012 Can this title be edited to say that the symmetrical AWD probably saved OP from having a much worse accident, and it was his own stupidity that caused the accident? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted January 16, 2012 Share Posted January 16, 2012 It should be changed to "shit happens when you hit black ice" Link to comment Share on other sites More sharing options...
__raj Posted January 16, 2012 Share Posted January 16, 2012 It should be changed to "shit happens when you hit black ice" "shit happens when you hit black ice" too fast. Link to comment Share on other sites More sharing options...
mustangendsley Posted January 16, 2012 Share Posted January 16, 2012 I say you were driving faster than 40 mph!!! Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 16, 2012 Share Posted January 16, 2012 Symmetrical AWD screwed me over... It took my girl and shot my dog. Link to comment Share on other sites More sharing options...
MasAyinde Posted January 16, 2012 Share Posted January 16, 2012 And it wrecked my car Link to comment Share on other sites More sharing options...
frank_ster Posted January 16, 2012 Share Posted January 16, 2012 mine too.. we should file a class action lawsuit against all awd cars Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
csbrown28 Posted January 16, 2012 Share Posted January 16, 2012 The OP really took the ball and set it up on a tee... *WHACK* Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 16, 2012 Share Posted January 16, 2012 My car does not handle nearly as dangerously as Subaru clearly had intended. should sue. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
1454 Posted January 18, 2012 Share Posted January 18, 2012 Words of wisdom op, make sure that battery is still sealed. Leaky, damaged battery can do alot of damage. I've seen two cars that were in the process of being repaired until they realized the damage from the acid. Link to comment Share on other sites More sharing options...
executor485 Posted January 18, 2012 Share Posted January 18, 2012 It was probably soap on the intercooler that made his AWD fail and caused him to wreck. I've heard that leads to numerous problems. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 18, 2012 Share Posted January 18, 2012 mine too.. we should file a class action lawsuit against all awd cars No, he should sue the cable manufacture and the company that installed the it. Because if the cable wasn't there, this damge would not have happened. So obviously, it's all there fault. I'm also sure the trucking company that shipped the cable from the manufacture to the Power company is also at fault. Hey may he could go after the company that made that truck too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 18, 2012 Share Posted January 18, 2012 It was probably soap on the intercooler that made his AWD fail and caused him to wreck. I've heard that leads to numerous problems. Turbo spooled when he hit a puddle? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
fahr_side Posted January 18, 2012 Share Posted January 18, 2012 Turbo spooled when he hit a puddle? Yup, at 12mph. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
executor485 Posted January 18, 2012 Share Posted January 18, 2012 If only he could have pushed it to 88mph, he might have been able to go back and prevent the AWD from failing. If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
Nrw Posted January 18, 2012 Share Posted January 18, 2012 No, he should sue the cable manufacture and the company that installed the it. Because if the cable wasn't there, this damge would not have happened. So obviously, it's all there fault. I'm also sure the trucking company that shipped the cable from the manufacture to the Power company is also at fault. Hey may he could go after the company that made that truck too. Don't stop there.. Gotta go after the state to. They're the ones who told the other companies to put that damn cable there! Link to comment Share on other sites More sharing options...
magnoon Posted January 19, 2012 Author Share Posted January 19, 2012 Listen guys, I already apologized for my thread title being out of line, I was just a little PO'd about my car :/. I just want to know if my car looks totaled or not, that's all I'm asking. I know that the accident was the fault of driver error, lifting my foot off the gas in panic. Thank you all who responded with helpful posts. Very much appreciated. Thanks, Chris Link to comment Share on other sites More sharing options...
Max Capacity Posted January 19, 2012 Share Posted January 19, 2012 Listen guys, I already apologized for my thread title being out of line, I was just a little PO'd about my car :/. I just want to know if my car looks totaled or not, that's all I'm asking. I know that the accident was the fault of driver error, lifting my foot off the gas in panic. Thank you all who responded with helpful posts. Very much appreciated. Thanks, Chris Your insurance hasn't told you yet ? It's been a few day's right ? I would say if those no sub frame damage your good. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rock2534 Posted January 19, 2012 Share Posted January 19, 2012 The insurance must put you in the same position you were in before the loss. They cannot replace your car with worse parts then what you had before....that would be illegal and you could make a complaint with the dept of insurance. I'm an auto insurance adjuster. Look up the word Indemnity Just curious, so you are saying that even though the driver has not informed the insurance company to add the aftermarket parts to the policy, they insurer will still cover those parts and compensate higher? I am not in the insurance biz, but find that hard to believe. Also, I see your other post you mention that it could devalue the car in their eyes, so that would be their way around it also. Like I said, just curious. Link to comment Share on other sites More sharing options...
Riptide Posted January 19, 2012 Share Posted January 19, 2012 Am I misunderstanding the situation here? Help me out. Lift off oversteer happens when you let off the throttle and then the car gets unsettled. This is typically in a turn. What about when the rear end comes unsettled and you are already in the throttle when it happens? Due mainly to crap tires (AFAICT) my car has fishtailed on me before when I accelerated from an intersection. Thus far, I have let off the throttle, stayed out of the brake, and just counter steered back into a straight line. Then back into throttle again. Am I making a mistake here? Link to comment Share on other sites More sharing options...
rock2534 Posted January 19, 2012 Share Posted January 19, 2012 Am I misunderstanding the situation here? Help me out. Lift off oversteer happens when you let off the throttle and then the car gets unsettled. This is typically in a turn. What about when the rear end comes unsettled and you are already in the throttle when it happens? Due mainly to crap tires (AFAICT) my car has fishtailed on me before when I accelerated from an intersection. Thus far, I have let off the throttle, stayed out of the brake, and just counter steered back into a straight line. Then back into throttle again. Am I making a mistake here? If you have traction and the back end is sliding out, then you are probably going too fast for conditions and/or tires and getting your "drift" on. Link to comment Share on other sites More sharing options...
SpecBGuy Posted January 19, 2012 Share Posted January 19, 2012 +1000 the title makes u look bad. anyways, any update on the what body shop or insurance said on damage. Link to comment Share on other sites More sharing options...
