subikid90 Posted October 13, 2011 Share Posted October 13, 2011 NO only 1 trust bearing at number 5, you put the normal main bearing in the number 3 location. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 14, 2011 Author Share Posted October 14, 2011 oh, it still sits there? even know it can except a thrust bearing? BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 15, 2011 Author Share Posted October 15, 2011 when inspecting the crank and rods i noticed that the rods had a bit of side to side play. not like sliding on the jornal but moving not parallel to the crank. just fyi. and im going to have the block machined to take a #5 thrust and then i need a phase 2 crank... anybody got a phase 2 crank laying around? BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 15, 2011 Author Share Posted October 15, 2011 new sti rods are 53 a piece new.. some one wants to sell me a new set for 125 shipped... ill think ill do it:) BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 17, 2011 Author Share Posted October 17, 2011 looking at sti rods compared to our rods... dont look much different? what changes the CR? the piston dish cc's? BNR18g on 93oct Link to comment Share on other sites More sharing options...
jamaha51 Posted October 17, 2011 Share Posted October 17, 2011 I found an ej257 crank for 60 in colorado springs craiglist. I can post a link later. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 17, 2011 Author Share Posted October 17, 2011 sounds good. I want to see that for sure. BNR18g on 93oct Link to comment Share on other sites More sharing options...
jamaha51 Posted October 18, 2011 Share Posted October 18, 2011 http://pueblo.craigslist.org/pts/2627002467.html Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 18, 2011 Author Share Posted October 18, 2011 hmm.... BNR18g on 93oct Link to comment Share on other sites More sharing options...
jamaha51 Posted October 18, 2011 Share Posted October 18, 2011 Ya, if I had enough money to be building my engine up it would be gone already! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 18, 2011 Author Share Posted October 18, 2011 you can buy these used parts and end up just haveing to spend money having them grinded and it might cost more then a new crank all together. BNR18g on 93oct Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 18, 2011 Share Posted October 18, 2011 looking at sti rods compared to our rods... dont look much different? what changes the CR? the piston dish cc's? Indeed. There is less on the piston dish on a 257 than there is on a 25D or any N/A Subaru EJ25. Gasket thickness is a factor too. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 18, 2011 I Donated Share Posted October 18, 2011 Gasket thickness is a BIG factor -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 18, 2011 Author Share Posted October 18, 2011 ok tell me this. how much of a change in gasket thinkness can change CR. sti rods and our rods are basically the same lenght. is the piston pin on sti pistons located different from the face then ours? BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted October 18, 2011 Share Posted October 18, 2011 When building a motor, basically, can be the difference between a working motor and an expensive paper weight. A gasket can change compression ratio 0.5 or more depending on how thick of gasket you go with -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 18, 2011 Author Share Posted October 18, 2011 damn... yea im starting to think im in over my head building this motor.. i have thing to think about like CR, bearing sizes, ptw clearence, ring gap and ponies. how important is PTW clearence. cause my block is going to be honed again and these used pistons im getting are unknown sizes.. BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted October 18, 2011 Share Posted October 18, 2011 Your pistons have an A or B size. The block also has these sizes stamped on it from the factory. You MUST have pistons that match the bore, A or B, or bore the motor 20 over and use 20 over pistons and rings. The FSM for our cars has what the tolerances for A and B sized pistons are. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 18, 2011 Author Share Posted October 18, 2011 what a pain in the ass. so if i have a piston thats to small for my bore im screwed. should just get 100mm pistons and bore to the right ptw clearence. BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 23, 2011 Author Share Posted October 23, 2011 sti rods and pistons in the mail. BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 23, 2011 Author Share Posted October 23, 2011 Modified Td-04 turbo (welded wastegate and rotated compressor housing) Forced air tech top-mount intercooler- Ebay BOV manual boost controller Custom intake PCV system (1 catch can and hoses) coolant hoses (for turbo) boost gauge custom headers custom uppipe custom 3indown/external waste gate 38mm(7psi spring) Full 3inch exhaust turbo inlet with catch can for pvc and head vent. awd 5spd tranny matching diff and driveshaft clutch to go with it.(stage 2 f1) i forgot some stuff rear and front half shafts crossmembers for tranny control arms knuckles eibach struts with lower springs and a greddy e-manage blue no wires gave me a package deal for one grand. picking it up next weekend maybe. love craiglist BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 25, 2011 Author Share Posted October 25, 2011 pistons and rods came in today. BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 25, 2011 I Donated Share Posted October 25, 2011 why do you have 3 threads floating around will all the same shit in them? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted October 25, 2011 Share Posted October 25, 2011 STi rods seem a little beefier than the 25D rods...just observing. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 25, 2011 I Donated Share Posted October 25, 2011 yes they do. it didnt look like it until i saw a close up of them -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 26, 2011 Author Share Posted October 26, 2011 yea.... what you think sti rods should look like? this are not ej25d. if they were they would fit my stock crank. reason i have the other thread is cause i wanted to talk motor building and would get more input if i made a new thread. BNR18g on 93oct Link to comment Share on other sites More sharing options...
