Jab83 Posted October 3, 2011 Share Posted October 3, 2011 that doesn't sound.... all that great. be better off turboing the 2.2. tis what i'm doing. unless i do a h6 swap or a sti/wrx. or JDM swap.. WHo knows! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 12, 2011 Author Share Posted October 12, 2011 you can turbo the ej25d block. just gotta get new rods and pistons. lower CR got everything took apart now. if i can keep the block at 99.5 mm i will otherwise im going to 100mm just gotta order bearings....but what one ones fit? just stockers? or stuff made for the sti and wrx and looking for a set of sti connecting rods... and im stuck on what to do about pistons... stock sti or these http://www.oakos.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=355&Product_Code=MAH-WRX209917I22&Category_Code=0407STI-PISTONS BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jab83 Posted October 12, 2011 Share Posted October 12, 2011 I've found that you can do that. lol... i'm gonna find a complete sti rebuild kit with aftermarket pistons and rods. and rebuild my 2.5 Link to comment Share on other sites More sharing options...
jamaha51 Posted October 12, 2011 Share Posted October 12, 2011 I don't know if you saw this swagon but there is a lot of info on boosting a ej25d. http://www.rs25.com/forums/f7/t39629-boosted-ej25d.html Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 12, 2011 Author Share Posted October 12, 2011 Did the ej25d come with a 10mm oil pump? cuz i got one already! yup seen that too. and this http://forums.nasioc.com/forums/showthread.php?t=1888017&page=4 BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jab83 Posted October 12, 2011 Share Posted October 12, 2011 hmmmmm. is there a way to mod the phase 2 crank to work in a phase 1 block? or am i just stuck with phase 1 crank? and there for have to use diff rods. :/ Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 12, 2011 Author Share Posted October 12, 2011 wait what? someone explain the problem or pros with a phase one or two? what do i have? i have hydraulic valve lash and the thrust bearing is not in the center i think... the rods dont have the angled ends... and i have a size 10 oil pump that i think is not stock. BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jab83 Posted October 13, 2011 Share Posted October 13, 2011 yours is a phase one block...... Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 13, 2011 Author Share Posted October 13, 2011 damn it subaru why you make it so weird. now i have no idea what fits. im just gonna run sti rods and pistons if i can. BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jab83 Posted October 13, 2011 Share Posted October 13, 2011 you cant unless its a phase 2 crank....... :/ the sti rods wont fit one the crank. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 13, 2011 Author Share Posted October 13, 2011 whats the reason why? can i still use this block? BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jab83 Posted October 13, 2011 Share Posted October 13, 2011 you can. i forget why. let me find it i some one told me this not to long ago Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 13, 2011 Author Share Posted October 13, 2011 i read i could run a phase 2 crank in a phase block. this is good. phase one block is better and phase 2 crank can run sti rods. im going to have to mill the block for a #5 thrust BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jab83 Posted October 13, 2011 Share Posted October 13, 2011 yeah but you have to mod the crank. I cant find any diy's or how to do it. grrr... Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 13, 2011 Author Share Posted October 13, 2011 i think you mean move the thurst bearing i dont even know anymore.. im gonna go look to see where that thrust bearing is again.. its that larger one right... BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jab83 Posted October 13, 2011 Share Posted October 13, 2011 hell if i know.. I cant remember. I couldn't find the person i was talking to about it. :/ Link to comment Share on other sites More sharing options...
Jab83 Posted October 13, 2011 Share Posted October 13, 2011 change the crank out in the EJ25D block so you could use STi rods (since STi rods have larger crank journals then EJ25D rods and won't work with stock 25D crank Okay, Ill try to explain better. In 1999, the Forester, and the Impreza 2.5 RS got the full Phase 2 EJ25, the one with a phase 2 block (thrust bearing at #5, and 52mm rod journals), 10mm oil pump, and the SOHC heads. Everyone know that, nothing special here, lol. I found all this in this thread http://forums.nasioc.com/forums/showthread.php?t=1888017&page=4 Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 13, 2011 Author Share Posted October 13, 2011 ok this sounds wierd but i had a 10mm pump and iirc the thrust bearing was not in the middle. it is the closer to the front the block? btw. this block in my 96 had a different engin put in. so maybe i have a phase 2 block with hydrlic heads? that would rock.. hell ill measure the rod i have sitting here on the desk. edit.. the rod here measures 51 without bearings.. so i guess not BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jab83 Posted October 13, 2011 Share Posted October 13, 2011 lol Link to comment Share on other sites More sharing options...
Jab83 Posted October 13, 2011 Share Posted October 13, 2011 you could have a 99 plus fozzy or rs engine Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 13, 2011 I Donated Share Posted October 13, 2011 gee swagon...this picture looks familiar. Did you post this saying it was yours? http://i1008.photobucket.com/albums/af205/cdnsigop/EJ25%20Build/DSC02790.jpg -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 13, 2011 I Donated Share Posted October 13, 2011 see : http://i1008.photobucket.com/albums/af205/cdnsigop/EJ25%20Build/DSC02790.jpg -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 13, 2011 Author Share Posted October 13, 2011 no. i posted it casue you asked... all my information came from that thread. and some others so brok. what should i do.... i supose my 97 wagon has the same junk in it too... phase one... BNR18g on 93oct Link to comment Share on other sites More sharing options...
Jab83 Posted October 13, 2011 Share Posted October 13, 2011 look around on how to mod a phase 2 crank in to a phase 1 block. wheres johnegg when we need him he would know! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted October 13, 2011 Author Share Posted October 13, 2011 you gotta machine the block to except a #5 thrust bearing im sure.. then run 2 thrust bearings? BNR18g on 93oct Link to comment Share on other sites More sharing options...
