wukindada Posted June 3, 2006 Share Posted June 3, 2006 STG.......any of those yours? Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
-TT- Posted June 3, 2006 Share Posted June 3, 2006 i just want twin turbos DO IT! Link to comment Share on other sites More sharing options...
andrew.anderson Posted June 3, 2006 Share Posted June 3, 2006 Irony is that if the tires did slip, I'd be over in Wheels/Tires bitching about how I need more traction (but not less horsepower). Agreed. If my tires squeeled i would be a little pissed. We did not put all that money in to the car just to lose the HP due to poor traction. Link to comment Share on other sites More sharing options...
team23jordan Posted June 3, 2006 Share Posted June 3, 2006 250...not enough new camry makes more than 250 Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
VTGT Posted June 3, 2006 Share Posted June 3, 2006 Legacy needs 280+ just to be considered somewhat powerful now. Link to comment Share on other sites More sharing options...
STi Boy Posted June 3, 2006 Share Posted June 3, 2006 we need more torque Link to comment Share on other sites More sharing options...
Elec Posted June 3, 2006 Share Posted June 3, 2006 You certainly don't NEED 250 horses. My last car had about 120hp and got me around just fine (although it was unbelievably boring and only did about 2-3mpg better than the LGT). Whether we all want that much power (or more) is a different issue. Having said that, I'm getting used to my Leggy's power after owning it a month and a half. At times it pulls so hard it surprises me. Other times, I find myself going "I know you're faster than this...". Hard to know whether I should blame it on 5EAT, current gear, outside air temp, turbo not fully warmed up, or if it's just how the power delivery is. I wouldn't mind a little more power, but since I don't plan to track the car and need to keep it a reasonable daily driver, I'll probably get an AP and either stop there or at stage 2. Link to comment Share on other sites More sharing options...
emorphien Posted June 3, 2006 Share Posted June 3, 2006 Legacy needs 280+ just to be considered somewhat powerful now. Isn't the 250/250 somewhat of a modest estimate anyway? Legacy still gets the power to the ground better than the Camry or most other cars in its class with big engines. Link to comment Share on other sites More sharing options...
rao Posted June 3, 2006 Share Posted June 3, 2006 There is nothing wrong with the Legacy that an additional 150 hp won't cure Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Lagacy GT Posted June 3, 2006 Share Posted June 3, 2006 250 hp coming from a turbocharged 4 cylinder makes me smile. I don't think a 270hp V6 engine would make me smile as much. Link to comment Share on other sites More sharing options...
Brady Posted June 4, 2006 Share Posted June 4, 2006 As others have noted, there is no way I NEED the 250 horse power. In fact, it's quite an expense for me. I burn up more gas, my car was more expensive because if it, my insurance is higher and I've been much more likely to spend money on more mods. For all that, I actually SMILE when I drive my car. I enjoy on ramps, I enjoy passing, I enjoy the occasional pull from stop lights. I enjoy pulling out of long sweeping corners. I enjoy the power. There are many other things I enjoy about the car, but the power is one of the most tangible things I can say make the car fun for me. Link to comment Share on other sites More sharing options...
warteaufmich Posted June 5, 2006 Share Posted June 5, 2006 we need more torque I would settle for a torque curve that doesn't take a nosedive after 4krpm. If torque could stay more or less constant after 4krpm, the stock 250 lb-ft would result in over 300HP at 6.5krpm. Cobb stage 2's supposed 345 lb-ft would equate to 425HP at 6.5krpm. Bigger snail helps to achieve that goal, but I guess some serious headwork would be involved to really keep the torque up at the high end of the powerband. Fortunately I don't bleed money when cut, otherwise I'd be slashing my wrists for this car. Link to comment Share on other sites More sharing options...
