08LGT80 Posted October 28, 2010 Share Posted October 28, 2010 so i took the leggy to the dealer for service yesterday. the service advisor suggest that my throttle body is dirty and needs to be cleaned. he said 299.99 for the service. should i do it? is there a cheaper solution? is this something i can do myself? or have anyone have had experience with this before? Link to comment Share on other sites More sharing options...
rao Posted October 28, 2010 Share Posted October 28, 2010 Complete nonsense. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted October 28, 2010 Mega Users Share Posted October 28, 2010 Which dealership was this so I can avoid them like the plague when I move over there? Link to comment Share on other sites More sharing options...
N.sane Posted October 28, 2010 Share Posted October 28, 2010 You just defined the term "stealership" right there I dont see the need to clean it since it's just filtered air going through it. Link to comment Share on other sites More sharing options...
08LGT80 Posted October 29, 2010 Author Share Posted October 29, 2010 Which dealership was this so I can avoid them like the plague when I move over there? Walker's Renton Subaru. Link to comment Share on other sites More sharing options...
08LGT80 Posted October 29, 2010 Author Share Posted October 29, 2010 You just defined the term "stealership" right there I dont see the need to clean it since it's just filtered air going through it. my friend said that throttle bodies do get dirty sometimes from dust particles that doesn't get filtered from the air intake filter. is this true? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted October 29, 2010 Mega Users Share Posted October 29, 2010 They can get a little dirty, but nothing that a rag can't take care of and nothing that would effect performance. Unless you don't have a filter. Link to comment Share on other sites More sharing options...
liljonson Posted October 29, 2010 Share Posted October 29, 2010 wrong. They can get gunked up and stick. but $300 is nonsense. Get some throttle body cleaner and just spray and wipe yourself.Doesn't mean yours is gunked up or will need it but $300 is insane Link to comment Share on other sites More sharing options...
f1anatic Posted October 29, 2010 Share Posted October 29, 2010 I dare disagree with RAO. On one of my Subaru cruises, I was the last car, bringing up the rear and an hour of dirt/gravel driving did it. I did have sand and dust in my vag...throttle body and throttle body hose and it did need cleaning.T he symptom I had was erratic idle, even stalling and cleaning did remove the problem. But get yourself a throttle body cleaner (spray) and a trusty socket wrench and screwdriver (for the throttle body hose) and do it yourself. If you are still on OEM TMIC it will be brainless easy. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted October 30, 2010 Mega Users Share Posted October 30, 2010 I've never had one gunk up on me. I've just wiped the crud off and put it back together. $300 is insanity though. Link to comment Share on other sites More sharing options...
bmx045 Posted October 30, 2010 Share Posted October 30, 2010 On my jeep, explorer, and now my legacy, black carbon/gunk build up develops there... I have noticed a smoother idle, better throttle response after a good cleaning. $300 is bullsh!t though. Just pull it out and clean it yourself with TB cleaner from autozone, or electrical contact cleaner (sensor safe). The most important part is getting the black buildup that can occlude the idle air from getting through when the body is closed. Thats pretty much the black stuff that cakes on the top and bottom in between the flap door, might take some good scrubbing but IMO it's a good maintenance habit. Hold the door completely open (full throttle) and scrub the black ring on the top and bottom of the body right where the door would sit when idle....you'll see what I mean Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 30, 2012 Share Posted August 30, 2012 Sorry to dig up an old thread. When removed did any of you have to replace the seal to the manifold? Getting ready for some updates and neeed to clean the TB for sure. Link to comment Share on other sites More sharing options...
jerseyglock Posted August 30, 2012 Share Posted August 30, 2012 You will need to remove your TMIC and TB (optional), clean both side of the plate with a toothbrush. Link to comment Share on other sites More sharing options...
brad_houck Posted August 30, 2012 Share Posted August 30, 2012 i work at a dealership and do prefer the process we use as opposed to using just throttle plate cleaner and a rag. i agree $300 is way too much but it does a hell of a job not only cleaning the throttle body spotless but also the whole intake track after the throttle body. it uses a cleaner and shop air through a machine with a nozzle wedged in between the throttle body hose and throttle body and sprays the cleaner in that way. gets great results but not for $300. i think at my dealer we charge about 100-150ish. Link to comment Share on other sites More sharing options...
kzr750r1 Posted September 11, 2012 Share Posted September 11, 2012 Main thing I was concerned about is removing the TB and needing another gasket... Not the case with these o ring seals. Didn't go into the whole intake track but was able to clean the TB very well after removing. Link to comment Share on other sites More sharing options...
Red-rover Posted September 17, 2012 Share Posted September 17, 2012 I would be a little weary of cleaning a drive by wire throttle body unless u are careful. I work at younker nissan right by walkers renton subaru and most of our nissans have drive by wire TBs and I have personally replaced a fair amount due to people trying to clean them by themself or improperly and damaging the interals/motors... Just an fyi and to be cautious... Link to comment Share on other sites More sharing options...
kzr750r1 Posted September 18, 2012 Share Posted September 18, 2012 Thanks and mine still seems to be fine. I'm now on to looking at the PCV as my problem post TB cleaning. Would have been nice to be done but looks like I've been lucky with 126k on the stock PCV. Used caution in cleaning the TB after removed. Used a TB cleaner not carb cleaner... TB cleaner acts much like MAF cleaner in that it evaporates pretty fast. Did take some mechanical help with a rag to get the built up crud off of the high pressure areas. Link to comment Share on other sites More sharing options...
triple_B Posted November 3, 2012 Share Posted November 3, 2012 i want to smoke test my entire system. how do i open my electronic Throttle body, (TB) plate correctly? i dont push it like old school do i. can i simply turn the car to ACC and put a brick on the accelerator pedal? thanks Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 2, 2013 Share Posted July 2, 2013 So long as your carful and don't bend the butterfly all should be fine. I moved mine while the TB was out to get the buildup off with a little mechanical and chemical persuasion. Link to comment Share on other sites More sharing options...
