IanB Posted December 22, 2010 Share Posted December 22, 2010 Mine is auto, I thought yours was as well? If not, I can probably make one for you, as it seems pretty simple. I also saw that learning view was made by merchgod and got upset at first, but if you check the last few pages of posts, just before yours, you'll see he says "I've started working on it again here and there. I don't really have an ETA at this point, though." So hopefully he's starting up on it again, I wonder hope he will include support for out 2.5i's and not just for the new sti/wrx Mine is auto as well, just wanted to make sure. I actually posted in that learning view thread earlier today to let merchgod know that we are without support if he's working on it again. Link to comment Share on other sites More sharing options...
2005legacy2.5i Posted December 29, 2010 Author Share Posted December 29, 2010 Hey I haven't been on here in a while but I keep getting [18:48:16.968] validating denso kernel ram area addr: FFFF6000 len: 0D98 I'm using Version 1.29.906 does anyone have any guidance for me? thanks Link to comment Share on other sites More sharing options...
IanB Posted January 19, 2011 Share Posted January 19, 2011 Well I haven't had a chance to touch anything since before Christmas now, but I might try to get out and do some more logging tonight. When I left off I was datalogging MAF tabs, to calibrate the MAF sensor. Takes a while to get a good log, 40+ minutes of low throttle input driving, boourns. Link to comment Share on other sites More sharing options...
pre-dent Posted January 30, 2011 Share Posted January 30, 2011 Does anyone know where I can download ecuflash 1.31? I have tried for about an hour to find it searching, but to no avail. I have pulled the ROM with ecuflash 1.42 but it won't read the file saying it's not defined. I have tried adding the definitions with no luck. Link to comment Share on other sites More sharing options...
dschultz Posted January 30, 2011 Share Posted January 30, 2011 A different version of EcuFlash won't help. If it's not defined, then that's it, it's not defined in any version of EcuFlash. Are you using the latest definitions? Found here. If so, and yours is not defined then you need to submit the ROM for definition creation at RomRaider. Link to comment Share on other sites More sharing options...
pre-dent Posted January 30, 2011 Share Posted January 30, 2011 Thank you, I actually submitted the ROM last night and you've already created a ticket for me. I appreciate it. I read through this thread and noticed a few people were saying that ecuflash 1.31 worked for them when other versions didn't, however, after a few hours of reading/searching I figured out that wasn't my problem so I joined the romraider forums. I noticed the CAL ID is very similar to the 2005 Impreza 2.5RS... E2ZJ121B vs E2ZJ121G. I have read the thread "Defining an unknown ROM, similar to a known ROM" and I am very tempted to try it myself, however, I doubt I'll be successful. Link to comment Share on other sites More sharing options...
pre-dent Posted January 30, 2011 Share Posted January 30, 2011 dschultz, would you be so kind to take a look at my forum post over on romraider when you get a chance to answer my questions? http://www.romraider.com/forum/viewtopic.php?f=3&t=6934&p=65793#p65793 Link to comment Share on other sites More sharing options...
sulk Posted February 2, 2011 Share Posted February 2, 2011 Just to clarify is anyone else still running/fine tuning their tune? The last 3 logs I did I lost, so I haven't logged it in a while. But the thing that I'm not sure about is when I do dyno pulls using RR, I'm getting funky results. Interested to see what other people are getting. Link to comment Share on other sites More sharing options...
2005legacy2.5i Posted February 3, 2011 Author Share Posted February 3, 2011 I'm still stuck and I haven't had the motivation to try to work on it, I want E-85!!! Link to comment Share on other sites More sharing options...
dschultz Posted February 3, 2011 Share Posted February 3, 2011 But the thing that I'm not sure about is when I do dyno pulls using RR, I'm getting funky results. Interested to see what other people are getting. Such as the throttle reading not staying at 100% through the entire pull? Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted February 4, 2011 Share Posted February 4, 2011 I have the functioning ROM, ROM DEFS, LOGGING DEFS, ECUFash data, ect for the 05 2.5i Legacy. I was going to tune pre-dents car, but didn't have it all together and functioning until recently. The injector size is very small, so you would need to do a lot to make e85 worth the cost. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
CDN 2.5i Posted February 4, 2011 Share Posted February 4, 2011 440cc topfeeds can be had for around $100 and probably flow enough for the 2.5i I would expect. They're all that AVO recommends for their turbo kit. Link to comment Share on other sites More sharing options...
2005legacy2.5i Posted February 4, 2011 Author Share Posted February 4, 2011 I have the functioning ROM, ROM DEFS, LOGGING DEFS, ECUFash data, ect for the 05 2.5i Legacy. I was going to tune pre-dents car, but didn't have it all together and functioning until recently. The injector size is very small, so you would need to do a lot to make e85 worth the cost. Thanks! Yea I know I need to get bigger injectors to run e-85 but the gains seem worth it, I guess I better find some injectors would 440cc work or what would you recommend? Thanks Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted February 4, 2011 Share Posted February 4, 2011 440's really are not that big, especially for e85. Plus, the 05 and 06 are sidefeeds, unless the NA is different. The 02-05 WRX uses 420cc injectors, pretty close to the same size. The 05-06 LGT's use 520cc injectors and the 07+ are 550cc. Most Legacy GT owners, who switch to e85, get a minimum of 800cc injectors. You'll also need a fuel pump, ect. I would see what gains are made with some slight mods first. No sense in dumping so much money if it's not worth it. You'll get to the point where an LGT would end up being a better option. Just my $.02 www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
CDN 2.5i Posted February 4, 2011 Share Posted February 4, 2011 '05 2.5i is topfeed, stock injectors are 265cc I'm pretty sure. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted February 4, 2011 Share Posted February 4, 2011 245.98, to be exact www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
sulk Posted February 4, 2011 Share Posted February 4, 2011 Such as the throttle reading not staying at 100% through the entire pull? No, more like wonky hp/torque curves, etc. I can't seem to get the same curves more than once. Although I must say, everytime I've done pulls I havn't really prepared for them, and only do a couple per run. The one thing that's consistent though is the max hp, it's always hovering around the same But I do have to go out and just take some time to do some dyno's properly, maybe it's just been the conditions I've been doing them in. Is that an issue that's been happening though? I haven't had a lot of time to check the RR forums recently Link to comment Share on other sites More sharing options...
dschultz Posted February 4, 2011 Share Posted February 4, 2011 I saw it once logging an '09 Impreza 2.5i. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted February 4, 2011 Share Posted February 4, 2011 No, more like wonky hp/torque curves, etc. I can't seem to get the same curves more than once. Although I must say, everytime I've done pulls I havn't really prepared for them, and only do a couple per run. The one thing that's consistent though is the max hp, it's always hovering around the same But I do have to go out and just take some time to do some dyno's properly, maybe it's just been the conditions I've been doing them in. Is that an issue that's been happening though? I haven't had a lot of time to check the RR forums recently Have you been using the same stretch of road the same time? Can you post some of your datalogs? www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
dschultz Posted February 4, 2011 Share Posted February 4, 2011 This may be a bit of help re: repeatability. Link to comment Share on other sites More sharing options...
IanB Posted February 4, 2011 Share Posted February 4, 2011 My efforts have been totally de-railed since Christmas, and I'm going to pick up my new-to-me truck ('96 Hilux Surf 3.0TD) in a couple of weeks, so I'm honestly not sure when I'll get back into this. The new project will keep me busy for the forseeable future, and I won't be driving the Legacy nearly as much going forward. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted February 4, 2011 Share Posted February 4, 2011 This may be a bit of help re: repeatability. I don't use the RR dyno feature. I use bad noodles and other software. This chart shows the difference between a stock LGT and my car, with just an STi up pipe and one gutted down pipe cat, running at 16psi. At one point (around 3,200rpm) or so, my car is making 80wtq more than the stocker Both use a smoothing factor of 4. Again, this is at 4,500ft so numbers would be higher at lower elevation. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
sulk Posted February 4, 2011 Share Posted February 4, 2011 This may be a bit of help re: repeatability. Thanks for the link I'll make sure to read through it before I go out next time. And I haven't been saving too many of my dyno pulls because of the wonky results. Link to comment Share on other sites More sharing options...
dschultz Posted February 4, 2011 Share Posted February 4, 2011 I don't use the RR dyno feature. Maybe beause you're not using a recent version of RR...? My car. The reference line (thin & faint) is a pull in sub-zero weather. http://www.romraider.com/forum/download/file.php?id=11930&mode=view Link to comment Share on other sites More sharing options...
dschultz Posted February 4, 2011 Share Posted February 4, 2011 And I haven't been saving too many of my dyno pulls because of the wonky results. You can also load in any 3rd, 4th gear pull you saved. As long as it contains Time, RPM and TPS. Link to comment Share on other sites More sharing options...
