burnout8488 Posted October 15, 2010 Share Posted October 15, 2010 I posted my rom on the RR forums and it looks like a new definition is required for our cars. I'm not sure if its the transmission, or because my car is USDM that a new one is required, but it will be made nonetheless! http://www.romraider.com/forum/viewtopic.php?f=8&t=6631&p=63391#p63391 Link to comment Share on other sites More sharing options...
IanB Posted October 15, 2010 Share Posted October 15, 2010 I posted my rom on the RR forums and it looks like a new definition is required for our cars. I'm not sure if its the transmission, or because my car is USDM that a new one is required, but it will be made nonetheless! http://www.romraider.com/forum/viewtopic.php?f=8&t=6631&p=63391#p63391 It's too bad you need a ROM definition of your own, but they'll get it done over at ROMRAIDERS, good guys over there! I got playing with this again last night, and it worked with no issues! No idea what changed, but I didn't have any of the problems I was having last time! I had to rename the ROM files with a .bin at the end, but other wise it went well. Got some datalogs and sent them off to the tuner for tweaking. Biggest difference I felt was the throttle response, obviously more linear and less bottom heavy. I'm pretty tired, so let me try the car out for a bit and I'll see if I can tell the difference otherwise. I did a few WOT pulls and it felt smoother up top, but hard to tell without repeated testing, lol. Unfortunately that doesn't make up any part of my commute, lol. Link to comment Share on other sites More sharing options...
nastorino Posted October 15, 2010 Share Posted October 15, 2010 my 3.0R is an 09, still teh vagcom cable or no? Link to comment Share on other sites More sharing options...
burnout8488 Posted October 15, 2010 Share Posted October 15, 2010 Tactrix for you my friend. Link to comment Share on other sites More sharing options...
burnout8488 Posted October 19, 2010 Share Posted October 19, 2010 A definition has been posted for the USDM 2005 2.5i MT/AT! http://www.romraider.com/forum/viewtopic.php?f=34&t=6645 Let the tuning begin! Link to comment Share on other sites More sharing options...
IanB Posted October 19, 2010 Share Posted October 19, 2010 A definition has been posted for the USDM 2005 2.5i MT/AT! http://www.romraider.com/forum/viewtopic.php?f=34&t=6645 Let the tuning begin! That was fast! Are you going to be tuning yourself? After spending some time driving on the 1st revision of my tune, it is definitely stronger and smoother in the higher RPM's, but that's the biggest difference for me so far. Waiting on my 2nd revision now. Gotta get this done before snow flies, knock counts will be totally different when there's any slip added to the equation. Link to comment Share on other sites More sharing options...
burnout8488 Posted October 19, 2010 Share Posted October 19, 2010 I just e-mailed infamous1, gonna get some more details on a GB for us N/A'ers. I wish I could tune myself... maybe I'll screw around with my idle speed for kicks Your results make me optimistic I'll be very happy when this is complete Link to comment Share on other sites More sharing options...
sulk Posted October 19, 2010 Share Posted October 19, 2010 Ian did you get a tune form infamous? Also burnout, I guess once you hear back from infamous, you should make a post in the NA section, because I wouldn't be surprised if theres a lot of NAs who would want a tune. If anything just to fix the DBW unresponsiveness. I know I happened to check this thread by accident, not sure if anyone else would check the tuning section. -sigh- I'm still waiting patiently for my cable to come in. Link to comment Share on other sites More sharing options...
IanB Posted October 19, 2010 Share Posted October 19, 2010 Ian did you get a tune form infamous? Also burnout, I guess once you hear back from infamous, you should make a post in the NA section, because I wouldn't be surprised if theres a lot of NAs who would want a tune. If anything just to fix the DBW unresponsiveness. I know I happened to check this thread by accident, not sure if anyone else would check the tuning section. -sigh- I'm still waiting patiently for my cable to come in. Nope, I'm getting tuned by Ron and Mikey at Phat Botti Tuning, came across a thread on NASIOC by chance, and jumped in. Didn't really look at any other tuners before making the plunge, hope that wasn't a mistake on my part, lol. So far the delays have been on my end, and in getting the ROM defined so I could get started. Link to comment Share on other sites More sharing options...
2005legacy2.5i Posted October 20, 2010 Author Share Posted October 20, 2010 What is my issue? here are my logs using v 1.29 [00:19:59.218] Version 1.29.906 [00:19:59.234] 8 memory models read. [00:19:59.531] Unable to find parent metadata SM5236 [00:19:59.531] ROM metadata models SM5237.xml is invalid. [00:20:11.281] ROM metadata models 2005Legacy25i-E2ZJ173B_v1.xml is invalid. [00:20:14.953] 350 ROM metadata models read. [00:20:14.953] checksum module "subarudbw" loaded. [00:20:14.953] flashing tool "wrx02" loaded. [00:20:14.953] flashing tool "wrx04" loaded. [00:20:14.953] flashing tool "sti04" loaded. [00:20:14.953] flashing tool "sti05" loaded. [00:20:14.953] flashing tool "mitsukernel" loaded. [00:20:14.953] flashing tool "mitsukernelocp" loaded. [00:20:14.953] flashing tool "mitsubootloader" loaded. [00:21:23.578] ssm2_init [00:21:23.734] ECU ID is 2F 12 0A 42 06 [00:21:23.734] ssm2_cmd_0x81 [00:21:23.781] ssm2_cmd_0x83 [00:21:23.828] denso challenge-response [00:21:23.875] challenge is F9 65 09 7A [00:21:23.875] response is 0D E6 2D 38 [00:21:23.921] ssm2_cmd_0x10 [00:21:24.296] validating denso kernel ram area addr: FFFF6000 len: 0D98 [00:21:52.406] ssm2_init [00:21:52.562] ECU ID is 2F 12 0A 42 06 [00:21:52.562] ssm2_cmd_0x81 [00:21:52.609] ssm2_cmd_0x83 [00:21:52.656] denso challenge-response [00:21:52.703] challenge is 41 ED 8E FB [00:21:52.703] response is 00 2E 93 DA [00:21:52.750] ssm2_cmd_0x10 [00:21:53.125] validating denso kernel ram area addr: FFFF6000 len: 0D98 [00:23:00.640] ssm2_init [00:23:00.796] ECU ID is 2F 12 0A 42 06 [00:23:00.796] ssm2_cmd_0x81 [00:23:00.843] ssm2_cmd_0x83 [00:23:00.890] denso challenge-response [00:23:00.937] challenge is 84 F5 FC 0D [00:23:00.937] response is 00 2E 66 39 [00:23:00.984] ssm2_cmd_0x10 [00:23:01.359] validating denso kernel ram area addr: FFFF6000 len: 0D98 [00:23:28.687] ssm2_init [00:23:28.843] ECU ID is 2F 12 0A 42 06 [00:23:28.843] ssm2_cmd_0x81 [00:23:28.890] ssm2_cmd_0x83 [00:23:28.937] denso challenge-response [00:23:28.984] challenge is 13 3A A0 D2 [00:23:28.984] response is 00 2A CB 47 [00:23:29.031] ssm2_cmd_0x10 [00:23:29.406] validating denso kernel ram area addr: FFFF6000 len: 0D98 thanks dennis Link to comment Share on other sites More sharing options...
IanB Posted October 20, 2010 Share Posted October 20, 2010 What is my issue? here are my logs using v 1.29 [00:19:59.218] Version 1.29.906 [00:19:59.234] 8 memory models read. [00:19:59.531] Unable to find parent metadata SM5236 [00:19:59.531] ROM metadata models SM5237.xml is invalid. [00:20:11.281] ROM metadata models 2005Legacy25i-E2ZJ173B_v1.xml is invalid. [00:20:14.953] 350 ROM metadata models read. [00:20:14.953] checksum module "subarudbw" loaded. [00:20:14.953] flashing tool "wrx02" loaded. [00:20:14.953] flashing tool "wrx04" loaded. [00:20:14.953] flashing tool "sti04" loaded. [00:20:14.953] flashing tool "sti05" loaded. [00:20:14.953] flashing tool "mitsukernel" loaded. [00:20:14.953] flashing tool "mitsukernelocp" loaded. [00:20:14.953] flashing tool "mitsubootloader" loaded. [00:21:23.578] ssm2_init [00:21:23.734] ECU ID is 2F 12 0A 42 06 [00:21:23.734] ssm2_cmd_0x81 [00:21:23.781] ssm2_cmd_0x83 [00:21:23.828] denso challenge-response [00:21:23.875] challenge is F9 65 09 7A [00:21:23.875] response is 0D E6 2D 38 [00:21:23.921] ssm2_cmd_0x10 [00:21:24.296] validating denso kernel ram area addr: FFFF6000 len: 0D98 [00:21:52.406] ssm2_init [00:21:52.562] ECU ID is 2F 12 0A 42 06 [00:21:52.562] ssm2_cmd_0x81 [00:21:52.609] ssm2_cmd_0x83 [00:21:52.656] denso challenge-response [00:21:52.703] challenge is 41 ED 8E FB [00:21:52.703] response is 00 2E 93 DA [00:21:52.750] ssm2_cmd_0x10 [00:21:53.125] validating denso kernel ram area addr: FFFF6000 len: 0D98 [00:23:00.640] ssm2_init [00:23:00.796] ECU ID is 2F 12 0A 42 06 [00:23:00.796] ssm2_cmd_0x81 [00:23:00.843] ssm2_cmd_0x83 [00:23:00.890] denso challenge-response [00:23:00.937] challenge is 84 F5 FC 0D [00:23:00.937] response is 00 2E 66 39 [00:23:00.984] ssm2_cmd_0x10 [00:23:01.359] validating denso kernel ram area addr: FFFF6000 len: 0D98 [00:23:28.687] ssm2_init [00:23:28.843] ECU ID is 2F 12 0A 42 06 [00:23:28.843] ssm2_cmd_0x81 [00:23:28.890] ssm2_cmd_0x83 [00:23:28.937] denso challenge-response [00:23:28.984] challenge is 13 3A A0 D2 [00:23:28.984] response is 00 2A CB 47 [00:23:29.031] ssm2_cmd_0x10 [00:23:29.406] validating denso kernel ram area addr: FFFF6000 len: 0D98 thanks dennis I still have no idea how to read the logs, but I have a few questions and a few tips to try out: -what operating system are you using? You have to install the driver in administrator status for certian versions of windows) -what driver did you use for the cable? -have you changed the baud rate for the cable to 4800 to match your ecu's output? How I got it to work was: -plug cable into car and laptop -turn on ignition to accesory mode, or start car -turn on laptop, make sure VAGCOM cable is plugged into the same port as when I installed the drivers -start ROMRAIDER software, make sure it's set to the correct COM port (you can find this info in the hardware properties in the device manager screen) Hopefully this helps some. Link to comment Share on other sites More sharing options...
burnout8488 Posted October 20, 2010 Share Posted October 20, 2010 [00:20:11.281] ROM metadata models 2005Legacy25i-E2ZJ173B_v1.xml is invalid. First of all, you put the RR def into ECUFlash. Take that file out. You should point ECUFlash to use "E2ZJ101B.xml," the one posted on IanB's RomRaider thread. Here's that: http://www.romraider.com/forum/viewtopic.php?f=34&t=6565 You may need to use ECUFlash 1.30 or 1.31. Try 1.30 first and see how it goes. http://evoecu.logic.net/mirror/ecuflash/releases/ Link to comment Share on other sites More sharing options...
burnout8488 Posted October 20, 2010 Share Posted October 20, 2010 I haven't received a response from Infamous1 yet, but I'll post here when it happens. Maybe he'll see this. Link to comment Share on other sites More sharing options...
burnout8488 Posted October 21, 2010 Share Posted October 21, 2010 "The groupbuy could be setup for current and future tunes. Pricing would be one set price for 2 or 20 individuals. Regular tuning rate is $150, with a groupbuy I could do $125 each." Need one more please! Link to comment Share on other sites More sharing options...
custom_junky Posted October 21, 2010 Share Posted October 21, 2010 still waiting on the cable Link to comment Share on other sites More sharing options...
burnout8488 Posted October 21, 2010 Share Posted October 21, 2010 h8 dealextreme. Link to comment Share on other sites More sharing options...
sulk Posted October 22, 2010 Share Posted October 22, 2010 I'd be down too, just waiting for the cable to come. dealextreme is always so slows. Do you know the cost of a retune afterwards if we change things? is it like 20$? Link to comment Share on other sites More sharing options...
burnout8488 Posted October 22, 2010 Share Posted October 22, 2010 Phatbotti tuning has a GB starting in their thread at NASIOC for $100 a tune... I might jump on that... I think infamous1 does 6 or 7 retunes for free, as long as the parts don't change. If you add mods, I'm assuming he'll charge a fee. Not sure if that fee is listed though. Link to comment Share on other sites More sharing options...
burnout8488 Posted October 23, 2010 Share Posted October 23, 2010 Does infamous1 do anything different than phatbotti tuning? If he can alter more values and produce a higher quality tune, I'd definitely throw him the extra $25 dollars. If they both tune the same parameters, I'll have a tougher time justifying it. Link to comment Share on other sites More sharing options...
sulk Posted October 24, 2010 Share Posted October 24, 2010 Only reason I'm kinda leaning towards phat tune is that he's already tuned a whole bunch of NAs, so maybe he knows more about tuning NAs? I have no idea, but I would think it would make a small difference.. Link to comment Share on other sites More sharing options...
IanB Posted October 25, 2010 Share Posted October 25, 2010 2nd revision in my inbox this morning! Can't wait to try it out! Link to comment Share on other sites More sharing options...
burnout8488 Posted October 25, 2010 Share Posted October 25, 2010 Let us know I love this cable. I was fiddling around with my rev limit and idle speed just to have something to do. Raised my limit to 6400 (Don't bother, the power levels out and there's no reason for the increase) and smiled because the reflash actually worked Link to comment Share on other sites More sharing options...
IanB Posted October 26, 2010 Share Posted October 26, 2010 Let us know I love this cable. I was fiddling around with my rev limit and idle speed just to have something to do. Raised my limit to 6400 (Don't bother, the power levels out and there's no reason for the increase) and smiled because the reflash actually worked I basically need someone to ride shotgun when I try out a new revision, if my knock counts are out of control I need to know then and there, and it's just not safe to watch the laptop and drive at the same time. I prefer that someone to be someone I trust with this kind of thing, lol. That means it will be Thursday night before I'll get a chance to try it out, but I'll update once I have. Link to comment Share on other sites More sharing options...
sulk Posted October 26, 2010 Share Posted October 26, 2010 -siiiiiiiiiiiggggghhh- I want my cable to be here, so I can spend my textbook grant money on a tune : > I needa stop checking lgt so often, lol Link to comment Share on other sites More sharing options...
custom_junky Posted October 26, 2010 Share Posted October 26, 2010 is there a version of romraider, or any other real time logger that can used on an andriod phone? i have a windhsield mounted phone holder that i use for GPS navigation that i can use to watch for knocking while driving without diverting my eyes from the road Link to comment Share on other sites More sharing options...
