ERZ Catted DP
istealfrombums
  • Replies 549
  • Created
  • Last Reply
  • 2 weeks later...
remember to keep the bracket off the STOCK DOWNPIPE or ull be kickin urself in the a$$. i had to go back to the shop i had do my work and retrieve it. save urself the trouble broseph...and hell ya stage 2 is where its at!
Do I need to get the 3" to 2.5 adapter to get the CNT DP installed with stock exhaust ? if yes, what's recommended source for the adapter ?
2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K
2007 B9 Tribeca Limited DGM - 272K
SOLD - 2005 OB Limited 5 MT Silver - 245K
SOLD - 2010 OB 6 MT Silver - 205K
thanks sprank, appreciate the info. Should've asked the question before I put the order for DP in. Will be ordering the adapter tonight !
You can get a 3 inch to 2.5 inch exhaust adapter Subimod makes one also.
ordered one from you and already got the tracking #. Excellent service, thanks again !
  • 2 weeks later...
coming soon CNT Racing External Wastegate Up Pipe w/ Dump Tube 38mm and 44mm
Fits 05-09 Legacy GT
here are the specs
fully construction of T-304 stainless ,Flange , piping, flex pipe all stainless . 2mm piping diameter construction with massive 1/2 stainless steel flange.
OEM gasket are not included (you will need to purchase new gasket)
http://www.cntracing.com/v/vspfiles/photos/Up-38MM-2.jpg
  • 2 months later...
Finally getting the ERZ/CNT catted downpipe. Got a few questions.
1) Where's the best deal on these right now? Any of the vendors running specials or coupon codes?
2) Based on these crappy pictures I took with my cell phone, can anyone tell me if that is the stock DP on my car? Or do I have to go and pull the heat shields (notice in pictures 4 & 5 they are welded to the DP). Reason I ask is that there is an aftermarket cat-back exhaust & aftermarket rear sway bar. So I want to make sure there isnt already an aftermarket DP on there.
3) Presumably I have to re-use the stock heat shields. I guess I have to grind those welds off. Does that mean I've got to tack weld this to the new DP?
4) The exhaust is a Megan. It has 3" piping. The cat is stock (I think), and has 2.5" piping (I think - see 7th pic for cat-exhaust joint picture). Is that ok to have the stock cat sandwiched between an aftermarket DP & cat-back? Or would it be hugely beneficial to get a cat w/ 3" piping (assuming such a thing exists and that I can afford it and that it would pass emissions in PA!).
Thanks everyone!
- Justin
ME, LOL. Catted $300 PayPal and delivered, Catless $180 PayPal and delivered. You just missed my sale by a few days. Still a great price though. if you get qouted lower, I can match price.
That is Stock.
No. You have it all wrong. No heatshields are re-used for the DP. You re-use the turbo heatshield. It is held on my bolts, not welds.
You are fine if it is not leaking. The CNT DP is 3" so it will mate to your CBE perfectly. I am not 100% certain of PA inspections and smog laws.
Thanks everyone!
- Justin
-Mike
