markyh Posted June 26, 2013 Share Posted June 26, 2013 Isn't it a little tight to get T-Bolt clamps on there? Link to comment Share on other sites More sharing options...
ssbtech Posted September 17, 2014 Share Posted September 17, 2014 How precisely does the TB hose need to line up on the TB? I installed the TB hose onto the TMIC first then slid it onto the TB. It seemed to be lined up just right to slide on without any fuss. I tightened up the clamps but it still seems to be leaking air from somewhere around the TB. I have removed the donut from the TB end of the hose a few months ago because it was in rough shape and was causing a leak. Link to comment Share on other sites More sharing options...
Mike07LGT Posted May 15, 2016 Share Posted May 15, 2016 Bumping this thread as my car started to make this noise today and the first thing I said was it sounds like a balloon letting air out... Google searched and came acrossed this thread. I checked everything and so far nothing seems out of place or loose. Hopefully it's a simple fix! Car runs fine just makes this crazy noise when building boost 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted May 16, 2016 Share Posted May 16, 2016 You may want to think about doing a vacuum/boost leak test. Do you know how to do that ? Are you still running the OEM tmic ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
drunkinmonk Posted May 29, 2016 Share Posted May 29, 2016 Is there another better aftermarket fitting one? I'm in need of a new one mine did the same thing with a torn inner boot lining. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
SBT Posted June 2, 2016 Share Posted June 2, 2016 Are you still using OEM TMIC. AVO fits fine on those. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 2, 2016 Share Posted June 2, 2016 I pulled the boots off the end of my OEM hose and used t-bolt clamps to keep it and my inlet in place. Never a issue since. With the slight amount of blow by its a matter of time until they start to slip off with the rubber boots in place. I had to fit the hose with the t-bolt loose and get very articulate with the 10mm flex drive to fit it perfectly as the its a bit a process to ensure it seats against the TMIC oulet and the TB inlet flush. Link to comment Share on other sites More sharing options...
SBT Posted June 2, 2016 Share Posted June 2, 2016 Anyone using hairspray as a slip-deterrent? Works...well. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
