m sprank Posted April 14, 2010 Share Posted April 14, 2010 only 1 way to find out, lol. Link to comment Share on other sites More sharing options...
Leonardo Posted April 14, 2010 Share Posted April 14, 2010 no because removing the TMIC will move it out of place. and I'm still tracking a leak that don't apear to be from there. Link to comment Share on other sites More sharing options...
atc5 Posted April 14, 2010 Share Posted April 14, 2010 dude, get in there and loosen the bolts on the turbo side a little bit and remove the tb hose, reposition, re-clamp, and you should be good to go. Link to comment Share on other sites More sharing options...
Leonardo Posted April 14, 2010 Share Posted April 14, 2010 Oh, I know. I just think my leak can be from somewhere else. I would like it to be just his but I see it all in place Link to comment Share on other sites More sharing options...
TacitBlue Posted April 19, 2010 Share Posted April 19, 2010 I think the stocker TG hose is just fine and that the AVO hose is probably just another part put on the market designed to do nothing other than make money for the vendor(s). I've been running over 18psi on my stock hose without issue... Well, I forgot to install a t-bolt clamp on it when I did my engine work, and the hose popped off the other day because a worm gear clamp, apparently, isn't strong enough for my boost! I'm building boost while turning onto a deserted back country road.... care is accellerating, then.... Boom!!!! LOL Now that its t-bolted, it hasn't moved so much as 1mm from its position. Link to comment Share on other sites More sharing options...
Leonardo Posted April 19, 2010 Share Posted April 19, 2010 well, my hose is in two parts as opposed as the one piece construction of the AVO and I can't keep the end sleeve on when trying to re-install the TMIC. Link to comment Share on other sites More sharing options...
m sprank Posted April 19, 2010 Share Posted April 19, 2010 The end sleeve is not used with the AVO TMIC. The sleeve must be removed for the AVO to fit properly. Link to comment Share on other sites More sharing options...
Leonardo Posted April 19, 2010 Share Posted April 19, 2010 but not on my OEM TMIC!! Link to comment Share on other sites More sharing options...
m sprank Posted April 19, 2010 Share Posted April 19, 2010 I must have misread your post. My bad. Yes the OEM needs the sleeve, lol. Link to comment Share on other sites More sharing options...
mightyS Posted May 28, 2010 Share Posted May 28, 2010 My throttle body hose came off so I'll need to buy some t-bolt clamps to hold it on. How wide is the hose? 3 inches? Link to comment Share on other sites More sharing options...
jaxx4k Posted February 2, 2011 Share Posted February 2, 2011 The AVO hose is a bit longer than stock, which makes it a bit easier to position the TMIC. HUmm.... is it worth it for $59 buxx... what 'inner donut'? You mean in the acctual stock throttle body hose there is a donut? Confused... There is a rubber boot that fits over the end. It is removable. I I had a boost leak and it came from the stock throttle body hose. It has an inner sleeve that pushed out. It held for about 6 months at 17.5 lbs of boost before failing. The end of the tube also looks expanded. It almost looks designed to fail at higher boost. I now have an AVO hose. is this donut on throttle body side or turbo inlet side?? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted February 2, 2011 Share Posted February 2, 2011 If you have an aftermarket intercooler, most instructions tell you to remove the rubber donut. If you have a stock one, you can still remove these off both ends. I ran my stock with and without with no issues. If you have an aftermarket intercooler, either Perrin or AVO. Get the AVO hose. It is worth the 59 bucks. Trust me. Only thing you need to do with the AVO is lube it with some oil a bit while installing it. It is a tight fit but once it is on you will never have a leak again. After its been on a while and sorta gets formed a bit. Taking on and off an aftermarket intercooler is cake. Link to comment Share on other sites More sharing options...
underpowerd Posted February 5, 2011 Share Posted February 5, 2011 My throttle body hose came off so I'll need to buy some t-bolt clamps to hold it on. How wide is the hose? 3 inches? a range that includes 2.75+ should be about right. if you want to really slam dunk it, consider using these clamps instead: http://preracing.com/index.php/hose-clamps-c-53_341_342 a bit pricier, but these put t-bolts to shame in every way. this is where i got mine years back when sourcing them was difficult, but you've got to buy into a bag. http://www.topperformanceparts.com/index.html?&Vl=6&Tp=2 Link to comment Share on other sites More sharing options...
MDKSDMF Posted February 7, 2011 Share Posted February 7, 2011 ya ive used the AVO tb hose with my IPR tmic and havent had any issues regarding popping off under boost even with regular clamps. i mean i used new ones but didnt have to buy the crazy tbolt ones. they couldnt hurt but on my stock VF40 @ stage 2 my hose hasnt budged after various WOT pulls. The stock seemed like no matter what i did it would not stay on once i pulled it so i went to AVO Link to comment Share on other sites More sharing options...
ashdoggy Posted February 7, 2011 Share Posted February 7, 2011 If replacing the tmic and going stage 3, which hoses should I buy? Other than the AVO throttle body hose. Link to comment Share on other sites More sharing options...
jaxx4k Posted February 8, 2011 Share Posted February 8, 2011 AVO- hose on back order.. crapp.. and T-bolt clamps works fine don't need those fancy once, held 23psi solid on in my lude back then w/out fail. Link to comment Share on other sites More sharing options...
compsurge Posted February 9, 2011 Share Posted February 9, 2011 I think this is what's up with my IPR. I can hear a boost leak. I was starting to think my engine was bad (knock correction at low load -12°), but I changed my mind after I listed ultra-carefully. I think I merely exchanged one boost leak for another (OEM TMIC blew tabs out on left side, now it's leaking on the right ) Edit: Just pulled mine. Stock end was chewed up and had a hole in it from the hose clamp. Hose clamp is crap (and hardware stores are closed at 11PM). I slapped it all back together and tightened it down as good I could and what do you know... no more pulled timing -granted I only drove it down the street after idling it for a couple mins to check for leaks. Thanks all! This seriously this has been bugging me ever since my install! Link to comment Share on other sites More sharing options...
jaxx4k Posted February 9, 2011 Share Posted February 9, 2011 is drivable im sure, just can't boost....I've sent out a APB to all the friends to find this hose & AVO said back order or 1-2 months. and no one else makes it. Link to comment Share on other sites More sharing options...
compsurge Posted February 9, 2011 Share Posted February 9, 2011 m sprank said his order is coming in 60-120 days as well I'm going to have to solve this with a huge hose clamp for now lol. Link to comment Share on other sites More sharing options...
jaxx4k Posted February 9, 2011 Share Posted February 9, 2011 ^^ i put one of these T-bolt over the stock hose it'll hold it in it's place. http://www.smallparts.com/dixon-valve-stbc350-stainless-steel/dp/B0037QFLUI?ref_=goo_pf_B0037QFLUI Link to comment Share on other sites More sharing options...
compsurge Posted February 9, 2011 Share Posted February 9, 2011 ^^ Thanks for saving me the searching. I'll have to order. I went to lowes and picked up a couple different sizes of regular (since I kind of emergency need it). My stocker is stripped and I think it blew out today. Car was running great this morning and I noticed only 1.4° timing pulled. Now it's back to the same old crap of pulling 11.8° I really hope this fixes it. Link to comment Share on other sites More sharing options...
MDKSDMF Posted February 10, 2011 Share Posted February 10, 2011 I think I read on some thread that vibrant makes a tb hose too. idk worth a look . good luck in ur search. I bought avo's last tb hose from their site a month ago..surprised their still on back order. Link to comment Share on other sites More sharing options...
rock2534 Posted February 11, 2011 Share Posted February 11, 2011 So what is the easiest way to get your hands on the tb hose, where it connects to the IC? Can/should anything be removed, or just try and weasel your hands in there the best you can? Link to comment Share on other sites More sharing options...
MDKSDMF Posted February 11, 2011 Share Posted February 11, 2011 take the intercooler off..disconect hoses from diverter valve but leave it on the TMIC. you can then get access to it. Link to comment Share on other sites More sharing options...
rock2534 Posted February 11, 2011 Share Posted February 11, 2011 take the intercooler off..disconect hoses from diverter valve but leave it on the TMIC. you can then get access to it. thanks man, are you referring to getting the hose on the tb itself? I actually mean getting the tb hose on to the IC outlet. I would assume the IC would need to be on the car so the tb hose could reach it.(??, I could be wrong). I can reach the top of the hose, but it seems tough getting your hands underneath it to get a good grip with the other crap that runs on top of it. You can tell I am quite the mechanic! Link to comment Share on other sites More sharing options...
