HAMMER DOWN Posted December 29, 2010 Author Share Posted December 29, 2010 Does anyone know if the neutral safety switch parameters can be changed with an Accessport. The reason being - When I swapped a 6 speed for the 5, I left the 6 speed neutral safety switch in the transmission. I know the grounds are opposite for the 5 and 6 speed. It would be nice to fix this via computer rather than via my garage floor. I also read on another forum that the Neutral Safety Switch effects the avcs. (no avcs in neutral) Is this true? If anyone definitively know the answer let me know. Sorry you have to use the 5MT's NSS (neutral safety switch). Get your wrenches out. Your avcs will work fine with 6MT's NSS. The 6MT's does work, BUT it will only let your cruise control SET in NEUTRAL. Which won't do you any good. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
integroid Posted December 29, 2010 Share Posted December 29, 2010 What hammerdown said. I drove around for a few weeks witht he wrong NSS in and only got a CEL. Link to comment Share on other sites More sharing options...
KCwagon Posted December 29, 2010 Share Posted December 29, 2010 Sorry you have to use the 5MT's NSS (neutral safety switch). Get your wrenches out. Your avcs will work fine with 6MT's NSS. The 6MT's does work, BUT it will only let your cruise control SET in NEUTRAL. Which won't do you any good. Mike Thanks, I am in the middle of a re-tune and I did not want it to effect the end result. Is the length of the harness of each nss the same? I am assuming the plugs are identical. Link to comment Share on other sites More sharing options...
NSFW Posted December 29, 2010 Share Posted December 29, 2010 The lengths are similar enough that you won't have to do any cutting or soldering, if that's what you're wondering. It's a very straightforward swap - at least if you have the transmissions on a bench in front of you. With the trans in the car, I bet the only hard part is getting your hands onto the switches and connectors. Link to comment Share on other sites More sharing options...
06gtleg Posted December 29, 2010 Share Posted December 29, 2010 Does anyone if 04 sti peddle assembly will bolt onto my legacy gt 5EAT? Link to comment Share on other sites More sharing options...
bsax14 Posted December 29, 2010 Share Posted December 29, 2010 anybody know exactly which parts of the spec B shifter linkage i will need to center the shifter? i finished my swap (minus the dccd). The shifter sits slightly forward and after spending so much time and money on this would like to have it centered. Also...I have borla exhaust, and i only have about 1/2" of clearance between the driveshaft and the resonator in the exhaust. Can i change the hangers or should i have an exhaust shop modify the pipes a little? any input appreciated. thanks. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted December 29, 2010 Author Share Posted December 29, 2010 anybody know exactly which parts of the spec B shifter linkage i will need to center the shifter? i finished my swap (minus the dccd). The shifter sits slightly forward and after spending so much time and money on this would like to have it centered. Also...I have borla exhaust, and i only have about 1/2" of clearance between the driveshaft and the resonator in the exhaust. Can i change the hangers or should i have an exhaust shop modify the pipes a little? any input appreciated. thanks. You need Spec. B shifting rods or have the lengthen them 3/8". Like I did. http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/1215071541.jpghttp://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/1215071544.jpghttp://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/1215071546.jpg Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
KCwagon Posted December 29, 2010 Share Posted December 29, 2010 The lengths are similar enough that you won't have to do any cutting or soldering, if that's what you're wondering. It's a very straightforward swap - at least if you have the transmissions on a bench in front of you. With the trans in the car, I bet the only hard part is getting your hands onto the switches and connectors. Oh the transmission is very much in the car. The six speed has to be dropped to get to the NSS on top. I also found out from a Subaru tech that it is a good idea to have the correct NSS in the car so the ecu knows what gear you are in. Anyway, thanks for the info, I am trying eliminate all the surprises I can. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted December 29, 2010 Author Share Posted December 29, 2010 ^^^ no you don't have yo drop the transmission. It's APITA, but it can be done. I did it 2hrs. with mine with the transmission in the car. If you closer. I would have you come over & help you do it. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
KCwagon Posted December 30, 2010 Share Posted December 30, 2010 (edited) Can you remove the rear crossmember and lower it a bit? How did you do it? Edited December 30, 2010 by KCwagon Link to comment Share on other sites More sharing options...
06gtleg Posted December 30, 2010 Share Posted December 30, 2010 Does anyone if 04 sti peddle assembly will bolt onto my legacy gt 5EAT? I called subaru parts department but they didnt know either. Parts "with a welder you can make anything fit" lol Does anyone know the answer to this? Link to comment Share on other sites More sharing options...
KCwagon Posted December 30, 2010 Share Posted December 30, 2010 I called subaru parts department but they didnt know either. Parts "with a welder you can make anything fit" lol Does anyone know the answer to this? It is from an impreza model so it will likely not just bolt in to a newer Legacy body style. What are you planning to do for a clutch resevoir? You may want to source a legacy pedal assembly with all the correct clutch lines and clutch resevoir. I would call Millenium Auto in Michigan. They have a ton of salvage Subaru parts. Even if you can get a good deal on the STI assembly you may end up spending more money than finding the correct parts if you include your time and anxiety in the cost. Link to comment Share on other sites More sharing options...
SBT Posted December 30, 2010 Share Posted December 30, 2010 ^ and changing out the ECU and all the electronic-related "stuff". - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted December 30, 2010 Author Share Posted December 30, 2010 (edited) Can you remove the rear crossmember and lower it a bit? How did you do it? Ya, put it up on my lift. Remove the heat shield between the exhaust & the drive shaft. Unbolt the exhaust at the spring bolt. Support tranny with a jack. Unbolt tanny's cross tie. Let jack down. Take 4' pipe & pray tranny toward PS & wedge a 2"x4"x4" between the side of the tunnel & the tranny. Now you should be able to get to the NSS. After I got mine done. It dawn on me. If you removed the TMIC & the Dog Bone underneath & depending on the size of your hands & arms. You mite not have to pray & block the tranny over. I told you IPITA. Mike Edited December 30, 2010 by HAMMER DOWN Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
06gtleg Posted December 30, 2010 Share Posted December 30, 2010 I have a friend that welds for a living so if it doesnt fit he can make it fit. Thanks Link to comment Share on other sites More sharing options...
KCwagon Posted December 30, 2010 Share Posted December 30, 2010 I have a friend that welds for a living so if it doesnt fit he can make it fit. Thanks Thats cool. Good luck with the project. Link to comment Share on other sites More sharing options...
06gtleg Posted December 30, 2010 Share Posted December 30, 2010 Thats cool. Good luck with the project. Thanks im going to need it lol. Link to comment Share on other sites More sharing options...
08lgt317hp Posted January 3, 2011 Share Posted January 3, 2011 any body use a 5 speed clutch on a 6 speed? and if you use a 07 sti trans what do you need to use so the stock axels work? Link to comment Share on other sites More sharing options...
wrxtacy2003 Posted January 4, 2011 Share Posted January 4, 2011 If by 5spd you mean a wrx's 5sp clutch, then yes it will work in the 6spd, you just need to use the 5mt flywheel too. As for the 07 trans with 05 legacy gt axles, they work just fine. I just installed a 07 6spd two days ago in my 05 LGT, and kept all 4 legacy axles. DK Link to comment Share on other sites More sharing options...
NSFW Posted January 5, 2011 Share Posted January 5, 2011 (edited) First posted updated with the 02-03 WRX diff option. Thank wrxtacy2003 for that information! Edited January 5, 2011 by NSFW Link to comment Share on other sites More sharing options...
NSFW Posted January 5, 2011 Share Posted January 5, 2011 You would have to get 3.90 R/P to match 05 STI tranny. 07-09 LGT 5MT diffs have that ratio (vs. 4.11 on 05-06 5MT). Why does the first post say that an LGT R160 can be used with the 06+ STI 6MT? Don't the 06+ STI 6MTs require 3.54:1 rear diffs? Link to comment Share on other sites More sharing options...
KCwagon Posted January 10, 2011 Share Posted January 10, 2011 Ya, put it up on my lift. Remove the heat shield between the exhaust & the drive shaft. Unbolt the exhaust at the spring bolt. Support tranny with a jack. Unbolt tanny's cross tie. Let jack down. Take 4' pipe & pray tranny toward PS & wedge a 2"x4"x4" between the side of the tunnel & the tranny. Now you should be able to get to the NSS. After I got mine done. It dawn on me. If you removed the TMIC & the Dog Bone underneath & depending on the size of your hands & arms. You mite not have to pray & block the tranny over. I told you IPITA. Mike Just for reference. If you DO need to get to the Neutral Safety Switch or the Reverse Switch on a six speed - removing the dogbone is the cats meow. It lowers the transmission an additional 6" and is enough to get even the biggest paws in there to change the switches. If you have access to a lift I would recommend that for sure. On a lift with air tools you are talking about 30 minutes at most. Remove intercooler, dogbone, heatshield (careful with the o2 sensor), crossmember, lower it gently. Thanks to Mike for the help on this one. Shawn Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted January 11, 2011 Author Share Posted January 11, 2011 No problem, glad to help any time. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
wpgspecb Posted January 13, 2011 Share Posted January 13, 2011 please weigh in.... DCCD or FRONT LSD, what would you choose... or both? Link to comment Share on other sites More sharing options...
SBT Posted January 13, 2011 Share Posted January 13, 2011 If I had the choice, I'd go with the FLSD over a DCCD, especially if I already had an LSCD. But the real question is why not both an LSD and DCCD if you have that opportunity (and a DCCD-capable 6MT). - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
