integroid Posted April 27, 2010 Share Posted April 27, 2010 Does it matter? I thought you could use your R160 rear end with the Spec B tranny? Link to comment Share on other sites More sharing options...
Guest Posted April 27, 2010 Share Posted April 27, 2010 Can someone confirm that the rear diff for an 08 spec B is a 3.54. I have seen conflicting information on this. Subaru and the source of the transmission says 3.54. Yes, the rear diff is 3.545, but there is 1.1:1 reduction in the tranny, so the actual final ratio is 3.9. Link to comment Share on other sites More sharing options...
KCwagon Posted April 28, 2010 Share Posted April 28, 2010 (edited) Thanks. I have a r160 - 3.54 that I will use. Here is what I purchased: 08 Spec B transmission, Spec B shift linkage, Spec B driveshaft, spec B flywheel and clutch, spec B slave cylinder and shift fork. Am I missing anything? Edited April 28, 2010 by KCwagon Link to comment Share on other sites More sharing options...
Guest Posted April 28, 2010 Share Posted April 28, 2010 SpecB/STI flywheel bolts. They are different and you don't want to use the evil Torx Plus bolts from 5MT anyway. You'll need spring for the shift fork and different clutch cylinder hose (buy a SS Goodridge). You will also need the SpecB shifter trim piece and shifter boot, unless you hack the 5-speed boot one to fit. You will be able to connect the rear O2 harness if you reuse part of it from 5-speed (just plugs in, no splicing). Don't forget to transfer over the neutral switch from 5MT (something I did). That should be it. Link to comment Share on other sites More sharing options...
KCwagon Posted April 28, 2010 Share Posted April 28, 2010 Thanks Unclemat. Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted April 28, 2010 Share Posted April 28, 2010 Just purchased an 08 STI tranny, driveshaft, flywheel, shifter, and rear diff. I am using an aftermarket clutch, spec b rear axles. I know I need to use the 5spd nss and reverse switch. Can I use my 5 spd front axles and is there anything else I need that is essential to the install? I'm getting all the little stuff like group n 6 spd mount, sts, ss clutch line and all the little things. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 28, 2010 Author Share Posted April 28, 2010 Just purchased an 08 STI tranny, driveshaft, flywheel, shifter, and rear diff. I am using an aftermarket clutch, spec b rear axles. I know I need to use the 5spd nss and reverse switch. Can I use my 5 spd front axles and is there anything else I need that is essential to the install? I'm getting all the little stuff like group n 6 spd mount, sts, ss clutch line and all the little things. DCCD controller, What I used, My DCCD controller ” Spiider’s” Auto DCCD controller http://i99.photobucket.com/albums/l293/HAMMERDOWNGT/Subaru/0904071237_edited.jpg http://dccdpro.com/?page_id=5 Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
PhilT Posted April 29, 2010 Share Posted April 29, 2010 (edited) I'm going to be getting a 6 speed tranny installed in 2 weeks time at Lachute Performance in Montreal. It's a '04 USDM STi transmission with DCCD. It comes with the stock clutch and flywheel for the '04 STi, but I am wondering if that would be enough to hold 350 whp. Edited May 21, 2010 by PhilT Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 29, 2010 Author Share Posted April 29, 2010 If I remember right. The STi 6MT is rated around 550ft.lbs. of torque. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted April 29, 2010 Share Posted April 29, 2010 Is that to the flywheel or wheels? Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 29, 2010 Author Share Posted April 29, 2010 Don't remember, it's the strongest tranny Subaru makes. In all my research it's the only thing people making 415whp up to 530 whp they didn't change other then the clutch. [ame]www.youtube.com/watch?v=QvyFbcZH-mU[/ame] [ame]www.youtube.com/watch?v=BYgg_kE1VmM[/ame] Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
PhilT Posted May 1, 2010 Share Posted May 1, 2010 So the stock STi clutch is good for how many ft-lbs at the flywheel Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted May 1, 2010 Author Share Posted May 1, 2010 Stock clutch don't know, I guess around 400-450max. Tranny IMO 550 to the wheels. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted May 18, 2010 Share Posted May 18, 2010 I was just informed that the 08 sti tranny that I just bought wont work with out my car!!!!! I was told that the 08 tranny doesnt have a vehicle speed sensor while my car (06) does and thus wont get a speed signal and put the ecu into limp mode and have no speedometer. Can anyone verify this????? I need to know asap!! If so has anyone heard of any solutions to this issue?? Link to comment Share on other sites More sharing options...
Guest Posted May 18, 2010 Share Posted May 18, 2010 I was just informed that the 08 sti tranny that I just bought wont work with out my car!!!!! I was told that the 08 tranny doesnt have a vehicle speed sensor while my car (06) does and thus wont get a speed signal and put the ecu into limp mode and have no speedometer. Can anyone verify this????? I need to know asap!! If so has anyone heard of any solutions to this issue?? Whoever you're listening to - stop now. 05-09 Legacies do not have tranny speed sensor either and take speed info from ABS. 08 STI tranny is perfect for swap (that's what I run). You could have also read this thread (or associated 6MT swap threads). Link to comment Share on other sites More sharing options...
2.5gtbx_44 Posted May 19, 2010 Share Posted May 19, 2010 Thats y it came as such a surprise to me. I did read this thread. All pages and while I did not read about the 06 not having wheel speed sensors I did read about the 08s going in with no problem. Unclemat I thank you for the relieving info. I was already thinking that this swap was a bad idea!! Whoo hoo!!.... Link to comment Share on other sites More sharing options...
CTATV Posted May 19, 2010 Share Posted May 19, 2010 subscribed Link to comment Share on other sites More sharing options...
legacyurabus Posted May 19, 2010 Share Posted May 19, 2010 so whats stronger, 6speed swap or ppg gears for the 5 speed. Link to comment Share on other sites More sharing options...
j255c Posted May 19, 2010 Share Posted May 19, 2010 Id say the 6 speed. The PPG cases may have the stronger gears, but still rely on the factory differentials and transfer case, both which are significantly weaker than the 6speed units stock offerings. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
PhilT Posted May 20, 2010 Share Posted May 20, 2010 Finally had the swap done by Lachute Performance in Montreal. I wish I had done this years ago, it is such a huge improvement in feel over the 5 speed box. Lachute did an excellent job, and customer service is top notch. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
KCwagon Posted May 20, 2010 Share Posted May 20, 2010 The swap is done and I have to say the 6 speed is great. I do have a question about the NSS. My reverse lights work but I have no cruise control. I have read the posts and understand that I need to use the 5 speed NSS. Is there a diagram or clearer description of how to fix this? SpecB/STI flywheel bolts. They are different and you don't want to use the evil Torx Plus bolts from 5MT anyway. You'll need spring for the shift fork and different clutch cylinder hose (buy a SS Goodridge). You will also need the SpecB shifter trim piece and shifter boot, unless you hack the 5-speed boot one to fit. You will be able to connect the rear O2 harness if you reuse part of it from 5-speed (just plugs in, no splicing). Don't forget to transfer over the neutral switch from 5MT (something I did). That should be it. Link to comment Share on other sites More sharing options...
08lgt317hp Posted May 24, 2010 Share Posted May 24, 2010 does any body know where i can get a full spec b swap Link to comment Share on other sites More sharing options...
goneskiian Posted May 25, 2010 Share Posted May 25, 2010 Thank you all for the great information on this! I have read and reread this thread and HD's pioneering install thread, but I have some gearing questions (obviously I didn't re-re-read them! Or take notes ). I know it's likely been answered by unclemat at some point in here but perhaps groff can edit his original post so it's a bit clearer. The section of the original post I'm referring to concerns rear differentials and how they are geared: "2006+ STI 6MT has a 1:1 stepper center differential which allows you to use your Stock R160 on the 07+ cars, if you use an 04-05 STI trans.. the GT 5MT came in 2005-2006 4.11FD 2007-2009 5MT 3.90FD..." So, does this say if one uses a 2006 or newer STi 6MT donor, they can use their stock rear differential ONLY if the LGT it's going into is a 2007 or newer? What would someone need if they were swapping this 2006 or newer STi transmission into a 2005 or 2006 LGT? Also, with regards to the shift linkage and shifter. Would the linkage out of a spec B not have to be modified to fit more centered in the console? Or is everyone (except HD) just not driving with their "ash tray" door open so it doesn't interfere in 3rd and 5th gear? Thanks! Link to comment Share on other sites More sharing options...
KCwagon Posted May 25, 2010 Share Posted May 25, 2010 does any body know where i can get a full spec b swap You might try Millenium automotive in Michigan. I bought a Spec B swap from them recently. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted May 28, 2010 Author Share Posted May 28, 2010 Thank you all for the great information on this! I have read and reread this thread and HD's pioneering install thread, but I have some gearing questions (obviously I didn't re-re-read them! Or take notes ). I know it's likely been answered by unclemat at some point in here but perhaps groff can edit his original post so it's a bit clearer. The section of the original post I'm referring to concerns rear differentials and how they are geared: "2006+ STI 6MT has a 1:1 stepper center differential which allows you to use your Stock R160 on the 07+ cars, if you use an 04-05 STI trans.. the GT 5MT came in 2005-2006 4.11FD 2007-2009 5MT 3.90FD..." So, does this say if one uses a 2006 or newer STi 6MT donor, they can use their stock rear differential ONLY if the LGT it's going into is a 2007 or newer? What would someone need if they were swapping this 2006 or newer STi transmission into a 2005 or 2006 LGT? Also, with regards to the shift linkage and shifter. Would the linkage out of a spec B not have to be modified to fit more centered in the console? Or is everyone (except HD) just not driving with their "ash tray" door open so it doesn't interfere in 3rd and 5th gear? Thanks! Option #1: Transmission Choice: 2007+ LGT Spec B 6MT, 2004, 2005 STI 6MT Rear Differential Choice: 2007+ LGT Spec B R180, 2004+ STI R180, <2004 Legacy or you can use a regeared stock R160 as well with stock LGT rear axles Axles: Front - Stock LGT, Rear - 2007+ Spec B or custom Driveshaft Shop Axles Or fine a 3:90 geared WRX R160 rear end. For shifting linkage more centered in the console, 2 option; 07 Spec.B 6MT shifting linkage or lengthen both STi 6MT shifting rod by 3/8". Like I done. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
