6MT Master Swap Thread
HAMMER DOWN
I'm the second person that's about to blow up If im going to use my 5EAT driveshaft then i can only keep my front half and need to buy a 07 spec.b. rear half?? Wouldnt it be vice versa? I really want to refrain from running to the dealer while doing this.
I think you are bit confused...
You need the driveshaft from a 4-eat or from a Spec B...diff flanges can be changed on the rear end to accomodate.
Half shafts, which may have you confused, are CV's.
Does that clear anything up for you?
  • 2 weeks later...
I have installed 6MT from JDM Legacy instead of 5MT...Now I am thinking about installation of DCCD.
But it could be one problem: gear transfer. Should I change the Legacy's gear transfer to WRX STI's one to install DCCD?
In case with 5MT+DCCD the transfer should be changed (I know this because I done 5MT+DCCD).
this is gear transfer from JDM Legacy...part # 33128-AA190
http://content.foto.mail.ru/mail/alexred2000/Subaru/i-184.jpg
this is gear transfer from JDM WRX STI (GDB)...part ## 33128-AA150, 33128-AA170 and 33128-AA240
http://content.foto.mail.ru/mail/alexred2000/Subaru/i-185.jpg
You need whole tail end case and all gears. Plus your main case doesn't have provision for DCCD wiring. Not sure if it is something you can drill.
Forget it. I swapped Legacy 6MT for STI 6MT. Much easier and cheaper.
  • 1 month later...
  • 2 weeks later...
