pansontw Posted April 7, 2009 Share Posted April 7, 2009 NEED SOME HELP HERE. Bilstein HD purchased 1 week ago from Fred Bean.... I successfully take the bottom nut off, but I am not able to simply unscrew the insert off of the housing. I tried my best to unscrew and even damaged it a bit, but still can not make it out. Have any of U encountered such problem??? or maybe they have changed their design on the strut to forbid taking the insert out of the housing!!!??? Panson Link to comment Share on other sites More sharing options...
Egan Posted April 7, 2009 Share Posted April 7, 2009 NEED SOME HELP HERE. Bilstein HD purchased 1 week ago from Fred Bean.... I successfully take the bottom nut off, but I am not able to simply unscrew the insert off of the housing. I tried my best to unscrew and even damaged it a bit, but still can not make it out. Have any of U encountered such problem??? or maybe they have changed their design on the strut to forbid taking the insert out of the housing!!!??? Panson Make sure you are turning the screw clockwise. One of mine came apart very easily, the other side turned about one turn and then wouldn't budge. Fortunately I hadn't cut the other bumpstop yet and I just buttoned everything back up. I'll live with the reduced travel. Link to comment Share on other sites More sharing options...
pansontw Posted April 7, 2009 Share Posted April 7, 2009 I thought unscrew = counter-clockwise??? Just tried one and get stuck immediately. Link to comment Share on other sites More sharing options...
SBT Posted April 7, 2009 Share Posted April 7, 2009 With the housing (bottom tube) clamped so it can't turn, turn the screw clockwise. Alternatively you might try clamping the srewdriver and use the housing as a force-multiplier, turning the housing counter-clockwise. Use plenty of PB Blaster if the screw (rod) is seized or not turning easily. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
pansontw Posted April 8, 2009 Share Posted April 8, 2009 Got this mod done today. Like Subietonic mentioned, "BP Blaster" is the key..... Make sure U turn "clockwise" in order to "unscrew"..... Thanks Guys Link to comment Share on other sites More sharing options...
jeguzik Posted April 16, 2009 Share Posted April 16, 2009 Installing the Rallitek Springs this weekend, they state about a .9 inch drop with the Spec.B due to the different Top hats. With such a small drop do i NEED to do the bump stop mod on my vehicle?? Please advise. Link to comment Share on other sites More sharing options...
Ryandigi Posted April 16, 2009 Share Posted April 16, 2009 ^I have ralliteks on and I do not think that I hit my stops. I know the fronts dont for sure since it sits so damn high (stock or higher), but the backs might over some rough stuff. I will try to take more notice for you. Link to comment Share on other sites More sharing options...
SBT Posted April 16, 2009 Share Posted April 16, 2009 Installing the Rallitek Springs this weekend, they state about a .9 inch drop with the Spec.B due to the different Top hats. With such a small drop do i NEED to do the bump stop mod on my vehicle?? Please advise. Short answer - Yes. Long answer is that however much strut stroke you're giving up, there's a fraction of the bump stop that should be cut out... Certainly not as much as the slammed drops, but some; probably 1 of the three nodules that make up the bump stop. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
pansontw Posted April 16, 2009 Share Posted April 16, 2009 Help me here please. I recently swap my stock suspension towards Bilstein HD/ ION..... I trim the front bump stop half and I am glad I did so... Now, my rear starts to bump like hell and I am eager to find the rear bump stop to trim but just couldn't find them. Could someone show me or point me where are them??? Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted April 17, 2009 Share Posted April 17, 2009 Not to rain on the parades...BUT..the OEM bump rubber has those progressions in there AND is that long to cushion as it get slams..........this is why we use a FIRMER and SHORTER bump stop on the Impreza's. We use it on the 04-07 front ( inverted) and the 08-09 STI front inverted. By cutting these OEM bump stops sure you gain the travel, but WHEN it hits it has even less protection/cushion than before. What is needed is a FIRMER/SHORTER bump stop. Ask us how we know.... In the picture below is one of our FRONT comparisons of OEM bump rubber vs the FIRMER one we use in the IMPREZA. BTW yes it fits Bilsteins as we use in in the following: Ohlins fixed perch fronts. Prodrive RB320 fronts. 04-07 STI fronts. 08-09 STI fronts. The design, size and specs of the bottom of the inverted shafts are all the same. THE real issue with the Legacy is the obvious lack of travel. So to recap this bump rubber is FIRMER and shorter. Also dont forget when you really need the bump stop its important that it NOT go to far past the middle of the range of the OEM rubber. Ours is about twice as firm as stock and has a different rate in the first progression than in the second. Just a thought. Myles PS. didnt someone a WHILE ago compare the HD next to the SPEC-B and realize that the HD uses shorter shafts? Hence why when you lower on the HD you have less travel by about 1/2 inch? Making the Spec-B Bilsteins the ones to get revalved( what I have done already) to a "SPORT" valve no less. I will search for the thread NOW. DONT PAY ATTENTION TO THE REAR AS ITS FROM THE 08 STI. http://racecompengineering.com/images/bumpstopcompareSM.jpg Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted April 17, 2009 Share Posted April 17, 2009 Help me here please. I recently swap my stock suspension towards Bilstein HD/ ION..... I trim the front bump stop half and I am glad I did so... Now, my rear starts to bump like hell and I am eager to find the rear bump stop to trim but just couldn't find them. Could someone show me or point me where are them??? they are built into the control arm and I trimmed mine years ago..BUT..dont get carried away as you NEEEEED that there. When these cars SLAM into the bump rubber its protecting other suspension parts. I trimmed about 1/4 inch from mine and noticed a difference when I have 2 adults in my rear with a full tank( wow that didnt sound right...). Myles Ps that rear bump rubber looks like a soft rubber pyramid. Link to comment Share on other sites More sharing options...
Mortal2None Posted April 19, 2009 Share Posted April 19, 2009 How much are the improved bump stops and are they in stock? I can't find them on your site so please link them? Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted April 20, 2009 Share Posted April 20, 2009 How much are the improved bump stops and are they in stock? I can't find them on your site so please link them? I will pm you. We are adding them to the site soon. Myles Link to comment Share on other sites More sharing options...
GTTuner Posted April 20, 2009 Share Posted April 20, 2009 I talked to a rep at Bilstein about this bumper inside the strut tube. He stated the HD series is designed for stock springs and the Sport series struts are for lowered cars. He couldn't tell me if the sport series was available for the LGT, but I can't find any listing except for the HD's. Question for RaceComp; Do those bumpers replace the units were cutting or do they just slide over the piston like OE style? Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted April 20, 2009 Share Posted April 20, 2009 Question for RaceComp; Do those bumpers replace the units were cutting or do they just slide over the piston like OE style? The replace the INTERNAL bump stops. Myles Link to comment Share on other sites More sharing options...
LegacyDan Posted April 23, 2009 Share Posted April 23, 2009 would you be able to do the same with the JDM Bilsteins? Have them on mine with Tein Stechs and want to see what difference it will make to my setup Link to comment Share on other sites More sharing options...
SBT Posted April 23, 2009 Share Posted April 23, 2009 http://racecompengineering.com/images/bumpstopcompareSM.jpg Myles, Ready to purchase, but have some questions. WRT the front Bilstein (Spec B or the JDM variants), do your bump stops fit the internal piston rod tightly or is the bump stop bore actually sized for a larger piston rod? Also, when installed, how much clearance between them and wall of the Bilstein's down tube (O.D. to I.D.)? Compared to a cut-down Bilstein bumpstop, how much difference is there between your's and their's. Don't want to get harsher due to the stop, just increase travel with the same/similar stop/feel. Also, getting ready to revalve my Spec Bs (It's right here in San Diego so why not), and was wondering what the ride difference was between stock and the "sport". TIA - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted April 23, 2009 Share Posted April 23, 2009 would you be able to do the same with the JDM Bilsteins? Have them on mine with Tein Stechs and want to see what difference it will make to my setup yep. Myles Link to comment Share on other sites More sharing options...
peteyjr Posted April 23, 2009 Share Posted April 23, 2009 Will this work with other dampers such as Koni's? Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted April 24, 2009 Share Posted April 24, 2009 Will this work with other dampers such as Koni's? nope. only inverted. Koni' are NON inverted. Myles Link to comment Share on other sites More sharing options...
RALLYT-WRX Posted May 18, 2009 Share Posted May 18, 2009 I will be throwing Eibach Springs on my Spec B. Apparently these springs only drop the car about an inch. Would thee springs require trimming of the front and rear bumpstops or will I be good to go without trimming. Link to comment Share on other sites More sharing options...
rs6er Posted May 18, 2009 Share Posted May 18, 2009 With the Ions I have that only lowered an inch, I didn't need to do this. But spring rates vary, so I can't really advise you. I'd try it first without modifying them. Link to comment Share on other sites More sharing options...
RALLYT-WRX Posted May 18, 2009 Share Posted May 18, 2009 With the Ions I have that only lowered an inch, I didn't need to do this. But spring rates vary, so I can't really advise you. I'd try it first without modifying them. That's what I was thinking of doing. If I hit the bump stops I will trim them if not I will leave them alone. Thanks. Link to comment Share on other sites More sharing options...
rs6er Posted May 18, 2009 Share Posted May 18, 2009 One of the vendors is selling shorter bump stops that compensate for the loss (gain?) of density when trimming the stops. I think that's what I would go with. Link to comment Share on other sites More sharing options...
TPLGT Posted June 18, 2009 Share Posted June 18, 2009 SO how do the rears go on? The post on the first page they're on the car? Rehab is for quitters. Link to comment Share on other sites More sharing options...
