jarrod Posted August 27, 2008 Share Posted August 27, 2008 anybody have anyidea why i cant get my cable itself to install. I had it installed and worked fine logging with ecu explorer but I had to reboot my computer and it wont install. I go to control panel add hardware looks for stuff connected but not installed reads my cable is there (COBB2 FU) is what it reads but wont install it even with it going online to find the drivers or if i insert the cd???? Any body have any ideas or even understand what im sayin??? same issue i'm having...good luck Link to comment Share on other sites More sharing options...
Metal2You Posted August 27, 2008 Share Posted August 27, 2008 So there is one driver for the APv2 and a separate driver for the OBDII dongle? EDIT: I think I get it. You connect the AP to the computer via USB to put maps on the AP or update the firmware, but the computer is going to be connected to the dongle via USB when tuning the vehicle. Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted August 27, 2008 Share Posted August 27, 2008 i guess theres a separate driver to connect the obdII dongle/cable to the pc itself. I'm confused though because i had the cable installed fine before for ecu explorer. Now i cant get it to install at all?? Link to comment Share on other sites More sharing options...
Metal2You Posted August 27, 2008 Share Posted August 27, 2008 The FAQ here (http://www.cobbforums.com/forums/showthread.php?t=41519) says to open a regular Cobb OTS map in Tuner Race, save the map to your AP Manager library location, and then load the newly saved -- formerly OTS -- map into your ECU with a reflash. Then you can begin tuning. Link to comment Share on other sites More sharing options...
Metal2You Posted August 27, 2008 Share Posted August 27, 2008 Hey, Kev. Check this out for the dongle driver: http://forums.cobbtuning.com/forums/showthread.php?t=41543 Link to comment Share on other sites More sharing options...
jarrod Posted August 28, 2008 Share Posted August 28, 2008 Hey, Kev. Check this out for the dongle driver: http://forums.cobbtuning.com/forums/showthread.php?t=41543 woo I'm gonna mail you a cookie...cigar or somethin Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted August 28, 2008 Share Posted August 28, 2008 Hey, Kev. Check this out for the dongle driver: http://forums.cobbtuning.com/forums/showthread.php?t=41543 thanks Metal2you:spin: cable is now installed gonna have to try the map thing tomorrow was at the track all night...(mods cobb ots stage 2 93LC xo2 dp hks up stock catback spec stage II+ clutch Spec LWF perrin sts GFB bov and stock tmic still on (waiting for accesstunner race for my front mount;)) 1/8 8.5@82.88 13.3@101.64 anyways ill keep you posted sure im gonna have another question... Link to comment Share on other sites More sharing options...
CapeStylz Posted August 28, 2008 Share Posted August 28, 2008 anyone have a link to the dongle/usb for the live tuning (the cable from the laptop to the car) i think i said that right Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted August 28, 2008 Share Posted August 28, 2008 Hey, Kev. Check this out for the dongle driver: http://forums.cobbtuning.com/forums/showthread.php?t=41543 Link to comment Share on other sites More sharing options...
biz77 Posted August 28, 2008 Share Posted August 28, 2008 anyone have a link to the dongle/usb for the live tuning (the cable from the laptop to the car) i think i said that right We were struggling with this last night. Could not get the live tuning or logging to work, but got a map built (the old fashioned way) and loaded onto the A/P and then onto the car. Thanks for the link kevkel33leg05 Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted August 28, 2008 Share Posted August 28, 2008 np but thanks metal2you Link to comment Share on other sites More sharing options...
kevkel33leg05 Posted August 28, 2008 Share Posted August 28, 2008 question has anyone gotten the data logging to work at all? Link to comment Share on other sites More sharing options...
jarrod Posted August 29, 2008 Share Posted August 29, 2008 question has anyone gotten the data logging to work at all? nope...i've got the dongle installed now but the logging and live tuning still don't work Link to comment Share on other sites More sharing options...
spiralsmurf Posted August 29, 2008 Share Posted August 29, 2008 has anyone tried using a tactrix cable? How do they release software that doesn't work?!?!?! Link to comment Share on other sites More sharing options...
praedet Posted August 29, 2008 Share Posted August 29, 2008 So, has anyone compared the tables in Race to Good Ole' ST Advanced? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted August 29, 2008 Author Share Posted August 29, 2008 One thing I seem to have heard about vs#2 AP is that it is locked out to other software. Wghat that means is you can still log with RR, but if you want to save a copy of your rom and then modify it w/ RR that is out. Kinda sucks as COBB does not have all the tables one may want to adjust, like per cyl timing comp. Also sucks cause every base map has to be done with the AP, but I hear the vs#2 is significantly faster then 31. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
biz77 Posted August 29, 2008 Share Posted August 29, 2008 One thing I seem to have heard about vs#2 AP is that it is locked out to other software. Wghat that means is you can still log with RR, but if you want to save a copy of your rom and then modify it w/ RR that is out. Kinda sucks as COBB does not have all the tables one may want to adjust, like per cyl timing comp. Also sucks cause every base map has to be done with the AP, but I hear the vs#2 is significantly faster then 31. True, there appeared to be overall quite a few less tables available in Accesstuner Race, but a few additional tables for idle that RR doesn't have and the throttle table is a single, easy to understand table instead of the two tables in RR. Couldn't you flash fixes for things like PCTC using RR initially, then grab that map off the car with the A/P ver.2 and start building the Accesstuner map from there? The new A/P grabs the the map that is on the car when it is married. Shouldn't you be able to modify this "stock" map in Accesstuner Race? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted August 29, 2008 Author Share Posted August 29, 2008 True, there appeared to be overall quite a few less tables available in Accesstuner Race, but a few additional tables for idle that RR doesn't have and the throttle table is a single, easy to understand table instead of the two tables in RR. Couldn't you flash fixes for things like PCTC using RR initially, then grab that map off the car with the A/P ver.2 and start building the Accesstuner map from there? The new A/P grabs the the map that is on the car when it is married. Shouldn't you be able to modify this "stock" map in Accesstuner Race? Good question. I don't have #2 AP, so I don't know. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
biz77 Posted August 29, 2008 Share Posted August 29, 2008 I played with it two nights ago on a buddys 06 FXT. We started with Cobb's VF-39 map for the Forester so I didn't check to see if you can modify the ROM that is stored on the A/P when it's initially married. Anyone try it? Link to comment Share on other sites More sharing options...
CapeStylz Posted August 29, 2008 Share Posted August 29, 2008 ok so i Fu**ed up...... 1st) I uninstalled the ap stage 2 from my car cause im a dumb ass.... 2nd) updated the firmware and downloaded the email link... everything went fine 3rd) i go out to my car to reinstall 4th) ap stars up and tells me OLD Dongle Found This dongle cannot be updated in the field please contact customer service. 5th) so i click ok and try to install my stage 2 and get this 6th)ECU Comms cable not connected or mis-configured im sure someone already said something about the dongle but im missing it HELP Link to comment Share on other sites More sharing options...
MiniStiGuy Posted August 30, 2008 Share Posted August 30, 2008 you must have the v1 dongle which then means you have to send it to cobb to get the new version. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Paisan Posted August 31, 2008 Share Posted August 31, 2008 So anyone wanna host an online clinic for tuning newbs? Willing to pay... -Andrew Same here, I'm definitely willing to learn and willing to pay for some good tutoring. -mike Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 2, 2008 Share Posted September 2, 2008 With what I am reading I cannot convert my TDC v1.16 map that is tuned already for my AEM CAI and TMIC to AccessTunerRace file via the new software. I guess where I need to start in order to datalog is convert one of the Cobb base maps using the ATR software and reflash. If this is the case I am sure I need to remove the AEM CAI put the factory intake on and go from there. Correct? http://forums.cobbtuning.com/forums/images/misc/progress.gif Link to comment Share on other sites More sharing options...
Infamous1 Posted September 2, 2008 Share Posted September 2, 2008 That would be correct, you would need a wideband O2 sensor to properly dial in the AEM. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted September 2, 2008 Share Posted September 2, 2008 Infamous any recommends on a wideband to work with the Cobb software? I know Cobb listed some but whats your opinion? Link to comment Share on other sites More sharing options...
