isuace Posted July 20, 2008 Share Posted July 20, 2008 I got a gallon of gen-u-whine Subaru coolant today but forgot the special sauce (Woulda thought the parts monkey would have tried to add to his sale). Would it be alright if I do the drain/fill tomorrow and just put the special sauce in later on when i have time to get it? Thoughts? Link to comment Share on other sites More sharing options...
franklin Posted July 20, 2008 Share Posted July 20, 2008 I got a gallon of gen-u-whine Subaru coolant today but forgot the special sauce (Woulda thought the parts monkey would have tried to add to his sale). Would it be alright if I do the drain/fill tomorrow and just put the special sauce in later on when i have time to get it? Thoughts? Should be fine. The special sauce ,AKA Subaru additive is only 4 ounces. Be sure to shake it up well before dumping it in. Link to comment Share on other sites More sharing options...
Erickson00 Posted September 11, 2008 Share Posted September 11, 2008 I had my coolant changed at 30,000 miles at Tires Plus. I am at 41,000 miles now. Am I screwed? Link to comment Share on other sites More sharing options...
outahere Posted September 11, 2008 Share Posted September 11, 2008 I got a gallon of gen-u-whine Subaru coolant today but forgot the special sauce....... Ask for the non-chunky version of the special sauce http://www.legacygt.com/forums/showthread.php?t=71247 Link to comment Share on other sites More sharing options...
mikeislord Posted October 13, 2008 Share Posted October 13, 2008 Good thing I got bored at work and checked this thread. Was about to just use the crap they sell at Pep Boys. /sigh Maintaining a Subie is definately a bit more complex than my old Honda beater. Link to comment Share on other sites More sharing options...
legacy2 Posted October 23, 2008 Share Posted October 23, 2008 what does the jiggle valve do on the thermostat? Link to comment Share on other sites More sharing options...
sashadg1 Posted December 30, 2008 Share Posted December 30, 2008 How many bottles of OEM Coolant do I need to buy from the dealership? mixing the 50/50 of course Link to comment Share on other sites More sharing options...
SBT Posted December 31, 2008 Share Posted December 31, 2008 1 gallon should do it. Per the tech manual, the cooling system holds 7.7 U.S Qts (MT model) and 7.6 U.S. Qts (AT model) which is nearly 8 quarts (2 U.S. gallons). To maintain the recommended 50/50 antifreeze to water dilution on a MT model, you'd need ~ 4 Qts (3.9) of Subaru OEM AF and ~4 Qts (3.9) of distilled water plus the 4 ozs of Subaru Cooling System Conditioner. Should be good to go. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
sashadg1 Posted December 31, 2008 Share Posted December 31, 2008 Thanks for info Subietonic! Link to comment Share on other sites More sharing options...
franklin Posted January 1, 2009 Share Posted January 1, 2009 Can the '05 -'07 LGT's use the new Subaru coolant ? Or should we use the old Subaru coolant ? Link to comment Share on other sites More sharing options...
SBT Posted January 1, 2009 Share Posted January 1, 2009 ^^ P/N reference or something that indicates there's a newer coolant. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
sashadg1 Posted January 1, 2009 Share Posted January 1, 2009 can we run a radiator flush cleaner first or is this not needed? Link to comment Share on other sites More sharing options...
bluesuby Posted January 1, 2009 Share Posted January 1, 2009 can we run a radiator flush cleaner first or is this not needed? Depends on how dirty your coolant is. I don't let my coolant get that dirty because I figure anything that's harsh enough to clean up a cooling system cannot be that good for it. A "flush" with clean water ought to do it. My question is do we add the secret sauce to the new (extended life) coolant the same as we did with the original? Link to comment Share on other sites More sharing options...
SBT Posted January 2, 2009 Share Posted January 2, 2009 can we run a radiator flush cleaner first or is this not needed? The only flush I would do would be with fresh water. If you're changing it at the prescribed intervals (either normal driving or harsh conditions driving intervals) then you shouldn't have any reason to flush it with other than water, if that. The less I put into that alloy block and head system, that's not specifically made for it, the less concerned I am about contaminants and metalurgical reactions. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted January 2, 2009 Share Posted January 2, 2009 My question is do we add the secret sauce to the new (extended life) coolant the same as we did with the original? The answer would be yes. They both have their role in the cooling system. And what is the extended life Subaru coolant that you're referring to above? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
franklin Posted January 2, 2009 Share Posted January 2, 2009 ^^^ I think he means the same as the "new" collant I was refering to. The " new" stuff is blue in color ( I think) vr's the "old" Subaru coolant that is green in color. The new stuff came out recently , and is listed for the newest cars. I'm trying to determine weather the '05 -'06 should go with the old or new stuff ? Link to comment Share on other sites More sharing options...
sashadg1 Posted January 2, 2009 Share Posted January 2, 2009 ask the parts guy at the dealer or one of the techs Link to comment Share on other sites More sharing options...
SBT Posted January 2, 2009 Share Posted January 2, 2009 Just some pertinent, recent (Nov 2008) tech info from SOA on coolant, coolant change out, flushing information and system conditioner - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted January 2, 2009 Share Posted January 2, 2009 Thanks for info Subietonic! Please check the front label to see if the coolant you're buying is already pre-diluted to 50/50. I know that the new Super Long Life Fluid is so you'd need two gallons of that, not just one as stated previously. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
franklin Posted January 2, 2009 Share Posted January 2, 2009 Just some pertinent, recent (Nov 2008) tech info from SOA on coolant, coolant change out, flushing information and system conditioner Thank you. This is the info I was seeking. Yes the new super long life coolant is blue. Yes its OK to use in our ( older ) cars , and with this the change interval is 11 years and /or 137,500 miles. yes continue to also add the Subaru additive too Thanks again for the official word. Link to comment Share on other sites More sharing options...
bluesuby Posted January 2, 2009 Share Posted January 2, 2009 Pre-diluted? And we thought the secret sauce was a scam to get a little extra cash out of us. I probably won't leave the new coolant in my car for more than a few years, but with distilled water costing $1/gallon, I don't like paying for pre-diluted coolant. Link to comment Share on other sites More sharing options...
SBT Posted January 2, 2009 Share Posted January 2, 2009 Thank you. This is the info I was seeking. Yes the new super long life coolant is blue. Yes its OK to use in our ( older ) cars , and with this the change interval is 11 years and /or 137,500 miles. yes continue to also add the Subaru additive too Thanks again for the official word. And don't flush with anything except fresh water, and definitely no power flushers unless you want to buy their recommended version and then only use it on Subarus (and then only those Subarus with fully alloy block). - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
spect2k Posted January 4, 2009 Share Posted January 4, 2009 I asked SOA about the new super coolant. Here is what I got: Thank you for your recent e-mail to Subaru of America, Inc. We appreciate you taking the time to contact us. If you choose to use the Subaru Super Coolant in your Legacy, you must flush out all of the Subaru Long-Life coolant before you replace with the Super Coolant in order to take advantage of the Super Coolant replacement interval of 137,500 miles or 132 months. Subaru Super Coolant can be mixed with the Subaru Long Life Coolant in your 2008 Subaru Legacy; however, when mixed, the replacement interval must be followed for Subaru Long Life Coolant (30 months/30,000 miles). If you have any additional questions, please do not hesitate to contact us again. Thank you for the opportunity to be of service. I'll put in the super coolant at 30K and then swap it out again at 60K before I use it long term. Link to comment Share on other sites More sharing options...
iggybdawg Posted January 7, 2009 Share Posted January 7, 2009 can't we just use any coolant that's safe for aluminum? plenty of other car brands make aluminum engines and radiators.. Link to comment Share on other sites More sharing options...
SBT Posted January 7, 2009 Share Posted January 7, 2009 ^ If you want to, it's your vehicle to operate and maintain how you see fit. For myself, I want to reduce/eliminate any variability from my maintenance plan and that means using the OEM products as much as practical. I'm just sticking with the 30K long life variety for now. Don't see any reason to change to the super long life stuff. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
