magnetic1 Posted June 6, 2008 Share Posted June 6, 2008 More to come soon. Just wanted to keep you guys updated. We will soon open up pre-orders! Still on our goal for our target price of $1299. This kit will come complete with everything you need! Instructions, Calipers, Rotors, Hawk Performance Ceramic Pads, SS-lines, and all hardware needed! Some highlights include calipers that weigh under 5 pounds each! Lots of pad choices from Hawk, Performance Friction, Carbotech, Porterfield and more! Much better and consistent pedal feel throughout its use! You can use stock wheels with many rotor choices. DBA4000s, OE-type, etc! Post questions that you might have here and Ill try to answer. I also have a test car using them and he will post here with his comments. You guys are going to LOVE these!!!! http://www.liteswap.com/Merchant2/graphics/00000001/lgtpbk/completekit.jpg http://www.liteswap.com/Merchant2/graphics/00000001/lgtpbk/instructions.jpg Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
VTGT Posted June 6, 2008 Share Posted June 6, 2008 Purdy. I need to see pics of these brakes installed on the car Great price. Any chance of getting a match rear set? Link to comment Share on other sites More sharing options...
magnetic1 Posted June 6, 2008 Author Share Posted June 6, 2008 Purdy. I need to see pics of these brakes installed on the car Great price. Any chance of getting a match rear set? Hey VT, No rears at the moment. We really wanted to get going on the fronts first. The tooling required to make brackets for the rear for such a low volume run would end up costing quite a bit. Plus it would require tons of testing to get the bias, brake forces, etc right since it would require much larger rotors. My main "turn-on" with this kit is the super wide variety of pads available. Especially if you track the car. Youre talking track pads that are half the price of normal LGT track pads!!! Hawk HT10s run only about $130! DTC70s are $165ish! Similar pricing for PFC01, etc! For street pads, pricing is on par w/ the stock stuff though. Maybe $5-$10 less. But again, lots more options on pad manufacturers. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
RobY Posted June 6, 2008 Share Posted June 6, 2008 Do these willwood calipers have dust boots? Link to comment Share on other sites More sharing options...
fweasel Posted June 6, 2008 Share Posted June 6, 2008 Do these willwood calipers have dust boots? They historically do not and these pictures seem to indicate the same thing. Hawk HT10s run only about $130! DTC70s are $165ish! Similar pricing for PFC01, etc!One of the primary reasons I swapped out my stock calipers to the Brembos. Those pad prices are INSANE! This coming from someone who just blew through a set of HT-10's in a single day. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
magnetic1 Posted June 6, 2008 Author Share Posted June 6, 2008 Actually the dust boots are a much smaller issue than most make it out to be. If the piston is made from higher quality materials such as stainless steel (most calipers use aluminum w/ a rubber dust boot), it can hold up very well. We've seen many Wilwood caliper kits for numerous cars for many years that continue to be trouble free. If you look carefully at calipers with dust boots, they are far from being hermetically sealed. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Xenonk Posted June 10, 2008 Share Posted June 10, 2008 Does Wilwood sell a piston replacement or rebuild kit for these calipers? Or are these the new generation of calipers that require less servicing than the older Wilwood calipers that were known to have a rebuild cycle of about 15,000 miles of spirited driving? Keefe Link to comment Share on other sites More sharing options...
magnetic1 Posted June 10, 2008 Author Share Posted June 10, 2008 Keefe, we've seen club racers and street cars use these calipers for years without rebuilds. Comparing that to those who track with stock calipers that need annual rebuilds, that is a pretty good sign. But if you really feel like you do want to rebuild the caliper, rebuild kits are only $9.88 Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Underdog Posted June 10, 2008 Share Posted June 10, 2008 They sure are pretty, but would this be a worthwhile upgrade for a street driven car (given the car is already equipped with appropriately sticky tires)? How would running this kit affect the brake bias? Would you need to run the same brand/type of pad and rotor in the rear? I really like that matte/machined look too! The Crimson Dynamo Link to comment Share on other sites More sharing options...
magnetic1 Posted June 10, 2008 Author Share Posted June 10, 2008 It would improve brake feel, and modulation (and looks ) but whether that is worthwhile to you is a decision you need to make There are plenty of people who dont see the track w/ StoPTech, Brembo, etc calipers and kits. Bias should not change. No need to run same brand/type in rear for the street. You can though and pads are cheap. The main draw is that you can get any type of pad for this caliper ULTRA-cheap! Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
mikeyan Posted June 10, 2008 Share Posted June 10, 2008 i haven't been to the track with the stoptechs yet (been on the car for a few weeks now), but they're pretty damn good for street use . Would i pay full price them? I'm not sure yet. But the double-assurance you get that you're going to stop in a panic situation is worth it to me. Mike SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
fweasel Posted June 10, 2008 Share Posted June 10, 2008 But the double-assurance you get that you're going to stop in a panic situation is worth it to meyour "double assurance" is placebo, IMO. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
mikeyan Posted June 11, 2008 Share Posted June 11, 2008 probably, but damn if i passengers haven't commented on high speed stops versus before the brakes were in. And these were passengers that had no idea i did anything to the car. It definately feels like the car is stopping a helluva lot better. Would i have paid full price for them? i'm still not sure. But i got an amazing deal Mike PS When i put them on, i really had no expectations for them. Already had upgraded pads and lines. I've been pretty darn impressed though. SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
jomamma Posted June 11, 2008 Share Posted June 11, 2008 what's the minimum wheel size needed to fit, 17x7.5? Link to comment Share on other sites More sharing options...
Xenonk Posted June 11, 2008 Share Posted June 11, 2008 what's the minimum wheel size needed to fit, 17x7.5? I think Magnetic1 had these calipers in mind to fit over the stock rims. Keefe Link to comment Share on other sites More sharing options...
magnetic1 Posted June 11, 2008 Author Share Posted June 11, 2008 Should fit over stock wheels. Im scheduling a production run for the mounting hardware and should be able to start pre-orders for the first 10 sets or so next week. (With a pre-order sale price!) The target retail is $1299, so pre-order will likely fall in below that. Keep in mind this comes with EVERYTHING. Rotors, pads, lines (front AND rear), hardware and calipers. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Underdog Posted June 11, 2008 Share Posted June 11, 2008 Hmm... I'll probably be due for a brake upgrade by then and compared to the other kits out there (Pads, Rotors, Lines, Fluid) that go for ~$700, this is a great deal! I'd be interested to see how well these hold up in New England type conditions, with longevity equal or greater than the stock components as the baseline. I'm also wondering how we would source pads and rebuild kits several years down the line... are they common enough that parts would be readily available? The Crimson Dynamo Link to comment Share on other sites More sharing options...
magnetic1 Posted June 11, 2008 Author Share Posted June 11, 2008 Hmm... I'll probably be due for a brake upgrade by then and compared to the other kits out there (Pads, Rotors, Lines, Fluid) that go for ~$700, this is a great deal! I'd be interested to see how well these hold up in New England type conditions, with longevity equal or greater than the stock components as the baseline. I'm also wondering how we would source pads and rebuild kits several years down the line... are they common enough that parts would be readily available? Just to answer some of your questions: These calipers have been tested and used in many applications including salt, etc. (just not specifically on the LGT). As far as pads go, the Wilwood Superlite calipers take a standard pad size and is available through numerous vendors. As far as rebuild kits go, there are many Wilwood dealers who carry rebuild kits, or they can be sourced directly from Wilwood. Hope that helps! Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Underdog Posted June 11, 2008 Share Posted June 11, 2008 It sure does, and your quick response is appreciated. I will be keeping a close eye on this thread and perhaps I'll be able to take advantage of the pre-order sale price! The Crimson Dynamo Link to comment Share on other sites More sharing options...
Golf4283 Posted June 11, 2008 Share Posted June 11, 2008 So you're offering a kit for front and rear wilwoods for $1,299? I might have to sign up. Link to comment Share on other sites More sharing options...
mikeyan Posted June 11, 2008 Share Posted June 11, 2008 fronts only for now SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
Underdog Posted June 11, 2008 Share Posted June 11, 2008 ^^ Front only... but still a great deal considering the pads, rotors, and lines (f&r) come with it... The Crimson Dynamo Link to comment Share on other sites More sharing options...
Dr.Chris Posted June 11, 2008 Share Posted June 11, 2008 I think the rear that he mentioned was for the SS lines, not the calipers. 2011 WRX Hatch currently. Looking for OXT or FXT for new daily to go with the WRX. Link to comment Share on other sites More sharing options...
magnetic1 Posted June 11, 2008 Author Share Posted June 11, 2008 ^^ Front only... but still a great deal considering the pads, rotors, and lines (f&r) come with it... I forgot, and fluid I might add the option of rear slotted rotors and pads for a small added charge. Since you'll be changing out the rear lines anyways, might as well do rotors/pads while youre there. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
Underdog Posted June 11, 2008 Share Posted June 11, 2008 Sounds great to me! With my suspension all upgraded, the braking already feels better. After this, I'm gonna need to mod the "go" to match all the "whoa"... I would really like to paint the rear calipers to match the matte finish of the wilwoods. Right now all my calipers are a grey/green oxidized color. Would you recommend the hawk ceramic pads (mentioned in the OP) and slotted rotors for daily-drivers, or do they need track conditions to get to operating temp.? The Crimson Dynamo Link to comment Share on other sites More sharing options...
