Merc6 Posted September 16, 2015 Share Posted September 16, 2015 My mod list is this when it last ran *OEM VF46 Turbo *OEM STi UP *Stromung Divorced Waste gate shorty front DP + PERIN catted rear DP *PERRIN TMIC *GFB GT BOV 50/50 *Cobb Front Sway *Blitz Air box Grille replacing front half of OEM Air Box *Mid Pipe Resonator Deleted for 2 bullet style resonators *2 Aero Turbines used as rear cans *Custom Angle Cut Pypes Quad Tips *2006 Legacy GT Limited Tan Interior Swap *35% Tint *Jazzy Aux *eBay Billet Grille insert, Black *White Puddle, Trunk, License Plate, and Map LEDs And Red Dome LED *No Name generic 15 Inch Sub in generic build a box and unknown amp(will look and see) *Tune was opensourced by Dynamic Power Solutions in Gaithersburg, Maryland What I have currently acquired since then is *OEM 2008 EJ257 Short Block E25C 704 with BBBB pistons *OEM VF 52 soon to be sent of to JmP for 11 Blade rebuild *OEM Engine Gasket Set (2005) *OEM 05 LL Bean Wood MOMO Wheel *OEM Timing Belt *OEM Head Bolts *OEM 10MM Oil Pump *OEM Closed Impeller Water Pump *OEM Oil Cooler *OEM Oil Control Valves X's 2 *OEM STi I/C sprayer tank *TIC FU Cam Bolts *LIC Aluminum Half Moons *GrimSpeed 3" Down pipe to Factory Cat-Back Exhaust Adapter *Infamous Performance & Tuning Filtered Turbo Oil Supply Line Kit V2 *AVO Induction Silicone Turbo Inlet - 05-06 Legacy GT/Outback XT *Mishimoto Subaru Legacy GT Radiator Hoses *Venair 05-09 Subaru LGT 5 Piece Ancillary Silicone Hose Set - Vacuum *Venair 05-09 Subaru LGT 6 Piece Ancillary Silicone Hose Set - Cooling *Venair 05-09 Subaru LGT BPV Return Silicone Hose *Tein Springs *Turkeylord Blue Tee replacement *Lamin-X tinted Tail Light Overlays 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
05legacygtr Posted September 16, 2015 Share Posted September 16, 2015 Heres my list...maybe missing a mod or 2? Lazy to add it up... Ps ive replaced axles, did diff and trans fluids x2, soon to do timing belt, waterpump, thermostat, etc service this week DIY most likely APM tuned transmission plates/blast plates Osram lowbeams/ fogs Tinted corner overlays as well Sent from outer space I really like your set up....if only I had some extra skrilla...after college we'll c, what rpms are u hitting full boost with that turbo?how does it feel street driving? Link to comment Share on other sites More sharing options...
LatentWagen Posted September 16, 2015 Share Posted September 16, 2015 Try to post up the total dollar cost of your mods, maintenance, etc rather than just posting your mod list. Add it all up; it's not hard, and the answer might shock you (or not). Title of thread: "How much money did you really put into your legacy?" LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
hobo2701 Posted September 16, 2015 Share Posted September 16, 2015 Engine/exhaust cosworth shortblock with Sti crank $4800 Cosworth intake manifold $800 Cosworth blueprinted 11mm oil pump $560 [intake & Exhaust Valves:Supertech Black Nitrided SS Valves Set (STD)] Springs:Supertech Dual Spring w/TI Retainers heads $2000 NGK one step colder plugs TGV deletes $150 GMS turbo inlet $80 injecctors Dynamics side feed rail adpater with 1000cc injectors and 6an fuel lines $600 Walbro 255lph fuel pump $75 Grimspeed EBCS $100 blouch 3.0 $1200 gates timing belt kit w/ water pump $250 GruppeS uel Header with white ceramic coating $300 Invidia catless downpipe with white ceramic coating $300 Cobb Catless uppipe with white ceramic coating $100 GMS catback exaust $400 Dual fms catch can setup $100 Killer B High Performance Oil Pan $450 Killer B Oil Baffle Windage $75 Killer B Ultimate Oil Pickup $170 group N transmission mount $85 torque solutions engine mounts $220 greddy 1.2 bar oil cap $80 MTX-L: MTX Series Digital Air/Fuel Ratio Gauge Kit $200 Suspension Ohlins DFV coilovers $3100 spec b Aluminum front control arms $600 spec b rear trailing arms $650 spec b upper lateral link $150 Sti rear pillowball laterall links $250 Gt spec tie rod ends/ball joints $350 AVO front lca bushing kit $65 Perrin xtreme duty front endlinks $200 Perrin 25mm front sway bar $200 AVO Subaru Legacy GT Rear Stabilizer Bar Mount Reinforcement Brackets $150 AVO Suspension Rear Solid Endlinks w/polyurethane 70mm - $130 AVO Suspension Rear Sway Bar 20mm $175 Cusco Legacy GT BP9 Front Lower Arm Bar $200 Cusco Legacy GT BP9 Rear Lower Arm Bar Set $160 Brakes Alcon/stasis 6 piston mono bloc 370mm x 32mm front brakes $3000 goodridge SS brake lines ferrodo pads Cooling FMS front mount intercooler $250 FMS oil feed line Koyo radiator $350 Megan blue radiator hosing $50 Cusco radiator shroud $125 mishimoto oil cooler $300 Drivetrain Clutchmasters fx350 clutch/flywheel $600 new oem hubs new oem knuckles Wheels rays engineering 57dr 18x8.5 +38 semi gloss black $2000 Rays lug nuts Exterior/Interior JDM SPEC B bumper in SWP. JDM SPEC B bumper beam + foam JDM SPEC B fender liners RH,LH JDM SPEC B foglights with brackets RH,LH JDM SPEC B bumper brackets side and inner RH,LH JDM SPEC B bumper tow hook cover JDM SPEC B bumper / headlight brackets RH,LH JDM SPEC B lower air dam guide + foam JDM SPEC B intake guide JDM SPEC B s402 Grill with white subaru emblem $3000 for bumper kit JDM Double Din setup with Kenwood DNX6960 $850 i did my best to rember and look at prices so this is a close guestimate but wow definitely havent added it up before im at the $30k mark not including 12K i paid for the car and at least 6-7K in labor. gotta love cars Link to comment Share on other sites More sharing options...
Rhitter Posted September 16, 2015 Share Posted September 16, 2015 Hobo is yours back up and running? My OBXT build Link to comment Share on other sites More sharing options...
hobo2701 Posted September 16, 2015 Share Posted September 16, 2015 pretty much ive just been driving my old bmw e21 this summer to keep miles off the subie and i just got a couple new parts like the oil cooler and the new injectors and fuel lines/rails but ya she will be on the street this fall and definitely gonna make it to at least one track event this year Link to comment Share on other sites More sharing options...
Merc6 Posted September 16, 2015 Share Posted September 16, 2015 Try to post up the total dollar cost of your mods, maintenance, etc rather than just posting your mod list. Add it all up; it's not hard, and the answer might shock you (or not). Title of thread: "How much money did you really put into your legacy?" Had this car since almost new. LOL no way I can guess what I foolishly paid new/used value of some of the things prior to rebuild. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
magnusonsubie Posted September 17, 2015 Share Posted September 17, 2015 This is why I'm afraid to even begin modding... When my parents ask me where all the money is that I've been saving for college I'll just show them my car.. Boy will I be the disappointing child again.. Sent from my LGLS990 using Tapatalk lol I'm in college right now and everytime I come home my parents look at my wagon and go "Oh thats new". Be realistic though. Set a goal of what you want out of your car and how much you're willing to spend. I have kinda just been winging it with my wagon which I've owned since Feb 2014 now and I'm $17,000 into it including the $10k price with 51k miles. I saw you had posted in the AVO 2.5i turbo thread as well and personally I wouldn't attempt to do that with your car. I would just do appearance and suspension for now. Theres a reason there isn't a huge market for engine mods for the 2.5i engine since there is a turbo engine in the same car available. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
battelready Posted September 17, 2015 Share Posted September 17, 2015 lol I'm in college right now and everytime I come home my parents look at my wagon and go "Oh thats new". Be realistic though. Set a goal of what you want out of your car and how much you're willing to spend. I have kinda just been winging it with my wagon which I've owned since Feb 2014 now and I'm $17,000 into it including the $10k price with 51k miles. I saw you had posted in the AVO 2.5i turbo thread as well and personally I wouldn't attempt to do that with your car. I would just do appearance and suspension for now. Theres a reason there isn't a huge market for engine mods for the 2.5i engine since there is a turbo engine in the same car available. Samesies. About to hit med school next year and i finally got myself to realize that ill probably be driving this thing for a very long time and more mods will begin to decrease reliability. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
Merc6 Posted September 17, 2015 Share Posted September 17, 2015 Yeah us already turbo'd guys are pretty much pouring the value of your car into keeping ours running right for a bit. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
quick4dr Posted September 17, 2015 Share Posted September 17, 2015 shit Ive owned her 6 years come next month, paid 13,900 for her with 65 or so in the clock, i have 121,xxx now. including 3 sets of wheels, snow tires, street tires, dyno sessions, maintenance, performance labor when it was over my head, parts... conversion to black interior, 4 different headers, 2 different DP, wide body fenders, other jdm goodies, importing fees... ... I lost track I was near 30k when i actual counted it all. with likely 10-12k made back on selling parts Link to comment Share on other sites More sharing options...
quick4dr Posted September 17, 2015 Share Posted September 17, 2015 Samesies. About to hit med school next year and i finally got myself to realize that ill probably be driving this thing for a very long time and more mods will begin to decrease reliability. Well then lets get that paint cleaned up and sealed up. long term protection! @js_finesse_fanatics http://www.finessefanatics.com Link to comment Share on other sites More sharing options...
tocinoman25 Posted September 17, 2015 Share Posted September 17, 2015 (edited) Updated with monies... Hits full boost around 5500rpms 20.xx psi Not as streetable as id like but when it hits, hold on...its not so bad but i was always eyeing kinugawa td06sl2 18g... Will turn it up more with built shortblock and if 5 speed wont hold up with them blast plates...ill get 6 speed lol Edited September 17, 2015 by tocinoman25 Updated Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
CTATV Posted October 12, 2015 Share Posted October 12, 2015 Probably 15-20 grand Link to comment Share on other sites More sharing options...
CTATV Posted October 12, 2015 Share Posted October 12, 2015 On the 20 side Link to comment Share on other sites More sharing options...
xtea Posted October 12, 2015 Share Posted October 12, 2015 I'm pretending this thread doesn't exist. Link to comment Share on other sites More sharing options...
Merc6 Posted October 12, 2015 Share Posted October 12, 2015 I'm pretending this thread doesn't exist. There is a few other threads I do that to as well. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
covertrussian Posted October 12, 2015 Share Posted October 12, 2015 You guys are making me feel better, I have about $4.5k in Power & maintenance (tires included). Though this is not counting about $1.5k in spare parts that I bought that are waiting for a rainy day... 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
I Donated Too luchadorjose Posted October 12, 2015 I Donated Too Share Posted October 12, 2015 I'm 18K into my specB purchase price, and 14K in mods, not including maintence. Link to comment Share on other sites More sharing options...
tocinoman25 Posted October 12, 2015 Share Posted October 12, 2015 im glad i am capable of doing 90% of maintenance thats a huge savings in itself..thanks to some hands on experience and these forums... No matter how much we put into our leggys...it puts a smile on our faces...especially when you pass up cars that least expect it...make it unique and make it your own...thats the beauty of the modding game hopefully i get to add more upgrades like built SB and a 6 speed... Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
Insomnia2020 Posted April 18, 2020 Share Posted April 18, 2020 (edited) I have invested 10k$ in my car, and it's just perfect now. Someone may say that 10000$ is a very big sum, and that I am stupid that I have spent them on a old car ) You may be right, but I have so much money that it's absolutely nothing for me. I have found some ideas on how to get a very nice passive income, and now I have no financial problems at all. I'm just trying to have some fun, you know. By the way, I like the car very much Edited April 20, 2020 by Insomnia2020 Link to comment Share on other sites More sharing options...
boxkita Posted April 18, 2020 Share Posted April 18, 2020 I have invested 10k$ in my car, and it's just perfect now that's not how this thread works. You actually have to list what you have. usually ppl start with a new thread on the "new member section ". You talk about how you came to own a lgt or obxt. After a couple posts, then you chime in on the "wdydtyc" threads. After you pass your 10 posts count, you start bumping year old threads. Its like dating. Hey wanna F? works in some bars. Here it takes a few dates,er,posts to get along. start here: https://legacygt.com/forums/forumdisplay.php/new-member-introductions-40.html Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
awfulwaffle Posted April 18, 2020 Share Posted April 18, 2020 I've disposed of over $10k in my dumpster of a car. But I like it, probably because I belong in a dumpster myself. Link to comment Share on other sites More sharing options...
awfulwaffle Posted April 18, 2020 Share Posted April 18, 2020 Er, I meant invested Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 18, 2020 Share Posted April 18, 2020 No, you had it right the 1st. time:rolleyes:. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
