finse Posted October 10, 2009 Share Posted October 10, 2009 ^be very careful with the squirrel finders...because the piece of metal is thin, it can be damaged and pretty easily and while it may look normal to the eye any little movement can mess with your cutoff, i used putty that gets hard...not sure of actual name got it at autozone Thanks for the heads up. Luckily the oxidation came off really easy. I found another thread where MiniStiGuy recommended quick steel. I will head out to pick up a tube soon. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 12, 2009 Author Share Posted October 12, 2009 yup Quicksteel is what you want. You can get it at any auto store or walmart also has it. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
finse Posted October 18, 2009 Share Posted October 18, 2009 Mounted up the lights yesterday, and got them aimed today. Here is a picture of the beam pattern. Overall I think it turned out pretty good. Thanks for the advice Retro OG's! Link to comment Share on other sites More sharing options...
lookslikeanevo Posted October 18, 2009 Share Posted October 18, 2009 looks a little too close to each other...but other than that it looksgood! Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 19, 2009 Author Share Posted October 19, 2009 yes I would agree with EVO on this in that the horizontal aim is off on the lights. Look up my aiming guide in the exterior section and you will see the location of the horizontal aiming screw so that you can space them correctly. nice job though. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
finse Posted October 19, 2009 Share Posted October 19, 2009 I did pop off the horizontal aiming caps, I guess I should have spent a wee bit more time getting it right. I am going to have to pull one of my housings a re-bake it, as I have found some condensation. I will hopefully have this done by next weekend, and I will re-aim them. I have also found one other issue. I had an xtec h7 kit in my other housings for 3 years. They were bullet proof, however now that I have switched over to the D2S bulbs (same xtec ballasts), I am having the dreaded one or both headlights not coming on issue. I am going to order the battery/relay harness today and will be considering replacing my battery as well. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted October 19, 2009 Author Share Posted October 19, 2009 try the harness first as isolating the system from the stock wiring will ensure it gets the required voltage. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
underpowerd Posted October 19, 2009 Share Posted October 19, 2009 sorry i'm late finse, i could have told you tons -- i've been running the whole mdx d2s optics for about a year now. i'll keep an eye out here if you have any further q's Link to comment Share on other sites More sharing options...
finse Posted October 25, 2009 Share Posted October 25, 2009 try the harness first as isolating the system from the stock wiring will ensure it gets the required voltage. That seems to have done the trick. Once I got the harness installed, both lights fired each time I tried. Several tests were done, including turning over the engine when the lights were on. sorry i'm late finse, i could have told you tons -- i've been running the whole mdx d2s optics for about a year now. i'll keep an eye out here if you have any further q's No worries underpowerd, luckily for me the retro with the mdx d2s optics went very smoothly. Link to comment Share on other sites More sharing options...
ndmx52 Posted December 3, 2009 Share Posted December 3, 2009 So do the MDXs drop in just like the RX330s? Are you guys using 07+ projectors? Getting any color out of these projectors? Link to comment Share on other sites More sharing options...
finse Posted December 3, 2009 Share Posted December 3, 2009 So do the MDXs drop in just like the RX330s? Are you guys using 07+ projectors? Getting any color out of these projectors? I have only done the MDX projectors, so I don't know if it was exactly like the RX330s, but it sure seemed like they were. As far as the year goes, I can not remember exactly, I seem to recall my projectors being 06 or 07. I'll see if I can find the packing slip when I get home. I played around with the color mod, but I did not like it so much, I really prefer the cutoff line being sharp. Link to comment Share on other sites More sharing options...
underpowerd Posted December 3, 2009 Share Posted December 3, 2009 (edited) from the pics i've seen, the lens holders and bowls are nearly identical to the 330s; consequently, using the lgt shields should practically make them a bolt on affair i liked the MDX shields as well, and the mounting bolt pattern looks tantalizingly close to the lgt, but actually needs either bracketing, or to be redrilled/slotted; took some doing (drill few holes, trim here, grind there, some washers) to get the entire optics assembly to tuck in/bolt up perfectly, but i'm happy i did, spread is wide and sweet. i have a full writeup with pics on my other comp, will post it later on if there's anyone that wants it. as for year, mine are 08, and i believe that was the first year the mdx got hid. here's a crappy cell phone wall pic (55w ddm ballasts, philips bulbs, no color washer spacing, oem mdx squirrel spotters left open): (fogs off) http://i174.photobucket.com/albums/w102/duluoz_01/Cutoff-nofogs.jpg Edited December 3, 2009 by underpowerd Link to comment Share on other sites More sharing options...
finse Posted December 3, 2009 Share Posted December 3, 2009 the MDX cutoffs look great! I'll have to keep that in mind if I open up my housings again in the future. Link to comment Share on other sites More sharing options...
Jerboa113 Posted December 4, 2009 Share Posted December 4, 2009 I would certainly like a writeup. the words "practically make them a bolt on affair" are words I like to hear. "The penalty good men pay for indifference to public affairs is to be ruled by evil men." - Plato Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 4, 2009 Author Share Posted December 4, 2009 Hehehehe I'll have my cousin upload the pics we took of my newest mod! OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
NSFW Posted December 9, 2009 Share Posted December 9, 2009 (edited) Are Acura TSX projectors similar to the MDX and RX330? There's an ebay seller with "RX330" in his TSX listing. It doesn't look quite right, so maybe it's just keyword spam, but I gotta ask... EDIT: Ebay seller "hidparts" is a keyword-spamming douchebag! Thanks! Edited December 9, 2009 by NSFW Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 9, 2009 Author Share Posted December 9, 2009 No the TSX projectors are completely different and are not a direct bolt on like the MDX and Rx330 non-asf are. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
NSFW Posted December 9, 2009 Share Posted December 9, 2009 Thanks. Link to comment Share on other sites More sharing options...
Golf4283 Posted December 9, 2009 Share Posted December 9, 2009 Hey MiniSTiGuy. I was thinking of taking my lights apart again and playing with the cutoff shield. I have an extra set of shields for the legacy and think I'm gonna play around with making a curved shield out of them. What do you think about that? Will it flatten out the beam pattern when facing a wall? I'm just sick of it trailing off due to the flat shield and I have some ideas that I think will work. I also want to trim the foreground limiter to get more of an Acura TL type limit pattern. Let me know what you think and any other suggestions. I'm currently running RX330 non AFS model. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 9, 2009 Author Share Posted December 9, 2009 I would say don't waste your time trying to bend and cut up the stock shields. Most guys that do custom shields use aluminum flashing or some other thinner material than what the stock shields are. Try your local hardware store and look for any metal sign or a sheet of thin metal and use that. Check out this Thread for more info on custom shields. http://www.hidplanet.com/forums/viewtopic.php?t=44359&postdays=0&postorder=asc&start=0 OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Golf4283 Posted December 15, 2009 Share Posted December 15, 2009 Hey Mini. Is it even possible to cram a TL projector in our headlights? I'm looking at either the TL or the RX330 AFS to play around with. I don't need the BiXenon function but really like the low beams of the TL. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 15, 2009 Author Share Posted December 15, 2009 you can cram anything in there with enough cutting etc. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Golf4283 Posted December 15, 2009 Share Posted December 15, 2009 what do you think about the AFS version of the RX330 versus the non AFS? Is it worth the switch? Link to comment Share on other sites More sharing options...
mr_luv Posted December 15, 2009 Share Posted December 15, 2009 Im runnin ASF's now with a hacked all to hell stock shield. The TL's are possible but a bitch you will just about hack away all your stock mounting area to get them in there unless you make custom brackets. Mr.350 Link to comment Share on other sites More sharing options...
Golf4283 Posted December 15, 2009 Share Posted December 15, 2009 I picked up a set of AFS's. I'm gonna run them with a custom shield and cram 'em in there. Also picking up a set of E30 lenses. Will post pics. Gonna do the retro weekend of xmas hopefully. Link to comment Share on other sites More sharing options...
