benbro Posted March 29, 2007 Share Posted March 29, 2007 Ok, i have 40,000 on my car and my clutch just blew. SUGGESTIONS PEOPLE???? I have a UP, DP, and exhaust and an ecutek. let me know whats the best solution to my clutch/flywheel needs...i need your wisdom!!!! PM or just post. Link to comment Share on other sites More sharing options...
Metal2You Posted March 29, 2007 Share Posted March 29, 2007 This is it, man. This ACT clutch seems like the best option by far. Link to comment Share on other sites More sharing options...
Boostjunkie Posted March 29, 2007 Share Posted March 29, 2007 A little off topic, but I don't feel like searching right now as I'm at work. Will an Exedy twin disc for a Subaru 5 speed work with my 05 LGT? I have a chance to buy one at a sick price to go with my turbo swap and don't want to pass up this deal. I don't think it will fit, but I don't recall exactly why. I will search for more info later, but I figured if anyone knows the answer now, it will save me some time. Thanks Unless it's made for an 06+ WRX it will not work. Even if it is, you still need to get an 06+ WRX type flywheel to go along with it. Link to comment Share on other sites More sharing options...
SQC049 Posted March 30, 2007 Share Posted March 30, 2007 Unless it's made for an 06+ WRX it will not work. Even if it is, you still need to get an 06+ WRX type flywheel to go along with it. It includes a flywheel. I don't think it is from an '05. Damn, it was a good deal too! Super JDM part out: http://legacygt.com/forums/showthread.php?t=65039 PM me an offer! Link to comment Share on other sites More sharing options...
mwiener2 Posted April 2, 2007 Share Posted April 2, 2007 I called ACT and got some solid info finally. They DO NOT offer a LGT clutch. They offer a conversion kit. The kit converts from an LGT setup to an 06+ WRX setup. The addition of a new flywheel is what makes it a conversion. The 06+ WRX clutch is 4mm wider than the LGT. That's really the only difference. So for those that are still curious, there are currently two clutch options for the LGT. 1. Spec 2. ACT 06+ WRX Conversion My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
antny Posted April 2, 2007 Share Posted April 2, 2007 So what kit is Harmon selling then? I just ordered the ACT clutch kit from them and it will arive tomorrow. I am guessing it is the conversion kit then. Link to comment Share on other sites More sharing options...
wichitalegacy Posted April 2, 2007 Share Posted April 2, 2007 So what kit is Harmon selling then? I just ordered the ACT clutch kit from them and it will arive tomorrow. I am guessing it is the conversion kit then. No, i think you ordered an RPS . Link to comment Share on other sites More sharing options...
SQC049 Posted April 2, 2007 Share Posted April 2, 2007 I'm so confused with this stuff. Super JDM part out: http://legacygt.com/forums/showthread.php?t=65039 PM me an offer! Link to comment Share on other sites More sharing options...
mwiener2 Posted April 2, 2007 Share Posted April 2, 2007 Yes, the Harmen Motive kit is the conversion kit as it comes with a new flywheel. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
HansGT Posted April 2, 2007 Share Posted April 2, 2007 [quote=mwiener2;1087212 So for those that are still curious, there are currently two clutch options for the LGT. 1. Spec 2. ACT 06+ WRX Conversion Correction... If I'm not mistaken...multiple options. 1. SPEC stage 1 (OEM fly) 2. SPEC stage 2 (OEM fly) 3. SPEC stage 2+ (OEM fly) 4. SPEC stage 3 (OEM fly) 5. ACT for '06+WRX with WRX fly 6. Bullycluch (modified '06WRX) + '06 OEM WRX fly. http://www.legacygt.com/forums/showthread.php?t=52707 7. RPS...if still available. Link to comment Share on other sites More sharing options...
sutter2k Posted April 2, 2007 Share Posted April 2, 2007 ^ I think Exedy makes an 06 clutch wrx clutch too. Link to comment Share on other sites More sharing options...
mwiener2 Posted April 2, 2007 Share Posted April 2, 2007 Correction... If I'm not mistaken...multiple options. 1. SPEC stage 1 (OEM fly) 2. SPEC stage 2 (OEM fly) 3. SPEC stage 2+ (OEM fly) 4. SPEC stage 3 (OEM fly) 5. ACT for '06+WRX with WRX fly 6. Bullycluch (modified '06WRX) + '06 OEM WRX fly. 7. RPS...if still available. As of a month ago: >Date: Fri, 2 Mar 2007 10:13:48 -0600 >From: "David Norton" <sales AT specclutch.com> >Subject: RE: Subaru LegacyGT CLutch >To: <mwiener2> >I have the clutch (we manufacture them in all 7 performance stages), but we >are seeking a flywheel sample now from which to begin design. > >David Norton >S.P.E.C., inc >800-828-4379 >205-491-8593-fax >sales AT specclutch.com So if they were looking for flywheel samples to begin design... I don't think they have a good product out yet. Right now, they have a "it should work." Which is exactly what RPS said, or more correctly, what MDTurbo said. The RPS clutch was never meant for the LGT and if you call RPS and ask them, they will say they never said it would even work. MDTurbo screwed a bunch of us and that's probly why he's gone into hiding. So that again, leaves us with two decent options: 1. ACT Conversion Kit 2. Bullyclutch conversion kit In both those cases what you are really doing is a complete swap to a 06+ WRX clutch and flywheel. So if there are kits out there floating around for 06+ WRX's, they 'should' work so long as you do the full swap (PP, Friction disc, Flyhweel, bearings) The spec setup with the stock DMF flywheel is not the greatest of ideas because the reason the majority of us need to upgrade is that we've exceeded the power level of the stock clutch system. The stock DMF wasn't designed to handle these types of loads and stresses and is prone to malfunction. The whole thing can either bind together, effectively making it a single mass flywheel, or it could fail by breaking into lots of little pieces. It could also break into those tiny pieces sometime after it's fused into a lump of metal. If you're upgrading your clutch to handle more power, lose the stock DMF. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
mccorry Posted April 3, 2007 Share Posted April 3, 2007 ^^^^^^^^^^^^^^ Exactly why I am still waiting. Link to comment Share on other sites More sharing options...
mwiener2 Posted April 3, 2007 Share Posted April 3, 2007 I went ahead and ordered the ACT kit. Being afraid to use full throttle is pissing me off. ACT is a big enouhg company that they will stand behind their application. They said they tested it, so they should honor a warranty claim...... I would hope so anyways. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
HansGT Posted April 3, 2007 Share Posted April 3, 2007 So that again, leaves us with two decent options: 1. ACT Conversion Kit 2. Bullyclutch conversion kit Ahh "decent". You said "So for those that are still curious, there are currently two clutch options for the LGT." That's why I listed the other options out there. People have used these and have had it "work". Link to comment Share on other sites More sharing options...
highlander Posted April 3, 2007 Share Posted April 3, 2007 share your thoughts on pedal effort and engangement point after you get it in. Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
bskey Posted April 4, 2007 Share Posted April 4, 2007 ^ I think Exedy makes an 06 clutch wrx clutch too. The Exedy clutch is the one RPS was using. life in spin cycle..... Link to comment Share on other sites More sharing options...
benbro Posted April 5, 2007 Share Posted April 5, 2007 Is it possible to order a lightweight flywheel while running a replacement OEM clutch? this may be a better option for me as im not planning on modding my car much beyond what i currently have on it. plus, i just dont have $900 bucks to drop on a harman motive clutch/flywheel combo. Link to comment Share on other sites More sharing options...
sutter2k Posted April 5, 2007 Share Posted April 5, 2007 Is it possible to order a lightweight flywheel while running a replacement OEM clutch? this may be a better option for me as im not planning on modding my car much beyond what i currently have on it. plus, i just dont have $900 bucks to drop on a harman motive clutch/flywheel combo. do 06 WRX ACT clutch, WRX 06 OEM flywheel (250.00). I would not go light on the flywheel. Link to comment Share on other sites More sharing options...
mwiener2 Posted April 6, 2007 Share Posted April 6, 2007 ACT setup is about $900 My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
GT-L Posted April 6, 2007 Share Posted April 6, 2007 do 06 WRX ACT clutch, WRX 06 OEM flywheel (250.00). I would not go light on the flywheel. you wouldnt need anything else? Link to comment Share on other sites More sharing options...
bskey Posted April 6, 2007 Share Posted April 6, 2007 I don't think anyone makes a lightweight flywheel that mates up to the oem clutch. life in spin cycle..... Link to comment Share on other sites More sharing options...
mwiener2 Posted April 7, 2007 Share Posted April 7, 2007 ^^ Why would anyone want that? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
antny Posted April 7, 2007 Share Posted April 7, 2007 Mine just got here the other day and I am just waiting for my Subaru MAster tech buddy to rebuild 2 motors before I can get him to help me install it. Cant go wrong with having a master tech work on your car after hours haha Link to comment Share on other sites More sharing options...
bskey Posted April 8, 2007 Share Posted April 8, 2007 ^^ Why would anyone want that? Just a response to: Is it possible to order a lightweight flywheel while running a replacement OEM clutch? this may be a better option for me as im not planning on modding my car much beyond what i currently have on it. plus, i just dont have $900 bucks to drop on a harman motive clutch/flywheel combo. I cant imagine anyone would choose to keep the stock flywheel, unless they were on a really tight budget. life in spin cycle..... Link to comment Share on other sites More sharing options...
