Car PC
f1anatic
Car PC Survey
258 members have voted
  1. 1. Car PC Survey
    • I have a Car PC and I love it
    • I want a Car PC but I lack the know-how or the money for it
    • I gave up on Car PC: too much time/money/effort
    • Interesting concept but I chose a brand name aftermarket infotainment unit
    • A windshield mount GPS navi and an I-POd will serve me just as fine
    • FTMW: This thread delivers !
  • Replies 1.6k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
This MB may be of interest to many of you still selectign parts for your Car PC.
http://www.linuxdevices.com/files/misc/via_pc2500_gos_dev_board-sm.jpg
The gOS Dev Board is a Micro-ATX form-factor Via "PC-1" motherbased on a 1.5GHz Via C7 processor. The board's hardware specs are listed as follows:
  • Processor -- Via C7-D 1.5GHz
  • Chipset -- Via CN700 + VT8237R plus
  • Memory -- 2 x DDRII slots, for up to 2GB
  • Storage:
    • 2 x PATA interfaces (up to ATA133)
    • 2 x SATA interfaces (up to SATA150)
    • Floppy drive interface
    [*]Networking -- 10/100 Base-T Ethernet based on Via VT6103L PHY
    [*]Video -- Via UniChrome Pro IGP (VIA CN700)
    [*]Audio:
    • Based on Realtek ALC655 (supports 6 channels)
    • Connectors -- audio line out/in, mic jack
    [*]Other I/O:
    • VGA out
    • 4 x USB 2.0 ports
    • 2 x PS2 ports
    • Parallel printer port
    • Serial port
    • IR interface
    Expansion:
    • PCI slots
    • CNR slot
    [*]Power:
    • 20-pin ATX power connector
    • +12V 4-pin power connector
    • Supports ACPI S1/S4/S5 mode power management
    [*]Dimensions -- 7.5 x 9.0 inches (190 x 228 mm)
Does anyone have a distribution block type battery terminal with the multiple outputs? Pics? I'm considering getting one to make my setup a bit more clean.
Check out the "RIGrunners" at http://www.westmountainradio.com/.
I know the West Mountain Radio guys personally, and they're great...
When Chuck Norris was born, the only person who cried was the doctor. Never slap Chuck Norris. - E.J.S.
If I were going to do this, I'd really want to try and do a solid-state (no moving parts) storage system. A couple of 4GB or 8GB CFII cards might work. I think I've seen somebody do it somewhere on the Interweb. Extreme temperatures will wreak havoc on spinning disks with a few microns separating head from platter. That concerns me.
________________________________________________ [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1980"]'05 BSM OBXT Row-your-own, W.I.P. :rolleyes:[/URL] [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1242"]'06 Shrek B # 64 - The car the wife loved to hate :( Sold...[/URL]
Well I made it thru a hot summer. Let me see what winter brings. I could live with replacing the hard drive once a year but yes...i would switch to a flash memory at least for the operating system.
You can now get 32GB and I believe 64GB solid state drives. They're available options on the Dell notebooks I order.
Uhh... yeah but (1) they're only availble on selct models and (2) they currently add like $500 or so to the price tag above a more generic build.
I ran my CarPC all through last winter in Albany, NY and all through this summer here as well.
Still running strong. I'm not worried.
Honestly, if it only last two years or so, I can get a new drive. 2.5" HDD's aren't anywhere near as expensive as they used to be AND are much better at handling temperature change and heavy shock than they used to.
Need a CarPC bezel? PM me!
I'm told (though not from an authoritative source) that booting XP does a large number of small disk writes, which will wear out flash memory within a fairly small number of boot cycles. I don't know if "small" is on the order of 5, 50, 500, or 5000, but the guy I talked to said not to bother.
XP-Embedded has a feature called "enhanced write filter" that was added specifically to address this problem. Much as I like the idea of running without disks, I'm going to wait for XPe first.
Agreed.
My cousin works at Microsoft. He said that the reason that solid state storage hasn't taken off is not due to cost (although currently expensive). Longevity is the true reason. Although hard drives may theoretically wear out over time and are suceptible to damage, normal usage does not lower the performance/longevity as it does to solid state/flash storage.
Coming back from stand-by isn't as bad as booting from a cold state, but it still does require those minor writes as well.
Actually I would'nt mind asking him, he's a software engineer. Not on Windws though, he's on the XBox Development Team ;)
There's actually a lot of things built into operating systems that people don't know about. But then again...I don't know about them hah:lol:
The guys at mp3car.com have put together a way to enable EWF on Windows XP. EWF (Enhanced write filter) prevents Windows from writing back to the drive.
That would be sweet. I thought that code wasn't even in XP. Do you have a link? I just spent 15 minutes browsing search results for "EWF" over there and only found stuff about XPe, not straight XP.
I did.
to ground my DSATX power supply
http://aycu12.webshots.com/image/5531/2000966408712862462_rs.jpg
below you can see my old motherboard, I replaced another MB with built in 6150 video, but u have idea how it look like
http://aycu17.webshots.com/image/6576/2000964438465282926_rs.jpg
Thanks to people who help me.. My carpc is running ;)
you can find a very quick 5 step to install in a GT.. with couple of pictures..
http://www.montreal-subaru-club.com/images/mike/carpc/
http://www.montreal-subaru-club.com/images/mike/carpc/screen1.jpg
Free Enguinity Program, for OBD2.. just need the Tactrix cable, and will work without anything else.. more detail in the link (top of the topic)
http://www.montreal-subaru-club.com/images/mike/carpc/enginuity1.jpg
Mike Moffa
Founder / Admin
Montreal Subaru Club
Is that PC one of these http://minipc.aopen.com/Global/spec.htm
Quick question - surely addressed before...so go ahead and kill the n00b.
I would like to start the DATA LOGGER in ENGINUITY directly - without going thru the main screen then clicking the Logger shortcut.
I have a car pc installed in my car and I love the "dashboard" one of the better ones out there - and there's no need for ELM scan and other tools. I can embed ENginuity in Centrafuse (my front end software) with no problems, but it would be awesome if my touchscreen shortcut tok me directly to the data logger. Any way of doing that ? Thanks.
