Most modded / fastest OB?
  • 4 months later...
  • Replies 215
  • Created
  • Last Reply
Latest edition....seam ripped the tweed out, and had the wife sew in matching blue alcantara.
My wife did the sewing for me by making a pattern off the tweed fabric and then just put it all back together
Bottom cushion installed now for the top
http://gallery.me.com/gregnauman/100042/IMG_0438/web.jpg?
http://gallery.me.com/gregnauman/100042/IMG_0441/web.jpg
  • 4 months later...
Well here is an update..... The motor was installed and I picked it up on Aug 26th from Cobb Plano. Motor built by them and Watt Bingham from Watts Shop
It was run on the dyno for 20-30 miles up and down the RPM range for 1.5 hours to break the motor in.
STI Block, STI Forged Crank, Crower/Cobb Rods, ARP Rod bolts, STI Bearings, JE Forged Pistons, STI 11mm Oil pump, Killer B P/U Tube, ARP Head Bolts
I drove it home and the following Saturday put my 08 STI 6 speed, Clutchmasters FX300, DCCDpro, R180 Diff, Spec B STS, group N mounts, kartboy shifter bushings.
So Car on the road and going back to Cobb for Final tune mid october.
  • 2 weeks later...
My previous turbo setup was a GT2876 (one larger than his current turbo) and I only netted 330hp. It was a crap setup, but still. I don't think his 2871 will do 100hp more than my 2876 did.
but like I mentioned before... he is on a mustang and I'm on a dyno dynamics
E85 is much more tolerant of heat. The difference from a TMIC and a FMIC on e85 everything else the same is going to be a lot smaller than you are expecting.
(Updated 8/22/17)
2005 Outback FMT
Running on Electrons
not unless he gets a bigger turbo.... but it is a mustang
Should be 380/430 to wheels on E85 if the past tunes with my setup hold true.
But that is still not as much as you at the altitude in Colorado.
Im happy with my results though so no need to go more, although my new motor could handle it.
I never intended to get this intense with my car but after 160K I just decided to keep the car instead of buying new and put in the 6 speed with the built motor.
I drive it every day as well
Mine dynod a blistering 226 whp and 271wtq on a dynocomp which read really low. My buddy also dynod 226 but then 255 on a different dyno but i forget which one.
Im .2 slower than 2 stage 2 sti's at the sacramento drags.
Can i claim fastest outback in california? :) or is there someone faster.
  • 5 weeks later...
Ran into a bit of a snag tuning it last weekend. The injector duty cycle was around 97% when we investigated the problem we found that the stock fuel pump control module only puts out 11.75 volts to the pump.
We will be swapping in an 06-07 STI fuel pump control module as we verified it will output 13.7 which causes the IDC to drop to 80%
I put down 362/415 to the wheels with the FMIC and the tune wasn't even close to being done. Hopefully Ill be close to my goal of 380/440
  • 4 weeks later...
I just got back this past Sunday Nov 14th for my updated Dyno Tune at Cobb Tuning in Plano TX. with the newly built motor 08 STI 6 speed and FMIC.
385 whp (E85) FMIC
423 wtq (E85) FMIC
347 whp (93) FMIC
360 wtq (93) FMIC
Updated new numbers and added new graph as well as temp etc.....
New Tune with FMIC, Grimmspeed Ported manifold and HF crosspipe, Aeromotive Fuel Pump, Aeromotive FPR, STI Fuel Pump Control Module
6 speed, R180 3.90
http://gallery.me.com/gregnauman/100026/Image/web.jpg?
Old Tune with TMIC, 5 speed, R160 4.44
http://gallery.me.com/gregnauman/100026/Nauman-20AVO-20380-20Dyno-20Graph/web.jpg?
Car: 2005 Outback XT
Tuner: Calvin Dotson Cobb Tuning Plano TX
Dyno Info: Mustang
Temp: 65-70
Sea Level: Aprox 900-1000 FT
Fuel: 93/E85 105 octane
PowerTrain:
Tuned by Calvin Dotson Cobb Tuning Plano TX
Cobb Ver 2 AP w Access Tuner Race
350 whp (E85) TMIC 385 whp (E85) FMIC
373 wtq (E85) TMIC 423 wtq (E85) FMIC
304 whp (91) TMIC 347 whp (93) FMIC
317 wtq (91) TMIC 360 wtq (93) FMIC
AVO380 (Garrett 2871r)
AVO Wastegate Actuator
Cobb Turbo Heat Shield
Prodrive EBCS
AVO FMIC
Perrin Signature Series Recirc BOV
AVO Throttle Body Hose
AVO Cold Air Intake
Aeromotive Stealth 340 LPH Fuel Pump
Aeromotive Fuel Pressure Regulator
07 STI Fuel Pump Control Module
ID 1000cc Top Feed Injectors and Conversion (Bosch)
Custom Y Feed Fuel Lines
Cobb Catted DownPipe 3" with flex and taper removed DEI Wrapped
Cobb Lightweight Crank Pulley
Grimmspeed UP DEI Wrapped
Grimmspeed Ported Exhaust Manifolds
Grimmspeed High Flow Crossover DEI Wrapped
Grimmspeed AOS
Autospeed Catback 3" Exhaust
Gates Racing Blue Timing Belt
Gates Racing Blue Radiator Hoses
Cobb Radiator Shroud
Braille B3121 Light Weight Battery
Rotella T6 5w 40 Synthetic
Cobb Stage 2 Motor- Cobb/Watt Built:
07 STI Block, 07 STI Forged Crank, JE 2618 Forged Pistons
Cobb/Crower Rods, STI 11mm Oil Pump, Killer B P/U Tube
STI bearings, ARP Rod and Head bolts,
DriveTrain:
08 STI 6 Speed
DCCDPro DCCD Controller
08 STI DCCD Switches
07 STI R180 Torsen
08 Spec B Rear Axels
STI Spec B Short Throw Shifter
Kartboy Shifter Bushings
STI Group N Tranny Mount
STI Group N Motor Mounts
Clutch Masters HD Pressure Plate
Clutch Masters FX300 Kevlar Disc
08 STI Flywheel
Subaru Extra-S gear oil F&R
Suspension:
Cobb Rear Sway Bar
Cobb Front Sway Bar
Cobb Sway Bar Bushings F/R
Kartboy Endlinks F/R
AVO Offset Control Arm Bushings
BC/BR Racing Coilovers Lowered 1.5"
Brakes:
Wilwood Superlight 4 Pot Front Brake Calipers
LGT Rear Brake Calipers
Hawk HPS Pads F/R
DBA 4000 Slotted Rotors F/R
Technafit SS Brake Lines
Motul RB600 Fluid
Audio:
2007 Spec B Radio MP3, Aux Input, Satellite Control
2007 Spec B Console Cubby Aux input for Iphone
Subaru Sirius Satellite Radio Module
Subaru Factory under seat Sub Woofer
Interior:
STI Pedals
STI 3 Gauge Pack in Cubby
STI Front Seats 04
STI Alcantara in Rear Seats
Cobb Shift Knob
STI DCCD Controls
Auto dimming Homelink Mirror
Innovate LC-1 Wideband
Passport X50
ProClip Iphone Holder
TomTom App iPhone
Exterior:
Window Tint Front 35% Rear 20%
Volt HID Kit with DRL Disabled
Toshiba HIR High Beams
STI Badge
JDM Outback Bumper with Exhaust Cutouts
Legacy GT Rear Bumper Beam
Michelin Pilot Sport A/S Tires
06-07 WRX Wheels
Those numbers are impressive (I know Mustang reads higher, but still). Just so I can contextualize it, do you know approximately what your 0-60 times are now?
No the Mustang is a LOWER reading dyno. Dynojet is the HIGHER reading dyno.
Others that have had same turbo were able to do around 4 flat 0-60
according to LBGT and seeeeya
Thank you for correcting me. I don't know why I switched them up. Very nice numbers.
Do you have an overall goal you are working towards with the car? Quarter Mile? Track? Or are you just making it awesome"?
