rtbrjason Posted May 18, 2009 Share Posted May 18, 2009 You can change the nav to display in KM or Miles on mine. There don't seem to be any settings that address Farenheit/Celcius for temp display, or the miles listed in the driver information readout. Link to comment Share on other sites More sharing options...
camber Posted May 19, 2009 Share Posted May 19, 2009 sorry but you recall incorrectly. Canadian models are metric, US models are imperial. you cant change it thru the menu. Apparently, my memory must be betters then your! j/k Or something changed for 2009(because you can do it on 2006, 2007, 2008) but there wasn't any hardware part number changes. Maybe you have version 3 disks and they changed? Anyways.... menu (Navigation button bezel, the rest are nav screen software buttons) -> Navigation Set Up -> User Settings -> Distance (Km/h or Miles option) See Photograhical evidence below Link to comment Share on other sites More sharing options...
Whatisit Posted May 19, 2009 Share Posted May 19, 2009 i was refering to the ferenhight/celcious, and how those cannot be changed. Link to comment Share on other sites More sharing options...
camber Posted May 19, 2009 Share Posted May 19, 2009 i was refering to the ferenhight/celcious, and how those cannot be changed. My bad... It's just that you quoted my post where I was referring to a post, that was a response to a post the about speed units. Anyways, FWIW the temperature unit is an ECU calculation that is sent to the NAV/information/dash panel. Therefore, I'm guessing a celcius ECU would display celcius temperature in the NAV. Although, I'm unsure what determines the unit that is displayed on the NAV. Maybe the NAV hardware/firmware is smart enough to know when its getting a celcius or farenheit reading? Link to comment Share on other sites More sharing options...
politby Posted May 20, 2009 Share Posted May 20, 2009 Whoa.. Whoa.... IIRC, the US and Canadian model are exactly the same. You can select metric or imperial units in the menu. It's not hard coded metric or imperial. Are you sure you are not referring to units in the navigation system? Those are certainly user settable, but as far as I know there are no units/language settings for the functions built into the display units - trip computer, service menu, etc. Link to comment Share on other sites More sharing options...
zmarko Posted July 5, 2009 Share Posted July 5, 2009 I know I'm bumping an old thread, but I just stumbled upon this on iwsti.com and remembered members here trying to get gauge readings on their NAV. http://www.blitzperformancesales.com/products/r-vitds/r-vitds.html Link to comment Share on other sites More sharing options...
Gator GT Posted July 5, 2009 Share Posted July 5, 2009 ^^^ very interesting zmarko. Could compliment the existing gauges someone has, like Oil Pres, Oil Temp and EGT....as this unit doesn't have those capabilities. "If we are to guard against ignorance and remain free, it is the responsibility of every American to be informed." - T. Jefferson Link to comment Share on other sites More sharing options...
strife1012 Posted July 5, 2009 Share Posted July 5, 2009 Looks nice, funny how its showing in a Legacy.Did anyone find a price for it? Link to comment Share on other sites More sharing options...
zmarko Posted July 5, 2009 Share Posted July 5, 2009 Looks nice, funny how its showing in a Legacy.Did anyone find a price for it? Someone mentioned on iwsti that it's like $500. Link to comment Share on other sites More sharing options...
fermau Posted January 27, 2010 Share Posted January 27, 2010 sorry for taking so long guys but now i'm back with some news. I managed to change my outback EU display with a US one. I confirm both video and backup camera works fine. I unfortunately cant find a gray wire to ground for video in motion mod....any idea ?Or can you just tell me...which pin is it ? Second things...about imperial-metric c-f temperature...you can set imperial and metric into the naw,but till now, i've not find a way to set it on the ecu.So temperature is displayed in F and everithing is in miles and gallons. Dunno if i can swap some pieces of my old monitor into the new one to set it on metric - Celsious...any idea ?thanks Link to comment Share on other sites More sharing options...
fermau Posted January 28, 2010 Share Posted January 28, 2010 lil update... sorry but in the night i did not found out it but now i did i found the gray wire so the in-motion vid mod its possible. I've another problem now and its that when my nav voice talks, it shut-off both radio and climate control, thats pretty weirdo...i think its some muting function thats not working. Is there a way to fix it..cutting the mute wire or bridging it ? another thing...which is the pinout of the 3 connector on the nav display ?any pinout ?thanks. Link to comment Share on other sites More sharing options...
fermau Posted January 28, 2010 Share Posted January 28, 2010 This is probably stupid but I have a question... Has any tried to get into the Diagnostic menu according to the instructions? It looks like the default password is 014220. It is accessed by pressing for 5 seconds or more on the top center portion of the screen. They probably changed the default password, but I thought I would ask anyway. Can you help me accessing the diag menu ? Do you do it with engine on or off ?Where exaclty you press...and in which menu..map..nav...consumption...info...where ?thanks. Link to comment Share on other sites More sharing options...
fermau Posted January 29, 2010 Share Posted January 29, 2010 i was trying to find out while when my navi talks me (vocal guidance) it shut off both my climate control and my radio..that turn back on as soon as the navi does not talk (i can't hear the voice thoug..i know that the problem is while it talks cause if i push the screen button with the speaker to test audio..it does the problem). So it seems like there are some pin that are different. Looking at the schemes i've found in the forum http://files.l33t.net.au/servicemanuals/FGZ201_Service_Manual.pdf http://files.l33t.net.au/servicemanuals/FGZ000UF2_Service_Manual.pdf i've seen that on page 2 , where theres the diagram with pinouts, i've found out that the J803 connector , pin from 17 to 36 , Both connector on both units got the same pinout , FGZ201 and FGZUF2 , apart from 3 pins 32-33-34 that are a-out-R / a-out-gnd / a-out-L on the FGZ201 ...have those pins (32-33-34) instead the FGZUF2 does not have those pins (32-33-34) Since i've those pins connected, and since those pins are related to audio, maybe this is the problem. Do you think cutting those 3 wires will fix my problem ? How can i identify exactly the pin/wires to cut looking at the connector from the hole parts...with the "retention-clip" downside ? Or easily..i attach the pic of the connectors. Its the 20 pins one...the smaller one...can u pls mark me pin 1-2-3 so than i figure out how to count them ?thanks. Link to comment Share on other sites More sharing options...
mikefoy6 Posted February 27, 2010 Share Posted February 27, 2010 Molex Connector PinOut for 08 Spec.B, may be the same for others: http://www.legacygt.com/forums/showthread.php?t=132007 Link to comment Share on other sites More sharing options...
GoRilla Posted February 28, 2010 Share Posted February 28, 2010 I'm just guessing, and it's probably been stated already, but arent we going to have to CHOOSE a video input, as there is only one aux input in the back? Maryland's Suby friendly Realtor. My favorite suby shop: http://www.IAGPerformance.com Link to comment Share on other sites More sharing options...
DocHolladay23 Posted February 28, 2010 Share Posted February 28, 2010 only 1 input in the 06, I'm sure the 08 is the same [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
Windy Road Posted March 1, 2010 Share Posted March 1, 2010 Correct all screens have one input. You can have a switch box with multiple inputs and just pick which one you want to use. Or what I did was run a RCA cable from the screen down under the center console to underneath the passenger seat so I can plug in what ever I want. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
GoRilla Posted March 1, 2010 Share Posted March 1, 2010 I think I'd be Ok with just the reverse cam. We need a full write up. Maryland's Suby friendly Realtor. My favorite suby shop: http://www.IAGPerformance.com Link to comment Share on other sites More sharing options...
DocHolladay23 Posted March 1, 2010 Share Posted March 1, 2010 It's pretty easy, you either have to remove the stereo or the screen, I had the stereo out when I did it and I just reached behind the screen, felt the input and plugged an RC cable into it. I ran that under the center console and and popped it out on the side to go under the passenger seat like Windy Road did. once it's plugged in you just hit the info button twice and it'll switch to the RCA. The parking brake needs to be up at that point, but if you remove the nav screen you can ground the parking sensor wire and it'll work at all times, even when the car is in motion. [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
Vwown3d Posted March 2, 2010 Share Posted March 2, 2010 I'm just guessing, and it's probably been stated already, but arent we going to have to CHOOSE a video input, as there is only one aux input in the back? Not true. On the newer models you have a video and the 4 pin reverse camera that can be a second. For the reverse camera input you: 1. Get molex plug. 2. Connect whatever video you want to the 2 pins 3. Find reverse signal wire in pass. side foot space, Trace all the way to teh nav system 4. cut wire, measure what type of signal it gives the nav to switch it over to display the video input. 5. Connect nav end to a switch to supply in with said input signal. 6. Now you have a second input that you can activate with the flip of a switch. 2 video inputs. i'm running a HKS camp2 on the "info" input and am finishing wireing up a video ipod on the reverse camera input. Link to comment Share on other sites More sharing options...
finse Posted March 2, 2010 Share Posted March 2, 2010 Not true. On the newer models you have a video and the 4 pin reverse camera that can be a second. For the reverse camera input you: 1. Get molex plug. 2. Connect whatever video you want to the 2 pins 3. Find reverse signal wire in pass. side foot space, Trace all the way to teh nav system 4. cut wire, measure what type of signal it gives the nav to switch it over to display the video input. 5. Connect nav end to a switch to supply in with said input signal. 6. Now you have a second input that you can activate with the flip of a switch. 2 video inputs. i'm running a HKS camp2 on the "info" input and am finishing wireing up a video ipod on the reverse camera input. Nice! I would like to get the HKS camp2, looks like a fantastic unit!! Link to comment Share on other sites More sharing options...
GoRilla Posted March 2, 2010 Share Posted March 2, 2010 Where are you located on the east coast? Wanna help a brotha out. Not true. On the newer models you have a video and the 4 pin reverse camera that can be a second. For the reverse camera input you: 1. Get molex plug. 2. Connect whatever video you want to the 2 pins 3. Find reverse signal wire in pass. side foot space, Trace all the way to teh nav system 4. cut wire, measure what type of signal it gives the nav to switch it over to display the video input. 5. Connect nav end to a switch to supply in with said input signal. 6. Now you have a second input that you can activate with the flip of a switch. 2 video inputs. i'm running a HKS camp2 on the "info" input and am finishing wireing up a video ipod on the reverse camera input. Maryland's Suby friendly Realtor. My favorite suby shop: http://www.IAGPerformance.com Link to comment Share on other sites More sharing options...
burlock Posted May 4, 2010 Share Posted May 4, 2010 So we still have nothing about getting boost to display instead of fuel consumption? Is this the only option for our Spec.B's? http://www.blitzperformancesales.com/products/r-vitds/r-vitds.html Has anyone tried this product? Thanks, Link to comment Share on other sites More sharing options...
dr_sharp Posted May 6, 2010 Share Posted May 6, 2010 That's pretty slick... haven't seen that before, thanks for posting. lol Link to comment Share on other sites More sharing options...
SubLo Posted May 7, 2010 Author Share Posted May 7, 2010 Oh wow! That looks like the perfect solution! I may cave and buy it!!! Thans burlock! ________________________________________________ [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1980"]'05 BSM OBXT Row-your-own, W.I.P. :rolleyes:[/URL] [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1242"]'06 Shrek B # 64 - The car the wife loved to hate :( Sold...[/URL] Link to comment Share on other sites More sharing options...
