subarunoob Posted February 7, 2023 Share Posted February 7, 2023 I have recently purchased the lovely Subaru liberty GT wagon, yesterday I wanted see the state of my air filter, opened it up looked clean enough put it back in. After I started the car and drove down the road I noticed a solider check engine light was on, cruise control flashing and I was stuck in sports mode (besides that I noticed no difference in how the car ran). Speaking to my friend that's a mechanic he suggested looking at the airfilter box and make sure it's properly sealed which it wasn't. Put it together properly and the check engine light is still on so my friend suggested disconnecting the battery terminals and waiting an hour. This doesn't clear the code so I then take it to get scanned, unfortunately the scanner is now unable to communicate with the car through the OBD2 port and the guy from supercheap auto said something about not picking up voltage at the port(starting the car and it still seems to run with out any issues). Does anyone have any suggestions on why there's no voltage at the OBD2 port. Also I'm incredibly sorry if I've done anything wrong I'm very new to this kind of thing! Link to comment Share on other sites More sharing options...
silverton Posted February 7, 2023 Share Posted February 7, 2023 the OBD ports can be finnicky, I have hit or miss luck with connecting scan tools to some cars and have to keep tension on the connector or it will disconnect, etc. Link to comment Share on other sites More sharing options...
TorqueLegend Posted February 7, 2023 Share Posted February 7, 2023 Could try to use a different brand OBD. Link to comment Share on other sites More sharing options...
subarunoob Posted February 21, 2023 Author Share Posted February 21, 2023 UPDATE: Tried a different scan tool and that did the trick, cleared the code and it hasn't come back. Link to comment Share on other sites More sharing options...
silverton Posted February 21, 2023 Share Posted February 21, 2023 But....what was the code? Link to comment Share on other sites More sharing options...
m sprank Posted February 21, 2023 Share Posted February 21, 2023 (edited) Glad you figured it out. Maybe the car threw a P0101 (MAF circuit/range performance) with the air box lid open. Edited February 21, 2023 by m sprank Link to comment Share on other sites More sharing options...
subarunoob Posted February 22, 2023 Author Share Posted February 22, 2023 UPDATE: Tried a different scan tool and that did the trick, cleared the code and it hasn't come back. I can't remember exactly what the code was but had to do with the airfilter sensor Link to comment Share on other sites More sharing options...
KZJonny Posted February 22, 2023 Share Posted February 22, 2023 18 hours ago, subarunoob said: UPDATE: Tried a different scan tool and that did the trick, cleared the code and it hasn't come back. I can't remember exactly what the code was but had to do with the airfilter sensor Not a bad idea to keep track of codes you have then delete in future. May help with further diagnosis here or elsewhere. There are also a couple of codes for our engines in particular which seem harmless enough, but can be indicators of serious problems. Just and FYI. Link to comment Share on other sites More sharing options...
