whitexc Posted October 9, 2021 Author Share Posted October 9, 2021 Teaser.... Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
whitexc Posted October 25, 2021 Author Share Posted October 25, 2021 All parts....save for the catted Cobb DP have been delivered and engine assembly/install should be this week and or next. First tune from Mike @ Tuning Alliance will be loaded into the AP before start up. New fuel pump (AEM 320) going in after the car is up and running (this I will tackle at home). Wrapped the Cobb UP with the 2" Inferno wrap and secured with stainless tie wire & worm clamps. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted October 25, 2021 Share Posted October 25, 2021 Curious to see how the inferno wrap holds up. Link to comment Share on other sites More sharing options...
whitexc Posted October 25, 2021 Author Share Posted October 25, 2021 We said someone had to try it! It can fall off lol....that's fine.....just don't jack the pipe up and render it unusable. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
whitexc Posted October 26, 2021 Author Share Posted October 26, 2021 Used what I had left of the Inferno wrap (only bought the 15' roll) to cover the top portion of the DP. It should help at least. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
whitexc Posted November 9, 2021 Author Share Posted November 9, 2021 (edited) And this folks, is why you don't set off the parts cannon lol. The catted Cobb DP showed up today so I removed the wrap from the 1320 piece and applied it to the Cobb pipe(sorry no pics). Both are nice but I have to say hats off to Cobb. The design and welds are amazing. You get what you pay for stands true here for sure. Hoping the car gets back together in the next week or so. 1320 catless DP for sale. Brand new, even have the box it came in and possibly a Grimspeed adaptor for stock mid pipe. PM for more info. Sent from my SM-G996U using Tapatalk Edited November 9, 2021 by whitexc Link to comment Share on other sites More sharing options...
whitexc Posted November 9, 2021 Author Share Posted November 9, 2021 Can someone verify both the radiator cap and overflow tank cap OEM part numbers that are known to work. I hate to ask but I have read and read and gotten more confused. I searched the latest part numbers I saw and one of them states it will not fit my car. Thanks in advance. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted November 9, 2021 Share Posted November 9, 2021 (edited) FWIW, I have a turbo tank cap from NAPA. It works fine. It's close to the same pressure setting as OEM. In reality there are only a few cap styles. You really don't need OEM in this case. Here's my local dealers parts page, both caps are there. https://parts.suburbansubaru.com/a/Subaru_2009_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/_54102_6023999/ENGINE-COOLING-AT-OIL-COOLER-PIPE/B13-450-06.html Oh, I see the radiator cap is not there. Call your local dealership Parts guy's, they'll have what you need. There are many vendors that can get it for you too. Edited November 9, 2021 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted November 9, 2021 Share Posted November 9, 2021 Ok, so I used the search function, https://parts.suburbansubaru.com/productSearch.aspx?ukey_make=5806&ukey_model=89998&modelYear=2009&ukey_trimLevel=110352&ukey_driveline=53396&searchTerm=radiator%20cap 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted November 9, 2021 Share Posted November 9, 2021 Try this sticky, https://legacygt.com/forums/showthread.php/oem-online-subaru-parts-vendors-list-42243.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted November 9, 2021 Share Posted November 9, 2021 https://www.subarupartsforyou.com/search?search_str=radiator+cap OK, I'll stop now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitexc Posted November 9, 2021 Author Share Posted November 9, 2021 (edited) Thanks Max. I know there are others and mine may not even need replacing at this point but I will while the engine is out. So much reading....it's dizzying at times lol. Edited November 9, 2021 by whitexc Link to comment Share on other sites More sharing options...
Tehnation Posted November 9, 2021 Share Posted November 9, 2021 (edited) I like to verify the part numbers on parts.subaru.com, subarus main site, so if they don't know then who does lol. You put in your exact car details, and it tells you exactly what part you should use for your exact year and model. I go by what subaru says most times when the forums gets confusing. And from subarus site you can see all the old part numbers they may have used in the past, ie the suppressed parts. The turbo reservoir cap Part Number: 45137AE00B Supersession(s): 45137AE00A https://parts.subaru.com/p/Subaru_2009_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/Radiator-Cap-Radiator-Cap/49251974/45137AE00B.html radiator cap Part Number: 45137FE002 Supersession(s): 45137FE000; 45137FE001 https://parts.subaru.com/p/Subaru_2009_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/Cap-Radiator/49251983/45137FE002.html reservoir cap Part Number: 45155AG00A https://parts.subaru.com/p/Subaru_2009_Legacy-25L-TURBO-5AT-4WD-GT-Limited-Sedan/Engine-Coolant-Reservoir-Cap/49252042/45155AG00A.html So any of these parts numbers would work, suppressed or current. The current being the best choice and better or upgraded over the suppressed version. Edited November 9, 2021 by Tehnation Link to comment Share on other sites More sharing options...
whitexc Posted November 9, 2021 Author Share Posted November 9, 2021 (edited) Thanks for the help all. I am a Google'r and that gets us in trouble more often than helping us! Ordered a new coolant pipe for the oil cooler from Napa as this one has seen better days. Another "while you're in there" part. Sent from my SM-G996U using Tapatalk Edited November 9, 2021 by whitexc Link to comment Share on other sites More sharing options...
Max Capacity Posted November 9, 2021 Share Posted November 9, 2021 Nice to know that NAPA has that pipe. How much was it ? I replaced the wagons back when I put the ej257 in, May 2012. I also replaced those hoses. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitexc Posted November 9, 2021 Author Share Posted November 9, 2021 Yeah, it came with the pipe, hose ends and clamps. It was $36. They had to get it from their warehouse but no biggie. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted November 10, 2021 Share Posted November 10, 2021 You may have missed it, but NAPA just got me the PCV tree last week, it had to come from somewhere a couple of days away. It was $12.00. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitexc Posted November 10, 2021 Author Share Posted November 10, 2021 Nice. I just replaced my PCV within about 10k when I did the turbo Inlet. Its in good shape. Holy cow if I'd have known how easy the intake comes off that job would have been cake. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
JoeInOregon Posted November 11, 2021 Share Posted November 11, 2021 And this folks, is why you don't set off the parts cannon lol. The catted Cobb DP showed up today so I removed the wrap from the 1320 piece and applied it to the Cobb pipe(sorry no pics). Both are nice but I have to say hats off to Cobb. The design and welds are amazing. You get what you pay for stands true here for sure. Hoping the car gets back together in the next week or so. 1320 catless DP for sale. Brand new, even have the box it came in and possibly a Grimspeed adaptor for stock mid pipe. PM for more info. Sent from my SM-G996U using TapatalkMay I ask why you went with the Cobb over the 1320, I have a 1320 waiting to go on..... I was hoping for an invidia downpipe but no one is selling the catless version anymore , guess I could have gutted a cobb or other bit seemed like a waste Sent from my Pixel 3a using Tapatalk Link to comment Share on other sites More sharing options...
whitexc Posted November 11, 2021 Author Share Posted November 11, 2021 I wanted a catted pipe. I ordered the Cobb and the lead time was pretty far out. I bought the 1320 piece to get the car rolling.....and here's to life and projects lol. The Cobb piece showed up. I wouldn't hesitate to run the 1320 piece, especially for the price. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
whitexc Posted December 6, 2021 Author Share Posted December 6, 2021 Cple pics of the engine mostly together and headed back in the car with the new Group N mounts and pitch stop. Waiting on a response from Crawford regarding a bracket that is available when mounting their AOS in a Legacy. Aside from that it shouldn't be long now. First map from Mike at TA is loaded up and ready in the AP3. I did email TurboXS about a midpipe/y pipe combo they sell (their axle back kit is on the car) but haven't heard back on that either. I figured those are the only two original exhaust pieces left aside from the manifold. Might as well go all in. Sold my factory DP on bookFace to cover my new Cobb DP plus a little so that worked out. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted December 6, 2021 Share Posted December 6, 2021 Did you think to test fit the tmic before you dropped the engine in the car ? I hope you got a good price for the stock DP. I got $900 for mine Sept 2020, they are worth much more now at the recylers. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitexc Posted December 6, 2021 Author Share Posted December 6, 2021 If you recall I am not performing this transplant. Home life and this project were not aligned. Is there something to look for? Everything Intercooler, inlet, bpv is all stock(bulletproofed). Original turbo massaged by JMP. It should all go back together the way it is supposed to I would guess. The DP fetched a fair dollar and the good part is it is being used on another LGT and not scrapped. I was offered about the same by two local scrappers and am happy it went to a subie home. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted December 6, 2021 Share Posted December 6, 2021 If the turbo was taken apart, the clocking may not be exact. I also hate that stock tmic locating and TB hose. There may have been play in the mounting of all the pieces that set where the top of the up pipe is located and angled. All those things create a compound of tolerances that may be an issue. I test fitting mine before dropping the engine in back in May 2012. Just because to me, it was easier to make adjustments if needed with the engine on the stand. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitexc Posted December 6, 2021 Author Share Posted December 6, 2021 Good call. I plan to stop by tomorrow and see how things look. I will follow up. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
