Max Capacity Posted July 27, 2020 Author Share Posted July 27, 2020 Update, Joint was installed. On the drive home from work today, no shimmy. Outside air temp 100F most of the way. Speed was 68-well I'll admit to 75...LOL, four different highways. No Shimmy. I'll be watching over the next few day's and let you know if/when something changes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted July 27, 2020 Share Posted July 27, 2020 damn I wish I got this in before i dropped in the motor, installed motor on a sunday part came on monday, was supposed to come on saturday, so had no choice. this is gonna be a bitch... How was the steering response and feel? Did it feel different? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 27, 2020 Author Share Posted July 27, 2020 Yes, the steering does feel a little tighter, quicker. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pleides Posted July 28, 2020 Share Posted July 28, 2020 So, forgive me as I haven't been able to piece together what all has happened here: Did you buy the STi steering rack and put in that joint and solve your problem? Link to comment Share on other sites More sharing options...
Max Capacity Posted July 28, 2020 Author Share Posted July 28, 2020 So, forgive me as I haven't been able to piece together what all has happened here: Did you buy the STi steering rack and put in that joint and solve your problem? After replacing the leaking rack with a OEM style replacement the shimmy was still there. The ebay STI solid joint has seemed to make the biggest difference in stopping the shimmy. Look into buying a 2015-2020 STI solid joint, they may be longer ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Enlight Posted July 28, 2020 Share Posted July 28, 2020 This is inspiring me to install the Perrin lockdown I already have lying around. Encouraging sign you identified the source, Max. muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
Tehnation Posted July 28, 2020 Share Posted July 28, 2020 (edited) makes sense, the extra slop in the steering can go both ways, so the shimmy is coming from the extra motion on the damper, the wheels are moving but the damper eats it before getting to the steering wheel. with the solid joint its able to stabilize by holding onto the steering wheel. Maybe that damper is a part that wears out faster than we think, and is just overlooked. Edited July 28, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Max Capacity Posted July 28, 2020 Author Share Posted July 28, 2020 makes sense, the extra slop in the steering can go both ways, so the shimmy is coming from the extra motion on the damper, the wheels are moving but the damper eats it before getting to the steering wheel. with the solid joint its able to stabilize by holding onto the steering wheel. Maybe that damper is a part that wears out faster than we think, and is just overlooked. That's how my mine assumes too. Time will tell. I also add, one reason I love the wagon so much is the radio. IMO the stock radio with the Sub and Mid-range kit, sounds wonderful. The entire car feels like it is filled with sound. Others have said it has something to do with the sound chamber effect of the wagon. The Spec B just doesn't do that, no matter how much I play with the settings. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted July 28, 2020 Author Share Posted July 28, 2020 Day 2. 50 miles of driving at or above 68mph, no shimmy. I even changed lanes on the different highways to see if there was any difference. I'd have over 100 miles, but the drive to work is slow...no hurry to get there... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Febreze Mee Posted July 29, 2020 Share Posted July 29, 2020 This is great news! I, personally, haven't noticed a shimmy with my car. I don't remember if I noticed one before or after the Perrin steering lockdown kit. However, I'll probably be grabbing one of the STi solid joints for when I do get around to replacing my steering rack. MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted July 29, 2020 Author Share Posted July 29, 2020 This is great news! I, personally, haven't noticed a shimmy with my car. I don't remember if I noticed one before or after the Perrin steering lockdown kit. However, I'll probably be grabbing one of the STi solid joints for when I do get around to replacing my steering rack. Try and get a 2015-2020 STI joint so we can confirm if it is longer. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Febreze Mee Posted July 29, 2020 Share Posted July 29, 2020 Boom. Ordered. It is on back order, so no telling when I'll get it. Can you believe that some of the Subaru parts sites are selling this solid u-joint for $202?! That is absurd! I ordered a 2015-2019 STi solid steering u-joint. #PN here: 34170VA030 Ordered through here: https://subieautoparts.com/product/2015-2019-subaru-wrx-sti-steering-linkage-assembly-knuckle-34170va030/ MILKRUN - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted July 29, 2020 Share Posted July 29, 2020 (edited) i measured mine laying straight, its about 8 5/8", 22.3cm-22.4cm, 223mm-224mm long. Edited July 29, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Max Capacity Posted July 29, 2020 Author Share Posted July 29, 2020 i measured mine laying straight, its about 8 5/8", 22.3cm-22.4cm, 223mm-224mm long. Show off, Which year, I think yours is the same as mine, 2005-2014 ? I see it in post #168. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted July 29, 2020 Share Posted July 29, 2020 lol , yea 2005-2014 , same as yours . Link to comment Share on other sites More sharing options...
Max Capacity Posted July 29, 2020 Author Share Posted July 29, 2020 I'll say it was nice to leave work get on the highway, get up to 70mph in a spot where it would always shimmy...and now I get...nothing. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Enlight Posted August 5, 2020 Share Posted August 5, 2020 Still holding? muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2020 Author Share Posted August 6, 2020 Yes , worked well last time driving home on the highway. Home now because of the damages from the hurricane Isaias . Work has been closed for two days including tomorrow. That's unheard of. I also retire on Friday. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Infosecdad Posted August 6, 2020 Share Posted August 6, 2020 Yes , worked well last time driving home on the highway. Home now because of the damages from the hurricane Isaias . Work has been closed for two days including tomorrow. That's unheard of. I also retire on Friday. Congrats! Link to comment Share on other sites More sharing options...
Enlight Posted August 6, 2020 Share Posted August 6, 2020 Congrats! muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
Tehnation Posted August 6, 2020 Share Posted August 6, 2020 Congrats! What are your plans? Take it easy or find something to do or another job, maybe a lil of both? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2020 Author Share Posted August 7, 2020 Thanks, got power back a few hours ago. Just in time for the last wake up for work. Don't plan to to much but enjoy life. I will ski more this during Winter...we'll see how that works out this season...in these crazy times. I do have lots of projects around the house. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
subisubisu Posted August 7, 2020 Share Posted August 7, 2020 Thanks, got power back a few hours ago. Just in time for the last wake up for work. Don't plan to to much but enjoy life. I will ski more this during Winter...we'll see how that works out this season...in these crazy times. I do have lots of projects around the house. Great news! Congratulations and enjoy! Link to comment Share on other sites More sharing options...
jaylew Posted August 7, 2020 Share Posted August 7, 2020 Congrats on retirement...just in time to enjoy the 'no front end shimmy' more! Now that you won't be driving to work in the wagon everyday, this will allow other 200k+ wagon owners to catch up to you Wagon is LIFE! - 265,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
Max Capacity Posted August 7, 2020 Author Share Posted August 7, 2020 Congrats on retirement...just in time to enjoy the 'no front end shimmy' more! Now that you won't be driving to work in the wagon everyday, this will allow other 200k+ wagon owners to catch up to you Yes, it will. LOL. Looking forward to being able to sleep late, this getting up at 4:40AM to be to work at 6:30 is getting old. It was nice on Friday's in Winter when I could get a jump on traffic going to VT every Friday evening for skiing. Now I'll be coming home from VT on Friday's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
