pksystems Posted May 15, 2023 Share Posted May 15, 2023 Pretty much finished installing everything in engine bay. Just need some fluids and an accessory belt cover. Might make one if I cant find one. I'll need to bleed the brakes, so I figured I would make a power brake bleeder with junk I had lying around garage. Air compressor set to low pressure with an inline filter and the cap of my old reservoir with some fittings/washers/o-rings. 6 Link to comment Share on other sites More sharing options...
NORULZleggy Posted May 15, 2023 Share Posted May 15, 2023 08+ STI Black Calipers do not fit the rear 2005-6 LGT with KNS brackets So I had an interesting day at the shop Getting my 08+ STI brakes installed. First It's a shame my Enkie 17x8s will not fit and I have to sell them (I never liked them, and they have 600 miles on the setup) do not fit so I have to put on my nice Gold wheels which I love! So for those who want to do it right, the fronts will bolt up, but the rear 08+ with KNS brake brackets or other brackets on the market we tried do not fit. the reason why is because it needs to be the calipers that are gold from a GR chassis car not a GD for the 05-06 LGT. So I have my fronts on the car, and they are working so damn well, but the shop called another shop, and they have a massive CNC machine and are going to custom make the brackets so I can fit the black STI calipers to the car with ease. The reason for this is because the holes do not line up. You can cut corners and do the ghetto way, but these are brakes for your car not a 10 speed bike. I did call and talk to KNS brakes while I was at the shop, and they told me I bought the wrong calipers and we all laughed and said you did not do good R&D because these do not make it so you can fit 08+ calipers to the rear of a legacy. Also this shop does these conversion all the time and mentioned there is no such thing as the wrong calipers. 2 Link to comment Share on other sites More sharing options...
SilentJ20 Posted May 15, 2023 Share Posted May 15, 2023 Simple one the other day. AC would only cycle on for a minute and then peter out. Replaced the relay under the hood. Good as new. 1 Link to comment Share on other sites More sharing options...
KZJonny Posted May 15, 2023 Share Posted May 15, 2023 13 hours ago, pksystems said: Pretty much finished installing everything in engine bay. Just need some fluids and an accessory belt cover. Might make one if I cant find one. I'll need to bleed the brakes, so I figured I would make a power brake bleeder with junk I had lying around garage. Air compressor set to low pressure with an inline filter and the cap of my old reservoir with some fittings/washers/o-rings. I was thinking about doing this for the clutch MC… If this method works well for brakes, please do report back. How much pressure are you feeding in? I would think you’d only need a couple pounds… Link to comment Share on other sites More sharing options...
KZJonny Posted May 15, 2023 Share Posted May 15, 2023 Finished removing the filter from the drivers side OCV oil feed on the block. Did this using the Hammrdown method which does not involve removing all the timing. (Did the full timing system at the end of last summer, and did not want to pull all of that apart again….) I don’t wish that particular job on anyone who does not have pretty small hands and somewhere to destress where nobody can hear you. Hah! There was a filter in there, which was the last one in the car, all the others being fairly easy and removed right after I bought the car. On the plus side it was very clean, but I was worried about it being dirty from potential PO abuse. If it ever has to come out again, at least the bolt head is shaved down and I’ve got a 17mm wrench that has a severe haircut to fit the space. Happy it’s a job you really only need to do once. 4 Link to comment Share on other sites More sharing options...
tysparks81 Posted May 16, 2023 Share Posted May 16, 2023 On 5/15/2023 at 9:57 AM, NORULZleggy said: 08+ STI Black Calipers do not fit the rear 2005-6 LGT with KNS brackets So I had an interesting day at the shop Getting my 08+ STI brakes installed. First It's a shame my Enkie 17x8s will not fit and I have to sell them (I never liked them, and they have 600 miles on the setup) do not fit so I have to put on my nice Gold wheels which I love! So for those who want to do it right, the fronts will bolt up, but the rear 08+ with KNS brake brackets or other brackets on the market we tried do not fit. the reason why is because it needs to be the calipers that are gold from a GR chassis car not a GD for the 05-06 LGT. So I have my fronts on the car, and they are working so damn well, but the shop called another shop, and they have a massive CNC machine and are going to custom make the brackets so I can fit the black STI calipers to the car with ease. The reason for this is because the holes do not line up. You can cut corners and do the ghetto way, but these are brakes for your car not a 10 speed bike. I did call and talk to KNS brakes while I was at the shop, and they told me I bought the wrong calipers and we all laughed and said you did not do good R&D because these do not make it so you can fit 08+ calipers to the rear of a legacy. Also this shop does these conversion all the time and mentioned there is no such thing as the wrong calipers. Can you put the KNS beside the one the shop makes to see how off the +08 calipers are as well as measurements please and thank you. I don't personally need them but this might help the community when someone buys the +08 calipers. #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
SubOperator Posted May 16, 2023 Share Posted May 16, 2023 No today but on Saturday. The morning looked like this: and then like this: Got eh front SS brake lines installed fairly quickly and painlessly: Then went to shocks. Got the two bolts out and they were in no shape to be put back in with the new shocks.It's been only 13 years since I put them back in, Subaru quality is not good (/sarcasm). While trying to put the left assembly back on temporarily with old bolts, pulled the CV axle out of the inner joint, and it would not go back no matter what we did. it is Mike HAMMERDOWN's old CV axle and it was already a reman from NAPA at that. Was loose when I got Mike's car and I only put it in "for now" while I was going to reboot my original CV axle. I think that should have been 5-6 years ago. Ordered new strut bolts for front and rear, new boots (inner/outer) for my CV axle. Rocking Tribeca and my son's 2012 Crosstrek in the meantime. 11 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K 2007 B9 Tribeca Limited DGM - 272K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
amm203 Posted May 17, 2023 Share Posted May 17, 2023 (edited) 5 year old Hayden 676 tranny cooler is leaking at the barb fittings. Does not appear to be a clamp issue. Not bad for a $35 part. Identical replacement is going in this weekend alongside an oil change. Planning to put Berryman B-12 Chemtool in the tank and run it close to E before I change the oil Sunday. Is this still a good idea to give the fuel system a bit of a clean? I recall JMP speaking highly of it. I'm running ID1050Xs FWIW. Edited May 17, 2023 by amm203 Link to comment Share on other sites More sharing options...
KZJonny Posted May 17, 2023 Share Posted May 17, 2023 1 hour ago, amm203 said: 5 year old Hayden 676 tranny cooler is leaking at the barb fittings. Does not appear to be a clamp issue. Not bad for a $35 part. Identical replacement is going in this weekend alongside an oil change. Planning to put Berryman B-12 Chemtool in the tank and run it close to E before I change the oil Sunday. Is this still a good idea to give the fuel system a bit of a clean? I recall JMP speaking highly of it. I'm running ID1050Xs FWIW. Yeah, it’s still good stuff. Ran some through the OBW when gas prices here were over $2/L. Didn’t see a big change, but I definitely got a few more kilometers on a tank after that. It’s just a good fuel system maintenance product. 1 Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 17, 2023 Share Posted May 17, 2023 I use half a can of Berryman B12 twice a year in my LGT and Forester. Also use a little in my John Deere and my pressure washer for season start up. 1 1 EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
pksystems Posted May 18, 2023 Share Posted May 18, 2023 (edited) Bled the brakes with my homemade pressure bleeder. The factory cap/seal wants to leak unless you fiddle/turn it to the exact spot. 10 psi is what I used. Pedal seems firm. Started filling all the remaining fluids. Edited May 18, 2023 by pksystems Link to comment Share on other sites More sharing options...
socalsleeper Posted May 18, 2023 Share Posted May 18, 2023 24 minutes ago, pksystems said: Bleed the brakes with my homemade pressure bleeder. The factory cap/seal wants to leak unless you fiddle/turn it to the exact spot. 10 psi is what I used. Pedal seems firm. Started filling all the remaining fluids. If you have something like the Motive bleeder the Subaru specific adapter is not too expensive. The OEM caps are not meant to hold a downward seal across the whole surface, at least not for this kind of application. It works sometimes, maybe, except when you really need it to work... 1 Link to comment Share on other sites More sharing options...
Pleides Posted May 18, 2023 Share Posted May 18, 2023 On 5/16/2023 at 3:16 PM, SubOperator said: No today but on Saturday. The morning looked like this: and then like this: Got eh front SS brake lines installed fairly quickly and painlessly: Then went to shocks. Got the two bolts out and they were in no shape to be put back in with the new shocks.It's been only 13 years since I put them back in, Subaru quality is not good (/sarcasm). While trying to put the left assembly back on temporarily with old bolts, pulled the CV axle out of the inner joint, and it would not go back no matter what we did. it is Mike HAMMERDOWN's old CV axle and it was already a reman from NAPA at that. Was loose when I got Mike's car and I only put it in "for now" while I was going to reboot my original CV axle. I think that should have been 5-6 years ago. Ordered new strut bolts for front and rear, new boots (inner/outer) for my CV axle. Rocking Tribeca and my son's 2012 Crosstrek in the meantime. Man, thought I was going crazy cuz your car looks basically identical to mine! How ya liking the Bilsteins? My Konis have had some issues and I'm not sure I wanna replace the one that's squeaking after already having replaced another one under warranty Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 18, 2023 Share Posted May 18, 2023 Prepped and painted an old set of front strut bodies for Koni strut install. I’m going back to struts and springs. Where does one find JDM pink springs these days, specifically the wagon 5mt version people seem to prefer? EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
lagwagon Posted May 18, 2023 Share Posted May 18, 2023 2 hours ago, BoozeRS05 said: Prepped and painted an old set of front strut bodies for Koni strut install. I’m going back to struts and springs. Where does one find JDM pink springs these days, specifically the wagon 5mt version people seem to prefer? I got mine from Nengun Performance. They still sell them. 1 3 Link to comment Share on other sites More sharing options...
tysparks81 Posted May 18, 2023 Share Posted May 18, 2023 Picked up Transmission & rear diff oil for my only outstanding fluid change. I had also purchased a roof rack for the PA meetup so I could free up some space in the trunk. It showed up today and I wasted no time getting it installed this afternoon. Just need to pick up a few tie-down straps and I will be ready for the drive down. 3 #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
SubOperator Posted May 19, 2023 Share Posted May 19, 2023 (edited) 11 hours ago, Pleides said: Man, thought I was going crazy cuz your car looks basically identical to mine! How ya liking the Bilsteins? My Konis have had some issues and I'm not sure I wanna replace the one that's squeaking after already having replaced another one under warranty I like them and this is the reason I am replacing them with Bilsteins as well. No noise from them at all, they just wore out and do not perform as they used too. Hard to blame them at 13 years old and ~170K all year long driving. Here is current progress, I finally learned to apply anti-seize when putting things back together: One modification I made to install this time around, something I noticed when I was replacing shocks years ago on wife's Tribeca. Installed OEM lower spring rubber seat, Subaru part # 20325AA001, Tribeca has them but my Leggy did not. Hoping this reduces the road noise a bit more, not that it was a problem but since I am there anyway, why not? Also noticed that Toyota used them on 2005 Sienna we had. Here it is: Edited May 19, 2023 by SubOperator 2 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K 2007 B9 Tribeca Limited DGM - 272K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
SubOperator Posted May 19, 2023 Share Posted May 19, 2023 8 hours ago, BoozeRS05 said: Prepped and painted an old set of front strut bodies for Koni strut install. I’m going back to struts and springs. Where does one find JDM pink springs these days, specifically the wagon 5mt version people seem to prefer? RalliSpec also has them on their website, $120 a spring, different versions. There is a full spec table somewhere on this forum with all part ## for various versions of Pinks for AT, EZ30, MT, wagon etc. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K 2007 B9 Tribeca Limited DGM - 272K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
Kojak Posted May 19, 2023 Share Posted May 19, 2023 ^ Uncle Mat’s suspension breakdown sticky was my bible when deciding on which variety of pinks was applicable to my wagon. Got mine years ago from Nengun in Japan, when bachelor life presented no obstacle to shipping fees. Oh, how times have changed. In world and life. 2 2 Link to comment Share on other sites More sharing options...
SubOperator Posted May 19, 2023 Share Posted May 19, 2023 10 hours ago, Kojak said: ^ Uncle Mat’s suspension breakdown sticky was my bible when deciding on which variety of pinks was applicable to my wagon. Got mine years ago from Nengun in Japan, when bachelor life presented no obstacle to shipping fees. Oh, how times have changed. In world and life. Yes I used UM's info too, good stuff. I am on the other side of the bell curve, this whole project with SS brake lines and Bilsteins was driven and done largely by my middle son. I was mostly there from time to time to hand him a tool or give priceless Dad's advice(s). 1 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K 2007 B9 Tribeca Limited DGM - 272K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
Kojak Posted May 19, 2023 Share Posted May 19, 2023 Have ss lines on deck, but it’ll be a min before my son can help w anything beyond a Hot Wheels Subie. On topic, topped off tank and put Berryman’s on the shopping list. Figure a two-tank regimen wouldn’t hurt my mpg. Link to comment Share on other sites More sharing options...
seanyb505 Posted May 20, 2023 Share Posted May 20, 2023 Picked up these free bilstiens and top hats with tein springs, I believe h techs. These shocks are really crusty, are they worth saving or pretty much garbage? I only have them as a solution to use when I need my KWs need rebuilding in 4-5 years. Link to comment Share on other sites More sharing options...
SubOperator Posted May 20, 2023 Share Posted May 20, 2023 Bilstein used to offer rebuilding service for their shocks. I have no idea how much it costs but should be less than price for a new one. If these will only be temps for you for KW rebuild time, my thinking is they will be fine as is... 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K 2007 B9 Tribeca Limited DGM - 272K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
amm203 Posted May 22, 2023 Share Posted May 22, 2023 (edited) Productive weekend - replacement tranny cooler is in, MAF sensor cleaned, AEM Dryflow filter cleaned & oil changed. She gets inspected tomorrow. I noticed the Whiteline Com C top-hat rubber is starting to crack again. I have a feeling WL will not send a new pair for free a 2nd time around so I'm debating just going back to OEM style top-hats. Are there any other options besides OEM or KYB? Group N appears to only fit older WRXs & Foresters. I don't need solid top-hats but would like something a little "sportier" Edit/Update to my question: Found top hats by a company called Pedders (Model #585113). They appear similar to the Com C hats in that they're offset. Some cursory research on other forums indicates they have a different bearing mounting geometry to avoid the binding/popping issue of the WLs as well as a less harsh ride. Might try them out Edited May 22, 2023 by amm203 2 Link to comment Share on other sites More sharing options...
pksystems Posted May 22, 2023 Share Posted May 22, 2023 (edited) Started it up for the first time in a year. No fuel leaks with my new teflon lines. No oil leaks. Coolant leak to track down, but I think it just needs a better clamp on new silicone upper reservoir hose. Engine is running very rough tho. Wideband that I free-air calibrated a couple months ago is reading just under 20 at idle. I think I must have a massive air leak in one of the couplers or a bad sensor/injector. The guy I bought it off of, bought this car from the PO and said they had a misfire issue they couldn't track down. I replaced all the coil packs/spark plugs and leaking PCV hoses (with catch can setup) but I did reuse the injectors. I have another set of injectors I can swap in if I find a bad one. The only CEL's I got were for the TGV deletes, but I've since disabled those codes with ecuflash. Also installed my modded grill. Man my bodywork on that is horrid. Scratches everywhere I'll need to fill/sand/repaint later. Received my knockoff Perrin accessory belt cover. I'll have to make some WRX style tabs to properly mount it. Edited May 22, 2023 by pksystems 2 Link to comment Share on other sites More sharing options...
