RIPjeep2002 Posted August 11, 2009 Share Posted August 11, 2009 Anybody have any ideas on how to mount these in the grill with the Cobb radiator shroud installed? The scoop of the shroud sits right where the one hella would sit if I mounted it to the bolt that holds the hood latch in. Link to comment Share on other sites More sharing options...
cfaber Posted August 11, 2009 Share Posted August 11, 2009 There should be another bolt hole below that one. Also you don't have to mount them in the grill area. you could put them in the wheel well area where the stockers are and have almost the same loudness. -cf Winning the internet Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted August 11, 2009 Share Posted August 11, 2009 There should be another bolt hole below that one. Also you don't have to mount them in the grill area. you could put them in the wheel well area where the stockers are and have almost the same loudness. -cf This I know but I have a R-Rev grill and am looking at filling in the space behind it Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted August 11, 2009 Share Posted August 11, 2009 And I do see the lower bolt hole. Now all I need is to go get a bolt long enough, with a washer and lock-nut. Does anyone know that if I undo the 2-10mm bolts holding that upright bar will I be able to bend it out far enough to get the lock-nut on the back side? Link to comment Share on other sites More sharing options...
Windy Road Posted August 11, 2009 Share Posted August 11, 2009 Anybody have any ideas on how to mount these in the grill with the Cobb radiator shroud installed? The scoop of the shroud sits right where the one hella would sit if I mounted it to the bolt that holds the hood latch in. There's an empty bolt hole right under the latch piece. Stick a bolt from the back side of the bracket towards the front, stick the horn mounts on the bolt. Then toss a lock washer and a lock nut on the bolt and tighten it down, all done. They horns will be close together but it works with the Cobb piece since I have it too. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
cfaber Posted August 11, 2009 Share Posted August 11, 2009 I suggest a number 10 bolt that's 1" long and get your self a few washers as well as a locking nut. Winning the internet Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted August 11, 2009 Share Posted August 11, 2009 There's an empty bolt hole right under the latch piece. Stick a bolt from the back side of the bracket towards the front, stick the horn mounts on the bolt. Then toss a lock washer and a lock nut on the bolt and tighten it down, all done. They horns will be close together but it works with the Cobb piece since I have it too. hey thanks for the walkthrough. never though of putting the bolt in backwards and putting the lock nut on the front side...ill let you know how it goes Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted August 11, 2009 Share Posted August 11, 2009 I suggest a number 10 bolt that's 1" long and get your self a few washers as well as a locking nut. thanks for the exact bolt that should be used. Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted August 13, 2009 Share Posted August 13, 2009 Alright, can someone quickly enlighten me. How the hell do you get the bolt in from the back side? There is clearly not enough room between the radiator and the center support to wiggle the bolt around to the back side of that center support. Can someone help me out here please? Link to comment Share on other sites More sharing options...
cfaber Posted August 13, 2009 Share Posted August 13, 2009 Don't, That's what the washers are for. You should be able to get the nut plus box wrench in behind the piller no problem. That's also why you want to use a lock nut. Winning the internet Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted August 13, 2009 Share Posted August 13, 2009 Don't, That's what the washers are for. You should be able to get the nut plus box wrench in behind the piller no problem. That's also why you want to use a lock nut. So how does it go? Bolt, washer, Hella Supertone brackets, then lock nut on back side of support beam? Link to comment Share on other sites More sharing options...
cfaber Posted August 13, 2009 Share Posted August 13, 2009 Yeah basically, Bolt->washers->hella's->washers->piller->washer->lock nut, Winning the internet Link to comment Share on other sites More sharing options...
RIPjeep2002 Posted August 13, 2009 Share Posted August 13, 2009 Yeah basically, Bolt->washers->hella's->washers->piller->washer->lock nut, Alright. Thanks for the info. Link to comment Share on other sites More sharing options...
Siper2 Posted August 17, 2009 Share Posted August 17, 2009 I've got a brand new pair of Supertones that I need to install. IAG Performance is selling them with pre-fab harnesses, including the relays, and I haven't had time to put them in yet. Had them in my old RS, they were great, but I never used the relay in that car. As it stands now, I think the harness was built for the stock location... It's pretty short, so I think so. Link to comment Share on other sites More sharing options...
cfaber Posted August 17, 2009 Share Posted August 17, 2009 Wire looming, 12g/18g vampire splice, 12g/14g wire, and a box of 1/4" wiring clips (for the relay), 5/8" terminal clip, and an inline fuse is all you need for the job. Plus some electrical tape and zip ties to keep things neat and tidy. The relay comes with the hella kit, creating the wiring harness is easy. Winning the internet Link to comment Share on other sites More sharing options...
TKDKracker007 Posted September 16, 2009 Share Posted September 16, 2009 Here's my quick-n-dirty install on my '08 LGT. I used the relay in my setup. Horn signal was tapped by removing the intake, popping off the innermost horn connector, and plugging in a spade connector. Like another member mentioned in their install, I installed the relay near to the fusebox to keep it relatively dry (I still need to tape/heatshrink that whole assy). I used an existing hole on the bottom of the center bar, putting the horns behind the license plate. I felt this gave better radiator clearance, and I couldn't get the upper two screws out of the grill, so this was easier too. Pics: http://i304.photobucket.com/albums/nn178/tkdkracker007/08%20LEGACY%20GT%20LMTD/Hella%20Supertones-%20Quick%20N%20Dirrty%20install/hellas_quickndirty001.jpg http://i304.photobucket.com/albums/nn178/tkdkracker007/08%20LEGACY%20GT%20LMTD/Hella%20Supertones-%20Quick%20N%20Dirrty%20install/hellas_quickndirty002.jpg http://i304.photobucket.com/albums/nn178/tkdkracker007/08%20LEGACY%20GT%20LMTD/Hella%20Supertones-%20Quick%20N%20Dirrty%20install/hellas_quickndirty004.jpg http://i304.photobucket.com/albums/nn178/tkdkracker007/08%20LEGACY%20GT%20LMTD/Hella%20Supertones-%20Quick%20N%20Dirrty%20install/hellas_quickndirty003.jpg http://i304.photobucket.com/albums/nn178/tkdkracker007/08%20LEGACY%20GT%20LMTD/Hella%20Supertones-%20Quick%20N%20Dirrty%20install/hellas_quickndirty005.jpg http://i304.photobucket.com/albums/nn178/tkdkracker007/08%20LEGACY%20GT%20LMTD/Hella%20Supertones-%20Quick%20N%20Dirrty%20install/hellas_quickndirty006.jpg http://i304.photobucket.com/albums/nn178/tkdkracker007/08%20LEGACY%20GT%20LMTD/Hella%20Supertones-%20Quick%20N%20Dirrty%20install/hellas_quickndirty007.jpg Link to comment Share on other sites More sharing options...
cfaber Posted September 16, 2009 Share Posted September 16, 2009 One thing I should note in my list of things you need. Using heat shrink works really really well to keep the water out of the soldered connections. Winning the internet Link to comment Share on other sites More sharing options...
squiddmonster Posted February 22, 2010 Share Posted February 22, 2010 Had the Hellas installed on Saturday and used the subimods bracket and plug and play relay harness. The harness worked out great but was not happy with the bracket. Imo the bracket is to long and very flimsy at the mounting point. This makes it very easy for the horns to vibrate due to how far apart they are. Sooo I went to Home Depot and found a tee bracket in the decking aisle. UPC# 044315037108 (sorry forgot the sku#.) All the mounting holes are already drilled. If you trim the top of the bracket leaving an 1/8 of an inch on top you can then use the lower bolt for the hood bracket to install it. Once the whole thing was installed I covered up the area and sprayed the tee bracket with flat black paint and it was done. It looks very similar to post # 133. The tee bracket from Home Depot was $3.73. I will post pics sometime this week. Link to comment Share on other sites More sharing options...
CTATV Posted February 22, 2010 Share Posted February 22, 2010 have any of you seen the subimods mount and wiring harness for the horn install Link to comment Share on other sites More sharing options...
ticklelgt Posted February 23, 2010 Share Posted February 23, 2010 can you get some pics of where you wired everything up with the harness I couldn't get mine to work I might be just grounding it wrong Link to comment Share on other sites More sharing options...
legacyCT Posted February 23, 2010 Share Posted February 23, 2010 have any of you seen the subimods mount and wiring harness for the horn install Just ordered mine today.. I will be installing it when it gets warmer out.. Ill let you know how it goes... Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted March 31, 2010 Share Posted March 31, 2010 http://www.anrdoezrs.net/click-3202266-10695891?URL=http%3A%2F%2Fwww.streetsideauto.com%2Fproducts2.asp%3Fbrand%3DBFDP%26partnumber%3D003399801 nasiocfan and get 10% WELCOME12 coupon code for 12% ends 4/7/2010 Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted March 31, 2010 Share Posted March 31, 2010 Just ordered mine for 44.68 , now I just need a really cheap bracket and a harness. The subimods brackets is way too much $$$$. Link to comment Share on other sites More sharing options...
brooklyngenius Posted March 31, 2010 Share Posted March 31, 2010 I have the subimods bracket on mine and mine is really thick, looks great and defiantely doesnt vibrate. ps the relay is overkill and completely unnecessary. Hella states the relay is only for older cars that dont run 2 stock horns. hellas use less power than the stock so simply plugging them into the stock harness is more than enough. useless signature line where i cant mention my sponsors "First Bagged BL5!" Link to comment Share on other sites More sharing options...
cfaber Posted March 31, 2010 Share Posted March 31, 2010 ^^ I don't know about that. They each draw 5+ amps of power at 12v (65 watts). IIRC the stockers draw far less than that. Winning the internet Link to comment Share on other sites More sharing options...
