suds2250 Posted August 19, 2006 Share Posted August 19, 2006 Sh*t! I should have blasted you and bosco when I pulled up! 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
NickB34 Posted August 20, 2006 Share Posted August 20, 2006 You can also pick up those 4 post relays that have an integrated fuse, which will add some protection to your electrical system Link to comment Share on other sites More sharing options...
CasopoliS Posted August 20, 2006 Share Posted August 20, 2006 I made a bracket this morning out of 3/4" steel stock. Thickness is like 1/8" or around there. Just need to paint it flat black now. The horns will not look like they do in the picture.... they will be different. http://img156.imageshack.us/img156/3797/dscn2042ob9.jpg http://img156.imageshack.us/img156/5648/dscn2044pg4.jpg The bracket: http://img156.imageshack.us/img156/9340/dscn2045bq4.jpg Link to comment Share on other sites More sharing options...
Garandman Posted August 20, 2006 Share Posted August 20, 2006 Here are a couple pics of my supertones. I used the hella relay and the diagram in post #3 to wire everything up. The relay is mounted in the left corner of the grille opening (you can see the blue wire connectors) using an existing threaded hole. The horns themselves I mounted using an existing hole in the cross support with a bolt and lock nut. Jon Nice. I just bought a set of Hella Compact Trumpet horns (I live in the city) and that looks like a great spot to mount them. The SuperTones only draw 2 watts each more so I can retrofit them if the 110db isn't enough. http://www.hella.com/produktion/HellaPortal/WebSite/Internet_usa/ProductsServices/Images/Compact_Trumpet.jpg Who Dares Wins スバル Link to comment Share on other sites More sharing options...
mach_six Posted August 20, 2006 Share Posted August 20, 2006 I think the Stebel ones are better and cheaper. Link to comment Share on other sites More sharing options...
j.reed Posted August 30, 2006 Author Share Posted August 30, 2006 I forgot about this thread I need to post my pictures at least. See first post. Link to comment Share on other sites More sharing options...
MDW25gt Posted August 30, 2006 Share Posted August 30, 2006 Looks like the cooling air to the radiator is blocked with the front mounts. That cant be good! I would find a way around that. Link to comment Share on other sites More sharing options...
jim1969 Posted August 30, 2006 Share Posted August 30, 2006 excellent how to thread. Link to comment Share on other sites More sharing options...
Garandman Posted September 8, 2006 Share Posted September 8, 2006 Had the Hella Compact Trumpet horns mounted in lieu of the stock horns. They fit in the same location, but barely. They're somewhat louder, and sound more like an American car horn. I liked my old air horns better but there are disadvantages to those in terms of mounting and response. We may try the new three way integrated compressor horns on our van, which has lots of mounting room. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
Claw Posted September 15, 2006 Share Posted September 15, 2006 Good thread.. might give me the confidence to do it myself. How do the Supertones compare to the Stebels? Link to comment Share on other sites More sharing options...
j.reed Posted September 17, 2006 Author Share Posted September 17, 2006 Looks like the cooling air to the radiator is blocked with the front mounts. That cant be good! I would find a way around that. I'm not worried, plus I have the fans-stuck-on problem, so I'm sure that'll compensate. Link to comment Share on other sites More sharing options...
PhilT Posted September 26, 2006 Share Posted September 26, 2006 Installed the Supertones over the weekend, very easy to do. I just put spades on the wires coming from the new horns, and plugged them into the existing connectors, no need for the relay that came with them. I've positioned the horns like Casopolis has done, but closer together, not sure if I like it though as it is quite obvious from the front. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
jim1969 Posted September 26, 2006 Share Posted September 26, 2006 did you paint them or leave them red? Link to comment Share on other sites More sharing options...
PhilT Posted September 26, 2006 Share Posted September 26, 2006 did you paint them or leave them red? Left them red, they stick out like a baboons asshole Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
jim1969 Posted September 26, 2006 Share Posted September 26, 2006 Left them red, they stick out like a baboons asshole :lol: Link to comment Share on other sites More sharing options...
automaticsti Posted September 29, 2006 Share Posted September 29, 2006 Is it OK to post replies? Link to comment Share on other sites More sharing options...
jim1969 Posted October 27, 2006 Share Posted October 27, 2006 does the bumper skin cover have to come off to get to the stock horns? Link to comment Share on other sites More sharing options...
CRAZY KEN Posted October 30, 2006 Share Posted October 30, 2006 ...has anyone mounted 2 sets of super tones??? Is it posibble or is it going to interfer with the airflow to our radiator??? CRAZY KEN Link to comment Share on other sites More sharing options...
Notyab Posted November 30, 2006 Share Posted November 30, 2006 ugh im no good @ these things but i just ordered a set so well see how it goes! Link to comment Share on other sites More sharing options...
G.T.Subie Posted January 29, 2007 Share Posted January 29, 2007 Where did you guys buy from? Denial is your best friend Link to comment Share on other sites More sharing options...
jim1969 Posted January 29, 2007 Share Posted January 29, 2007 J and J Associates. http://www.jnjassociates.biz/ Link to comment Share on other sites More sharing options...
just_phil Posted February 23, 2007 Share Posted February 23, 2007 Had the Hella Compact Trumpet horns mounted in lieu of the stock horns. They fit in the same location, but barely. I got the Supertones mounted in place of the stock horns, and they fit in there quite comfortably. I had to grind the corner of the new (supplied) mounting strip, so that one of the horns sits at an angle, while the other one goes straight down, just like the OEM one. I also had to bend it forward just a little bit to avoid touching anything. The first time I tried it on an empty stretch of the road, my wife and I both giggled stupidly. Now I am afraid to use it, so that I don't scare anybody off the road Link to comment Share on other sites More sharing options...
mcsquish Posted February 25, 2007 Share Posted February 25, 2007 Does anyone have a sound bite of these. I'm a little scared that they might be too loud. Thanks for posting the link where to get them. I'm looking at the 113db. ________ VAPORIZER REVIEW Link to comment Share on other sites More sharing options...
suba_rus Posted February 25, 2007 Share Posted February 25, 2007 Does anyone have a sound bite of these. I'm a little scared that they might be too loud. Thanks for posting the link where to get them. I'm looking at the 113db. +1 Link to comment Share on other sites More sharing options...
mlrtime Posted February 25, 2007 Share Posted February 25, 2007 . Link to comment Share on other sites More sharing options...
