well....crap. please help
  • Replies 516
  • Created
  • Last Reply
no, not yet. I suppose I could do that as well.
ToDo List:
- check valve clearance on LH head
- run a warm idle log on LGT
- count teeth for timing
- bleed power steering pump (later down the road)
- hook up boost gauge to OBXT and read idle vacuum
Personally, I am not sure if it is worth going through the hassle of installing that boost gauge. I kinna doubt that btssm is reporting a wrong boost/vacuum value. And if you had an issue there, I would suspect it'd affect all cylinders, not just one bank.
On your list, I would first count the teeth btw. You do have to take the crank pulley off but you know that.
  • Moderators
crank pulley / harmonic balancer are the same thing with these cars, although technically I don't believe the pulley acts as a harmonic balancer for these cars according to subaru.
You would need the crank sprocket to count the teeth, for sure, but the outer "pulley" needs to come off.
Not currently in stock :(
I have not reset valve lash. I'm kind of intimidated to do that. I don't really want to replace any buckets either.
For the record, I still think it's timing; I just don't know how.
I thought you had checked everything "valves", bucket measurements, reset lash, etc., during reassembly and brought everything to spec. Certainly much easy to do out of the car, but now that you indicate that you haven't done that, that's immediately where I'd start, especially if the tooth count and everything on the front end lines-up where it's supposed to be.
If I missed that you hadn't done the valve adjustments, I apologize. That's the first thing I would have pointed you to. A dime to a donut, that's likely where your LC and misfires is originating. Especially with leakdown done on a cold engine.
Just take your time and follow the FSM on the valve adjustment. Replace the HG if/when you pull that head. Don't make that a point of failure going forward.
Can I reuse the brand new head gasket that I just put on there, or do I need a new one since this one has technically been "crushed" already? If so, i'll probably go with a 6star gasket instead of the OEM one.
as for valve adjustment, I may be misunderstanding something here. I thought I would have to replace the buckets themselves if the valve lash is out of spec? I didn't think you could actually adjust the valves themselves and reuse the same width bucket.
I guess I'll just have to read the FSM while I'm sitting on the shitter later...
  • Moderators
Replace the gasket.
You are correct on replacing the offending buckets, as needed. If you are servicing a head you can move your existing buckets around to get as many valves at appropriate clearances, then you need to buy new buckets for whatever is left based on your measurements / math.
cool. I can math well.
i'm not going to remove the head at all then. there's no need to remove the head to replace buckets or check valve clearance. the valves and seats looked good when I had them off anyway. pictures are posted in the beginning of the thread.
^ This. We all should have caught this sooner. Be sure to check 1 and 3 too. If 2 and 4 were/are off, there's likely some changes on bank 1 as well.
Good point - was just about to make that.
Don't bench-set your lash and then reinstall your head and expect that to be okay.
The belt torque will load/unload your cams - hard to believe, but true - and affect your measurements.
I'm too anal, and have found that machine shops often fudge it to get it "good-enough". True Subaru shops not as much, but you're typical non-Subaru shop will. ISTR BoxKita posting about his less than stellar experience.
  • Moderators
I'm not saying to fudge it.
Seriously though, it's not realistic to expect that the starting point for setting lash is ALWAYS going to be a long block with timing belt installed. Plenty of starts will be bare heads or anything in between a LB with timing belt and just a pile of parts. If you set it in the middle of spec and then install (this is NOT fudging things or saying "eh, it's close enough) and actually know how to use feeler gauges, you should be just fine.
Given the option and opportunity to measure with the timing belt on? By all means, don't throw that opportunity away and just do it.
Replace the gasket. Check to make sure that the 6S gasket is dimensionally the same thickness as your OEM one on the other side. Thickness changes side-to-side result in compression differences and you don't want the engine unbalanced with more or less CR on one side vs the other.
Spreadsheet all of your bucket measurements, and then use the program to figure out which ones can replace another and be within spec. Good possibility you can make one work and the spreadsheet will show you that immediately. Might save you having to buy more than you think you do.
Perhaps xt2005bonbon would send you a copy of his valve lash computation spreadsheet ;)
If the clearance checks out then you need to take off the head.
Make sure you inspect the gasket thoroughly as well to see if you have had blow-by between the cylinders in some obscure way that wouldn't be noted on the leak-down test. Miscoloring of the headgasket could tell a lot.
And if you don't see anything at all when it comes to the headgaskets then it's time to look at the sprockets that they are indeed correctly mounted on the camshafts. If they are according to the pics I posted above it's still a possibility. I know that I'm paranoid, but it don't hurt to be thorough.
And for locating cracks in alu block/head:
[ame=http://www.youtube.com/watch?v=109-Uzu2ihw]Aluminum block crack detection techniques (magnaflux dye penetrant) - YouTube[/ame]
