xt2005bonbon Posted June 4, 2018 Share Posted June 4, 2018 Good job man. Good example of perseverance. btw, Are you reusing the same (new) head gaskets? Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 12, 2018 Author Share Posted June 12, 2018 No, of course not. Used new headgaskets. Reusing the "new" head bolts Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 14, 2018 Author Share Posted June 14, 2018 Significant change of plans!! More to follow as the new owner releases information Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 18, 2018 Author Share Posted June 18, 2018 Car runs like a champ! She's with her new owner now! Ill post some pics soon amd maybe a video of the,first start up Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 18, 2018 Author Share Posted June 18, 2018 so here's the last bit of pics for you. super long story short, we pulled the broken motor from his 05 LGT, swapped some goodies over to the OBXT motor, and dropped it in. car now runs like a champ!! I pulled some logs and everything looks great. Couldn't be happier. for the sake of total transparency and in hopes others dont make the same mistake i did: When installing a new rear main seal, be sure to keep it flush and dont drive it all the way in. my dumb ass drove it in and it blocked the return passage causing a pretty significant leak of oil. we were ready to take the car for a test drive last night after letting it idle for about 20 minutes. as we were backing out of the garage, we noticed a huge puddle of oil and a trail of oil to the car. after looking at it, we concluded it was coming from the brand new rear main seal. completely my fault. I'll own that mistake. I suck at life. so we spent the next hour pulling the motor AGAIN. we were really booking it and had that thing down to a science. Kieth came over around 1430 today to put the motor back in and he drove off at 1730. so, pretty quick turn around. had a vacuum leak from not connecting the FPR line to the plenum, but after that plugged in, all the values look great. the car pulls like a bat out of hell. the only noise it makes is the chatter from the fuel injectors. else, solid freggin car! Another satisfied customer! Also, Kieth is a beast turning wrenches. It was an absolute pleasure having him over to help out. he certainly knows his way around a tool box and is more knowledgeable on these cars than most. This car definitely went to the right owner! Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 18, 2018 Author Share Posted June 18, 2018 And heres the first start up! Link to comment Share on other sites More sharing options...
scoobydrvr Posted June 19, 2018 Share Posted June 19, 2018 She's on the road, driving like a champ! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 19, 2018 Share Posted June 19, 2018 so here's the last bit of pics for you. super long story short, we pulled the broken motor from his 05 LGT, swapped some goodies over to the OBXT motor, and dropped it in. car now runs like a champ!! I pulled some logs and everything looks great. Couldn't be happier. Which goodies did you exactly take from the LGT and put in the OBXT? At least, I see a GS intercooler. Link to comment Share on other sites More sharing options...
scoobydrvr Posted June 19, 2018 Share Posted June 19, 2018 Had to avoid things that required a custom tune so that really just left the Group N motor mounts, Torque Solutions pitch stop, Grimmspeed intercooler, Koyorad radiator, Samco rad hoses and bypass hose, Tomei Expreme EL header w/catless up pipe, and Perrin catted downpipe. Going back later for the JDM HVAC and aftermarket radio, LED lights, and shift boot and e-brake boot, and sway bars. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 19, 2018 Share Posted June 19, 2018 I see. Now, keep a good eye to what btssm reports to make sure she runs well for many many miles. OP, could you now summarize what has been done to the engine in the end. And can you also report any tips and tricks (e.g. when you pull the engine, put it back, take engine apart, etc...) that you may have? I may have to do the exact same thing you just did (rings/pistons). Link to comment Share on other sites More sharing options...
Infosecdad Posted June 19, 2018 Share Posted June 19, 2018 Had to avoid things that required a custom tune so that really just left the Group N motor mounts, Torque Solutions pitch stop, Grimmspeed intercooler, Koyorad radiator, Samco rad hoses and bypass hose, Tomei Expreme EL header w/catless up pipe, and Perrin catted downpipe. Going back later for the JDM HVAC and aftermarket radio, LED lights, and shift boot and e-brake boot, and sway bars. Not sure what you were coming from, but typically an EL header will need an update to the tune, as will the down pipe if it used to be stock. There was a pretty decent difference on mine when I went from stock manifold to EL headers. Link to comment Share on other sites More sharing options...
scoobydrvr Posted June 19, 2018 Share Posted June 19, 2018 Not sure what you were coming from, but typically an EL header will need an update to the tune, as will the down pipe if it used to be stock. There was a pretty decent difference on mine when I went from stock manifold to EL headers. You make a good point. I put the Cobb stage 2 OTS tune on; it's pretty close and appears to do okay. I'll be getting a custom tune from Cryotune once I get the car settled and wideband wired in again. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 19, 2018 Share Posted June 19, 2018 Yeah. Then watch btssm closely or your AP for FKC/FLKC events. custom tune should be done real soon IMHO. Link to comment Share on other sites More sharing options...
scoobydrvr Posted June 19, 2018 Share Posted June 19, 2018 Of course. I've pretty much always got one eye on the AP. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 20, 2018 Author Share Posted June 20, 2018 alright, this post is for BonBon and anyone else that wants the recap: I bought the car with an assumed diagnosis of a blown head gasket due to misfires in cyl2&4. stupid long story short, had to replace pistons and rings due to completely separated ringlands on both pistons. I also went ahead and freshened up the heads, valve train, replaced all gaskets, and put valve lash back in spec. as for tips and tricks -- leave as much on the engine as possible when pulling the motor. it's actually a very simple job to pull the motor. 6 tranny bolts, 2 starter bolts, 2 motor mount bolts, fuel lines, coolant lines to the heater core, brake booster vac line, fpr vac line, wiring harness on the alternator and A/C come off, ground straps on the bottom come off, 5 downpipe bolts, 2 big and 2 small coolant lines from the radiator (pull the radiator out too by unplugging the two fans, and removing the two top plates that hold it in position), unplug the engine-to-body harness and remove the bracket from the firewall, yank the engine! dont be a putz, remove the battery first. the trick to removing the engine is to jack up the transmission with it so the angle is better -- likewise when reinstalling. not sure what other advice you could need. dont forget to replace the throw out bearing anytime you pull the motor. just makes life easier in the long run. grease up the input shaft as well. take the extra few minutes to remove the flywheel/flexplate and replace the rear main seal while it's out as well; be sure to keep it flush and not drive it all the way back so you dont block the oil return passage like i did. that's basically it. if you ever need help or have questions, feel free to shoot me a PM. Link to comment Share on other sites More sharing options...
JazzAvi8r Posted June 20, 2018 Author Share Posted June 20, 2018 crap, forgot A/C lines, power steering lines or the whole pump and move it to the side, air box, and pitch stop -- but you get the idea Link to comment Share on other sites More sharing options...
xt2005bonbon Posted June 20, 2018 Share Posted June 20, 2018 Thanks for the info and tips. I will certainly pm you if I ever have to go through this. Link to comment Share on other sites More sharing options...
