Rhitter Posted May 17, 2017 Share Posted May 17, 2017 Did you use spacers to raise the manifold up to fit the larger intake? In for your smog experience next year My OBXT build Link to comment Share on other sites More sharing options...
dukeneverwinter Posted May 18, 2017 Author Share Posted May 18, 2017 Did you use spacers to raise the manifold up to fit the larger intake? In for your smog experience next year no spacers on the manifold, but it may have helped if I had. I am using the 2.5in" inlet 1.5 xt-r. Link to comment Share on other sites More sharing options...
Rhitter Posted May 19, 2017 Share Posted May 19, 2017 DT just posted your results on e85 Flexfuel - these are awesome! Must be a blast to drive. http://legacygt.com/forums/showpost.php?p=5632257&postcount=6 My OBXT build Link to comment Share on other sites More sharing options...
dukeneverwinter Posted May 20, 2017 Author Share Posted May 20, 2017 DT just posted your results on e85 Flexfuel - these are awesome! Must be a blast to drive. http://legacygt.com/forums/showpost.php?p=5632257&postcount=6 Lol. Sweet! I meed to update my thread. Gotta break it in! Bill is a fantastic guy. Super humble. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
LatentWagen Posted May 20, 2017 Share Posted May 20, 2017 Awesome results on E!! How is spool on the street? LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
dukeneverwinter Posted November 16, 2017 Author Share Posted November 16, 2017 YouTube link to a drag run. This was a couple months back. 8.23ish was best run? Babying 2nd and 3rd gear shifts. Also.... 6k-ish clutch drops on Michelin Pilot Sport A/S 3+ may be a bad idea. This was thre days ago. Broke a rear axle. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
dukeneverwinter Posted November 16, 2017 Author Share Posted November 16, 2017 Awesome results on E!! How is spool on the street?Spool on the street is nice and predictable. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
xt2005bonbon Posted November 16, 2017 Share Posted November 16, 2017 YouTube link to a drag run. This was a couple months back. 8.23ish was best run? Babying 2nd and 3rd gear shifts. [ame=http://www.youtube.com/watch?v=IqJ6etqKsuU]08 Subaru Outback XT 5mt. 1/8 mile drag race 8.26run San Diego Race Legal - YouTube[/ame] Got squat? Impressive man. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 16, 2017 Share Posted November 16, 2017 Learn how to slip the clutch using the e-brake and pre-load the driveline, if your going to be doing that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
stocklgt Posted November 17, 2017 Share Posted November 17, 2017 Hows the 5MT holding up? Nice build, sleeper status for sure! I just finished my build too, like you i threw my wallet at it. How do you like the E85 flex kit? Considered running one but went with meth instead because E85 is scarce in Queens NY. Link to comment Share on other sites More sharing options...
dukeneverwinter Posted November 17, 2017 Author Share Posted November 17, 2017 Hows the 5MT holding up? Nice build, sleeper status for sure! I just finished my build too, like you i threw my wallet at it. How do you like the E85 flex kit? Considered running one but went with meth instead because E85 is scarce in Queens NY. so far, the 5mt is doing great. I thought it was the trans that grenaded, I am really pleased it was just an axle. according to the website I saw the legacy/outback gears are the same strength as the STI ones. So it should last, hopefully. The Flex Fuel kit works as advertised. Fill up with any combo of fuel and it adjusts on the fly. After I get a bigger intake (sf tech BIG maf), and aftermarket exhaust, I am going back for a retune. I'll also have an external oil cooler installed by that time. All just to protect the engine in long haul driving, and abusive situations. Link to comment Share on other sites More sharing options...
Daniels Posted March 23, 2018 Share Posted March 23, 2018 How has that recirculating EWG flex tube held up? Link to comment Share on other sites More sharing options...
dukeneverwinter Posted December 10, 2018 Author Share Posted December 10, 2018 How has that recirculating EWG flex tube held up? So far so good, recently crawled under there to replace a broken CV boot and didn't notice anything awry. It's in such an annoying spot to check for leaks, but I do need to crawl under the car again. I am really curious about it, and need to check it more thoroughly than just a visual. Link to comment Share on other sites More sharing options...
dukeneverwinter Posted December 10, 2018 Author Share Posted December 10, 2018 Added a Nameless Catback with 5" mufflers. Got a retune, now at about 22.5-23psi. SubieFest 2018 Exhasut Comp Driveby after install Link to comment Share on other sites More sharing options...
rebourne Posted December 11, 2018 Share Posted December 11, 2018 Added a Nameless Catback with 5" mufflers. Got a retune, now at about 22.5-23psi. SubieFest 2018 Exhasut Comp Driveby after install Sent from my LG-LS997 using Tapatalk So loud and that's the biggest muffler they sell?! pic thread build thread Link to comment Share on other sites More sharing options...
dukeneverwinter Posted December 12, 2018 Author Share Posted December 12, 2018 Yup. Bu if you don't have an aftermarket downpipe it won't be nearly as loud. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
dukeneverwinter Posted December 12, 2018 Author Share Posted December 12, 2018 Also, a OneTake happened. Link to comment Share on other sites More sharing options...
rebourne Posted December 12, 2018 Share Posted December 12, 2018 Good video! pic thread build thread Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 12, 2018 Share Posted December 12, 2018 OP, you should try to get your hands on the BTS suspension kit if you can. These are quite rare and a bit $$. But it will help with handling quite a lot IMO, and you can retain ride height (or even slightly increase it as I did) with some spacers. Link to comment Share on other sites More sharing options...
dukeneverwinter Posted December 13, 2018 Author Share Posted December 13, 2018 OP, you should try to get your hands on the BTS suspension kit if you can. These are quite rare and a bit $$. But it will help with handling quite a lot IMO, and you can retain ride height (or even slightly increase it as I did) with some spacers.Yeah, I keep reading about them. But unless the yenn gets worse or dollar gets stronger, i'd rather spend the extra and go semi custom Ohlins. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
pjcampbell Posted March 6, 2019 Share Posted March 6, 2019 Just saw the video for this on reddit. Is this on a draw through MAF tune? (Not speed density)? I am working on a "similar" build (sort of...) with EJ253 heads and a gigantic supercharger in an 05 Outback. I had just assumed I'd need a PPG gearset in the 5MT. I don't really launch my car though. That nearly cuts the budget in half! Link to comment Share on other sites More sharing options...
pjcampbell Posted March 6, 2019 Share Posted March 6, 2019 Is it 460 crank or at the wheels? Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 6, 2019 Share Posted March 6, 2019 Yeah, I keep reading about them. But unless the yenn gets worse or dollar gets stronger, i'd rather spend the extra and go semi custom Ohlins. Sent from my LG-LS997 using Tapatalk Looked at their website after watching the video... Also looked they still offer an option from my old bike. The OBXT version looks like a great setup, but that damn price point... OUCH! Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 8, 2019 Author Share Posted March 8, 2019 Just saw the video for this on reddit. Is this on a draw through MAF tune? (Not speed density)? I am working on a "similar" build (sort of...) with EJ253 heads and a gigantic supercharger in an 05 Outback. I had just assumed I'd need a PPG gearset in the 5MT. I don't really launch my car though. That nearly cuts the budget in half! This is on speed Density, the MAF is still there, but mainly for IATs and keeping the filter out of the hot engine bay.. My gearset has been holding up fine. I did just grenaded a rear differential though. Using it as an excuse to go 6speed with r180 rear. SO i'll have a 5speed for sale soon! Link to comment Share on other sites More sharing options...
dukeneverwinter Posted March 8, 2019 Author Share Posted March 8, 2019 Looked at their website after watching the video... Also looked they still offer an option from my old bike. The OBXT version looks like a great setup, but that damn price point... OUCH! Keep an eye out on fleabay and forum classifieds. I found some for 700 on fleabay. And because I live in San Diego, I drove them to Bilstein and they are hopefully going to revalve them for Rallitek rear springs. Link to comment Share on other sites More sharing options...
