dukeneverwinter Posted April 19, 2017 Share Posted April 19, 2017 Getting parts in as we speak for my next big project on my 08 Outback XT. Burnt an exhaust valve so we pulled apart the motor. People convinced me to "refresh" the short block since it was out. This refresh became a built short block. Threw my wallet at it and parts are trickling in. Post #2 will have the build plans. first the back story. We were driving to Utah to go mountain biking, we pulled off in Vegas to ride some of the local trails there and the car had a wicked stumble at idle. WE said Ff it and rode in Vegas and then continued to Utah. Car was fantastic on the freeway and had all the power I wanted, no overheating or oil loss. every time we checked. http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11710 http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11712 http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11711 When we got to the campsite in Utah we got busy. We bought a compression tester at Harbor Freight, and new spark plugs and a tool kit from Autozone. We tore into it and did a compression test. Dead #4. I have a bike pump that has a big air chamber in it so we did a makeshift leak down test. After finding top dead center on #4. we put a plastic bag of the oil filler spot, and over the tail pipe. Let the air chamber go and we popped one of the bags off the exhaust pipe. All signs pointed toasted valve. http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11718 http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11719 so we drove it home to San Diego.... Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 19, 2017 Author Share Posted April 19, 2017 We pulled the engine out and found a burnt valve on #4. Pretty cool that our shade tree ideas actually produced a real result. Thankfully these engines come out of the car pretty easy. But in the removal, I found more bad news in the form of a messed up turbo impeller. http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11715http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11713 BUILD PLANS new things to get Blouch 1.5xt-r biggest turbo that has "good" spool in stock location. Tial MV-R mount via a Ultimate Racing up/down pipe recirc kit. Delicious tuning e85 Flex Fuel kit Closed Deck long block with JE pistons and forged rods from S&S Subarus and Sand Cars Grimmspeed TMIC so I can use the STI style turbo GSC Valves/Spirngs/retainers. Why not, the head is getting redone anyway right? DW1200 ev14 inejctors ACT 6puck clutch Crawford AOS Parts the car already has. AEM 320 pump Tomei ELH manifold COBB intake and airbox Reasoning on things Before pulling the turbo, I was just going to get the heads redone and put the car back together with the same shortblock. But on finding the damaged impeller, I was undecided on what to do. I could get it rebuilt for $3-500? or buy a new turbo for around $1k or more. I ended up opting to go big. But then, which turbo? An AVO440xt or similar is as big as you can really get using the stock style TMIC. And it's expensive for basically a gt28 turbo which doesn't get great reviews on Subarus. I started seeing the Blouch turbos that are only a tad more than the 440xt and decided I needed to find an intercooler that will allow an STI style turbo on the Legacy GT/Outback style platform. Thankfully Grimmspeed makes such an intercooler. Once I found the intercooler the choice of turbo was easy. So I ordered a Blouch 1.5 xt-r! Once I decided on the turbo, things started to get out of control... I decided I wanted to do EWG. Ultimate Racing makes a pretty cool kit that fits an sti style turbo and runs the EWG recirculating to the downpipe. Stay tuned for more! Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 19, 2017 Author Share Posted April 19, 2017 After using a center-force 6 puck clutch in my turbo MR2 I decided to put something similar in the Outback to handle the much increased power output. It could be clutch pedal geometry, but the center-force feels much much lighter than the Exedy Stage 1 HD clutch that I had previous in the outback. I am keeping the stock single mass flywheel primarily for drive-ability. I may loose some fast revs, but I actually drive these cars daily. http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11732 After choosing the Blouch 1.5 XT-r I wanted to maximize it's ability to breath and function within the limits of my mods. I wanted a External Wastegate but I did not wanted it vented externally. I did some searching and a company in canada, Ultimate Racing, makes an up-pipe downpipe EWG set up. They supply a Tial MV-r EWG with the version of the kit I bought. I had them make it a three bolt up-pipe to match my current Tomei ELH. Once I got the exhaust bits from Ultimate Racing I had them Cerakoted at a local powder coating place. East County Powdercoating http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11734http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11733 before Cerakote http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11735http://legacygt.com/forums/picture.php?albumid=2563&pictureid=11738 Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 19, 2017 Author Share Posted April 19, 2017 reserved #2 Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 19, 2017 Author Share Posted April 19, 2017 reserved #3 Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 19, 2017 Author Share Posted April 19, 2017 reserved #4 Link to comment Share on other sites More sharing options...
Max Capacity Posted April 19, 2017 Share Posted April 19, 2017 Remember to replace some of the old age items like hoses and clean the engine grounds and mating surface of the block and tranny. Good Luck with your project. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 19, 2017 Author Share Posted April 19, 2017 Remember to replace some of the old age items like hoses and clean the engine grounds and mating surface of the block and tranny. Good Luck with your project. Yeah. One of my posts was going to be all the hoses and stuff. Everything that runs water or oil through it is new. Every hose and o-ring.. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
birkhoff Posted April 20, 2017 Share Posted April 20, 2017 Looks like a small piece of that valve went into the compressor. Too bad. A catted UP like we have in the 2005 models would have saved the turbo Nice workshop there. Awesome interpretation of the old fashioned repair 'bay'. Link to comment Share on other sites More sharing options...
Gex Posted April 20, 2017 Share Posted April 20, 2017 I doubt the valve piece knocked the turbo. When I pulled my heads with a burnt valve the piece of valve fell out from between the head and piston. Good luck on the build. I love my Dom1.5XT-R. Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 20, 2017 Author Share Posted April 20, 2017 I doubt the valve piece knocked the turbo. When I pulled my heads with a burnt valve the piece of valve fell out from between the head and piston. Good luck on the build. I love my Dom1.5XT-R. Yeah, i am pretty sure it was some foreign object that damaged the turbo. If a valve piece would have, it would have taken out the hot side, not the cold inlet side Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
08 LGT Posted April 20, 2017 Share Posted April 20, 2017 What mileage did this happen? Just curious Link to comment Share on other sites More sharing options...
xt2005bonbon Posted April 20, 2017 Share Posted April 20, 2017 I love that you did all this troubleshooting at the campsite. Epic!! This reminds me when we went camping to Gooseberry mesa in Utah to go MTB and had to figure out a way to cover my torn cv joint. I had fun too! I would note that this burnt valve would have probably be avoided if the valve clearance would have been checked. You must have had slight rough idle for a while no? Link to comment Share on other sites More sharing options...
birkhoff Posted April 20, 2017 Share Posted April 20, 2017 Yeah, i am pretty sure it was some foreign object that damaged the turbo. If a valve piece would have, it would have taken out the hot side, not the cold inlet side Sent from my LG-LS997 using Tapatalk Good point. My brain must have been on holiday yesterday! Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 20, 2017 Author Share Posted April 20, 2017 I love that you did all this troubleshooting at the campsite. Epic!! This reminds me when we went camping to Gooseberry mesa in Utah to go MTB and had to figure out a way to cover my torn cv joint. I had fun too! I would note that this burnt valve would have probably be avoided if the valve clearance would have been checked. You must have had slight rough idle for a while no? No rough idle that I can remember, nothing noticeable. Car had 137k miles. There were signs of leaked coolant, so I am sure i got hot here or there. Although it has never over heated. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 20, 2017 Author Share Posted April 20, 2017 While tearing apart the engine after deciding to go for the full rebuild, I found signs that thebcar had been leaking coolant from the crossover pipes. Also, some tiny scarring on the top side of cylinder #4. Only can see the marks, cannot feel or measure them with a bore gauge. Also, checkout the nasty looking water pump. This was a legit OE subaru pump after only about 45k miles. I guess it didn't like running on water plus 'water wetter' for 5k miles after the tear down 45k ago. switched to distilled water and Subaru coolant after the first 5k. Not sure why I didn't fill up with Subaru coolant in the first place. probably just forgot to buy it when I did the last project. We checked the bore with a guage and everything measured in spec even at 137k miles. Decided to go built block because the heads are getting work anyway, and also the decision to go bigger turbo. Piston #4 showed no signs of ringland failure, or any kind of damage. Also, not pictured, but one of the screws on the back of the stock oil pump was slightly loose. Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
Rhitter Posted April 20, 2017 Share Posted April 20, 2017 What are your plans for smog with the STI style turbo? or do you "know" a guy? My OBXT build Link to comment Share on other sites More sharing options...
dukeneverwinter Posted April 20, 2017 Author Share Posted April 20, 2017 @Rhitter. We'll see...I still have a stock TMIC, maybe if i don't find a guy, i'll see if I can find a cheap vf46 Sent from my LG-LS997 using Tapatalk Link to comment Share on other sites More sharing options...
fahr_side Posted April 21, 2017 Share Posted April 21, 2017 Can't use the stock TMIC with an STi-style turbo like the XTR. You can either use a 'universal' style cooler than can do either style, or use an STi-fitment TMIC and the metal intake manifold. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
fahr_side Posted April 22, 2017 Share Posted April 22, 2017 Get a VF-52 if stealth is the goal. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
Rhitter Posted April 22, 2017 Share Posted April 22, 2017 But VF52 doesn't have the power of a DOM1.5. Looking forward to watching the build. My OBXT build Link to comment Share on other sites More sharing options...
fahr_side Posted April 22, 2017 Share Posted April 22, 2017 But VF52 doesn't have the power of a DOM1.5. Looking forward to watching the build. You're preaching to the choir my friend <-- guy with a Dom1.5 on personal car / test mule Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
tocinoman25 Posted April 22, 2017 Share Posted April 22, 2017 Subbed... Sent from my SM-G935V using Tapatalk Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
jersdunz Posted April 23, 2017 Share Posted April 23, 2017 Did you rule out the stock location efr7163? Great spool and power.. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
xtea Posted April 23, 2017 Share Posted April 23, 2017 Dom 1.5 and 7163 spool about the same. Dom makes less power but also less expensive install. Link to comment Share on other sites More sharing options...
