ebo03 Posted August 18, 2016 Author Share Posted August 18, 2016 In the Baja today I noticed a new car maker. Maybe I need to add to the fleet.http://uploads.tapatalk-cdn.com/20160818/92acd15f5fb9310d947977f9e933bf0a.jpg Link to comment Share on other sites More sharing options...
GTEASER Posted August 18, 2016 Share Posted August 18, 2016 :lol: GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Garurumon Posted August 19, 2016 Share Posted August 19, 2016 U urabus Link to comment Share on other sites More sharing options...
ebo03 Posted August 23, 2016 Author Share Posted August 23, 2016 Rear adapter rotors and brackets, short shifter, and all sorts of driveline bushings and mounts arrived from KNS Brakes. I highly recommend doing business with them. Nick was very helpful getting my order sorted out. I'm getting antsy to install everything. Still waiting on the Brembo refurbishment and ceramic coating on the header. Link to comment Share on other sites More sharing options...
ebo03 Posted September 5, 2016 Author Share Posted September 5, 2016 Changed the oil & filter on the Baja today. Plastic splash shield was MIA so installed a Primitive skid plate after yet another round of broken bolt removal and thread repair. Just enough clearance for a Fumoto F105S. http://uploads.tapatalk-cdn.com/20160905/a854f5f61c1e868d7e3e424fab5cfaa6.jpg http://uploads.tapatalk-cdn.com/20160905/502adb1ca7d1b8ede69a4f07f33813c1.jpg Link to comment Share on other sites More sharing options...
brandon.mol Posted September 6, 2016 Share Posted September 6, 2016 A couple good smacks to the skid plate from the top with a hammer will give you a bit of comfort clearance... I gave my turbo an extra half inch that way after cutting out the spacer at the rear to increase ground clearance, which made things tight in the front. Link to comment Share on other sites More sharing options...
ebo03 Posted September 6, 2016 Author Share Posted September 6, 2016 A couple good smacks to the skid plate from the top with a hammer will give you a bit of comfort clearance... I gave my turbo an extra half inch that way after cutting out the spacer at the rear to increase ground clearance, which made things tight in the front. I am not worried about it at all. It should be just fine as is. Link to comment Share on other sites More sharing options...
ebo03 Posted September 8, 2016 Author Share Posted September 8, 2016 Ceramic coating is done! Machine work on rear Brembos is done. Hayworth needs to finish up the machine work on fronts then they're off to powder coating before coming back to him for new dust boots, o-rings, etc. http://uploads.tapatalk-cdn.com/20160908/fc400bf8d9fae5bba1a67baed532bbf9.jpg Link to comment Share on other sites More sharing options...
ebo03 Posted September 15, 2016 Author Share Posted September 15, 2016 A hood to play with. http://uploads.tapatalk-cdn.com/20160915/2ce39768b1f25301aaaab20163c7326c.jpg Link to comment Share on other sites More sharing options...
ebo03 Posted September 15, 2016 Author Share Posted September 15, 2016 Here's the game plan but with a Grimmspeed TMIC and splitter:Â http://legacygt.com/forums/showthread.php/adding-sti-scoop-3rd-gen-hood-pics-221149.html Link to comment Share on other sites More sharing options...
fredrik94087 Posted September 17, 2016 Share Posted September 17, 2016 Jesus! That is why I am so scared of getting another car. It just never stops. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
ebo03 Posted September 17, 2016 Author Share Posted September 17, 2016 Jesus! That is why I am so scared of getting another car. It just never stops. Oh come on. This is just my beater truck.[emoji48] Link to comment Share on other sites More sharing options...
ebo03 Posted September 21, 2016 Author Share Posted September 21, 2016 Just received the base map from Tuning Alliance. We are going to install everything from post #2 on Friday. Less the Brembos, still don't have them back from refurb yet. Link to comment Share on other sites More sharing options...
ebo03 Posted September 23, 2016 Author Share Posted September 23, 2016 Install day. http://uploads.tapatalk-cdn.com/20160923/40698638e67f003b9228d9bdb30ba332.jpg http://uploads.tapatalk-cdn.com/20160923/557a566bfcf34588027410ac9dfe9660.jpg Link to comment Share on other sites More sharing options...
ripstik Posted September 23, 2016 Share Posted September 23, 2016 thats quite the haul of parts Link to comment Share on other sites More sharing options...
ebo03 Posted September 24, 2016 Author Share Posted September 24, 2016 (edited) Nearly all the shifter and driveline mounts and bushings are in. We could only work on it for about 5 hours due to other commitments. For anybody who plans on installing TiC shift linkage bushings you will need their linkage update part. They claim that all 2006+ 5-speed trans do not need the update...not the case on the Baja. Not only is the stock U-joint "not serviceable" but the TiC bushings are too large to fit the U-joint anyway. We used a grinder and punch to separate the U-joint and then welded it back once we realized it was a no go due to bushing size. No power mods were installed today...so sad. Will have to get back to it in a couple of weeks. Shifting is much improved. Everything is firmed up.[emoji106] Edited September 24, 2016 by ebo03 Link to comment Share on other sites More sharing options...
jojorios Posted September 24, 2016 Share Posted September 24, 2016 Install day. http://uploads.tapatalk-cdn.com/20160923/40698638e67f003b9228d9bdb30ba332.jpg http://uploads.tapatalk-cdn.com/20160923/557a566bfcf34588027410ac9dfe9660.jpg This pic just did things to me. Too bad it all couldn't go in. Link to comment Share on other sites More sharing options...
ebo03 Posted September 26, 2016 Author Share Posted September 26, 2016 This pic just did things to me. Too bad it all couldn't go in. Too bad we couldn't get the power parts on. This car definitely needs an exhaust. My girlfriend of over a year, who knows nothing about cars, commented that the car sounds very different as soon as she got in it the other day. Until then I would have said that she was not the most observant when it came to anything car related. I was actually thinking that there may be a small chance that she wouldn't even notice a new exhaust - ha not a chance! Link to comment Share on other sites More sharing options...
ebo03 Posted October 3, 2016 Author Share Posted October 3, 2016 New passenger airbag was installed today from the recall. Link to comment Share on other sites More sharing options...
ebo03 Posted October 17, 2016 Author Share Posted October 17, 2016 Brembo calipers go to powder coating tomorrow. I hope to get all the power mods on it this coming weekend. Link to comment Share on other sites More sharing options...
ebo03 Posted October 17, 2016 Author Share Posted October 17, 2016 We have a seat bracket and sliders just no seat. http://uploads.tapatalk-cdn.com/20161017/50be13d35ea062b4ba877eb3a3b5c855.jpg Link to comment Share on other sites More sharing options...
s2baru Posted October 17, 2016 Share Posted October 17, 2016 Powdercoating them orange right? Link to comment Share on other sites More sharing options...
ebo03 Posted October 17, 2016 Author Share Posted October 17, 2016 Powdercoating them orange right? Haha you would love that. But no going with a silver. Should look like these but with red Brembo logos. http://uploads.tapatalk-cdn.com/20161017/e89e0e9719cddb5888d1b78538288a78.jpg Link to comment Share on other sites More sharing options...
ebo03 Posted October 27, 2016 Author Share Posted October 27, 2016 I expect to have the Recaro Speed by next week. The vendor was expecting to have it this week then they'll ship it out. The sad news is that it will be about a month before the power mods are installed. My friend who has access to a lift dislocated his ankle last week so he's out of commission for about 4 weeks. I find it hard to get motivated enough to spend all day on my back under jack stands -- damn, I must be getting old! I'm going to wait until he can at least hobble around before we get all the fun parts installed. In the mean time I might focus on getting a few things done on the Legacy. Link to comment Share on other sites More sharing options...
STI_Steve Posted October 28, 2016 Share Posted October 28, 2016 So your brakes will look like mine! http://i63.tinypic.com/14us81.jpg Link to comment Share on other sites More sharing options...
