Andrew's DiySB Rebuild
What color combo should I paint my block / heads / valve covers?
37 members have voted
  1. 1. What color combo should I paint my block / heads / valve covers?
    • everything SILVER
    • everything RED
    • sb RED / heads SILVER / vc's SILVER
    • sb RED / heads SILVER / vc's RED
    • sb SILVER / heads RED / vc's SILVER
    • sb SILVER / heads RED / vc's RED
If you tap a piston down and stop at juuuuust the right spot, you can see that the oil ring is positioned correctly BEFORE causing any damage.
Not sure what I am seeing there. The ring compressor should sit straight on the piston, with the leaves all aligned and only the piston skirt showing before you start. It should be quite firmly cinched down.
Once you start feeding in the piston, the compressor must stay in contact with the firedeck at all times, otherwise a ring will slip out. Maybe you are just experimenting there to show us that the oil pack has made it in, but otherwise, that picture looks pretty scary!
^ My thoughts exactly. Why is the compressor "tipped". I'd be holding that firmly against the block to ensure nothing expands until it's fully inside the bore.
Hope the re-hone fixes the bore issue. What's the status on the new A piston and rings?
You may or may not recall that a while ago I bought a few used pistons with an unknown amount of miles on them. Well, I cleaned off the best looking one and decided it was worthy of making the team. I wasn't motivated by saving a few dollars, it's a really great looking piston. A little brake cleaner and about 5 minutes of scrubbing got it looking almost as good as new (compared to a new one in the pics). Even the skirt coating looks near-new. Say what you will, but it's in the motor now. Cylinder F was already compromised.
Cylinder F's end gaps using new rings + the top oil ring from the used piston:
Top - 0 017"
Middle - 0.0235"
Oil (both)- 0.016"
The crank spins easily as it should and none of the cylinders are scratched (this time). I'm sealing everything up and calling it a day. All things considered I'm pleased with today's work.
Edited by StkmltS
pic uploaded to server
Not yet. I'm going to try to do it with the pistons installed. I'll just use oil instead of water.
Sent from inner space.
Might also check they are close in weight unless you want the motor to shake itself to bits.
Nice job on a quick recovery there. Sometimes getting the dang project moving trumps perfection.
Can't you compare the dish on the pistons you still have at the bench? You have the forked `B' grade as a standard and at least one other of the used ones.
And as fahr-side suggested, check piston weight. You can also do that with the spares. New stock is within a gram or two out of the box, around 415g for the set I worked with. I'd weigh them first. It'd be astounding if they had the same weight but different crowns.
I'm not certain the used pistons are all from the same motor, so the weight of one may not represent the others. The new take-out pistons probably didn't come from the same motor either, but I did weigh them to confirm they're all close to each other. I'm sure I wrote the numbers down somewhere...
Tonight's plan:
Turn on air conditioner :)
Remove piston F
Weigh piston F
Measure dish of used piston F
Measure dish of new piston B
Reinstall piston F
Measure dish of piston in cyl #2 (if feasible)
Reinstall all access hole plugs and covers (transmission side)
Seal engine using tape and ear plugs
Place engine on stand
Sand rusty spots on oil pan
Clean coolant crossover pipe
Paint oil pan and crossover pipe
The Internet doesn't need to know what my daily goals are, but writing down what I'm hoping to accomplish each day has really helped me to stay on-task and not get side tracked.
After all, goals are only dreams until there's a written plan.
Edited by StkmltS
"Plans are worthless, but planning is everything."
-- Dwight D. Eisenhower
"No battle plan survives contact with the enemy."
-- German military strategist Helmuth von Moltke
I'm all for planning.
And the one I use when talking about strategic planning with clients is a version of Monson's quote:
"People/companies don't plan to fail, they just fail to plan."
The rear main seal is evenly flush with the OD (outside diameter) in the case.
All three access hole plugs have new gaskets and ultra grey, and are tq'd to 50.6 ft/lbs.
Rear cover plate screws are tq'd at 4.7 ft/lbs (56.4 in/lbs). The small cover has a new o-ring, and the baffle plate has ultra grey. The screws holding on the large baffle plate can be a real PITA to get out. I had to ez-out two of them, so I replaced all six with new M6-1.0 x 14mm screws for good measure (from Home Depot).
I've only used a few new gaskets so far, but the pics in Bonbon's master gasket thread have already been very helpful.
Edited by StkmltS
  • Moderators
What's the torque for the coolant crossover pipe bolts? The spec isn't where I want it to be in the service manual.
It's just one bolt right? Looks like FSM says 4.7 ft/lb (6.4 Nm). Page 1716.
Don't really see why it would matter though. Just snug it down and you should be good, don't strip it.
Not currently in stock :(
