6th Gen Legacy Wheel Thread
  • Replies 896
  • Created
  • Last Reply
Top Posters In This Topic
I'm eyeing this Enkei TY-5 in Pearl Black that should be available summer '16. This its the same as what Simonsez posted. Size chart is here.
If I stay 18" and go for 245/45R18 tires, will 18x8.5, insert 50 work (seems close to the WRX offset 55 some of you guys have on).
If I go 19" with 245/40R19 tires, will 19x8.5, insert 35 work?
http://i65.tinypic.com/168c5eh.jpg
Edited by evo171
Sizes that fit/work:
18x8.5 ET45-55 (WRX/STI size - quite a few running these)
19x8.5 ET45-55 (same offset as you're running same width as above)
19x9 ET50
If you run 19x8.5 ET35 you may need to roll your guards to avoid rubbing. These will sit out 20mm more than the WRX/STI fitment of ET55.
Edited by tigger73
  • 2 weeks later...
Wheel: Miro Type 111
Specs: 19x8.5 +35
Tyres: Nankang AS-1 235/40r19
Suspension: RS-R springs, dropped 1.2 inches on the front, .5 in the back
These have been posted a couple of pages back but the lowering now set it off. On point kayslay!:wub:
http://legacygt.com/forums/attachment.php?attachmentid=226049&d=1457265633
http://legacygt.com/forums/attachment.php?attachmentid=226050&d=1457265633
http://legacygt.com/forums/attachment.php?attachmentid=226051&d=1457265633
http://legacygt.com/forums/attachment.php?attachmentid=226052&d=1457265633
http://legacygt.com/forums/attachment.php?attachmentid=226053&d=1457265633
Wheels: Weds SA55M
Specs: 19 x 8.0 ET45 (to be confirmed)
Suspension: Lowered 2 inches on H&R Lowering springs
Wheels and photos courtesy of Generalxxx :)
http://legacygt.com/forums/attachment.php?attachmentid=224664&d=1455314069
http://legacygt.com/forums/attachment.php?attachmentid=224665&d=1455314069
Edited by tigger73
Specs: 19x8.5 +35
Gosh that's gorgeous. I love it!
What size exhaust tips are those, SubieN8?
Quick question for you, the factory 18"s are 50 series, any reason why you went with 45 series instead, wouldn't that make the overall diameter smaller? I'm thinking about getting a set of those and want to make sure I have a clear understanding of the sizes. Thanks!
Edited by vpdjc
^ Barely noticeable really. The WRX wheels I have are 8.5. The stock Limiteds are 8. There's not as many tire choices for the 8.5 wheel as there are for the 8. So I went with an inexpensive summer tire that was brand name and looked good. I could have done 235/50/18 but that limited my choices and I wanted a wider tire.
Got it, thanks.
Are you sure the Limiteds are 8? I was pretty sure they're 7.5.
You are correct. All 2015/2016 Legacy alloy wheels are 7.5 width. (Outbacks are all 7.0.) It's not clear whether the steel wheels supplied for base-trim Legacys are 7.5 or 7.0.
Source: 2015 Legacy/Outback Factory Service Manual, page WT-2.
Source: 2015 Legacy/Outback Owners Manual, page 12-9.
Edited by ammcinnis
"If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland)
I am sorry, I believe you are correct.
Yes the Limited is a 7.5.. When i swapped my Wheels i used the stock tires didint have any issues, but when I get my New Wheels i plan on using 225/45/19 General GMax AS03's.. I didnt want a 245 just because they might interfere with my Fenders when I lower the Bags..
Sent from my SM-G930P using Tapatalk
You must be going for the Storm Trooper look. What wheels are those?
I'm just waiting when I can win the 6th Gen Photo Contest and make the challenge Star Wars related. Yes I own a set of trooper armor.
Specs: 19x8.5 +35
Not to be redundant but i'm in love with the Type 111 Limited Edition, even after lowering, are you rubbing in any way at all? Thanks
No rubbing at all but to make sure, after installing rear springs I partially rolled the rear fenders to give the tire some extra clearance
Would 19x8.5 et50 be almost flush? They have 19x8 et45 but I prefer the 8.5 width.
You'll be 100% fine. kayslay's wheels are same spec (19x8.5) with +35 offset so "poke" 15mm more than the ET50 you're looking at and he had no rubbing at stock height.
If I was getting wheels again I'd go with a 19" as there's still a lot of tyre sidewall with 18's.
No, offset is too high.
Maybe on a gen5 but us gen6's have a lot more room under our guards.
Edited by tigger73
It's ok, I've ordered the BBS SR 19x8.5 et45.
