DougKelly20 Posted March 30, 2021 Share Posted March 30, 2021 Did you mean 8.5? 9.5 seems a little much. Did you check out fitment industries like I suggested? Link to comment Share on other sites More sharing options...
ammcinnis Posted March 30, 2021 Share Posted March 30, 2021 So would I be safe with a ... Define "safe." "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Capt99ws6 Posted March 30, 2021 Share Posted March 30, 2021 (edited) The 9.5's are +38 and the 8's are +35 that I'm looking at. Thought the 9.5's with +38 would fit better than the 8's +35?? I did look at fitment industries and people have run both, but none are on stock suspension. So I'm not really sure what one would fit the best without many issues. And by "safe" I mean no real big issues. Don't mind a little work to get them to fit without rubbing Edited March 30, 2021 by Capt99ws6 Link to comment Share on other sites More sharing options...
Capt99ws6 Posted March 30, 2021 Share Posted March 30, 2021 Looks like the 18x8's +35 with 245/45/18's will work the best. Link to comment Share on other sites More sharing options...
DougKelly20 Posted March 31, 2021 Share Posted March 31, 2021 Yeah those should fit fine. I guess I was just curious why you ruled out 8.5 and 9 and went straight to 9.5 as an option. With stock suspension you have a much larger margin for error, so I doubt you'll need to camber or roll fenders. Good luck and post pics when you get them installed! Link to comment Share on other sites More sharing options...
darrien917 Posted April 22, 2021 Share Posted April 22, 2021 So would I be safe with a 18x9.5 +38mm with a 245/45/18 tire on stock suspension? (I have 19x9.5 +25) and with no negative camber it sticks out passed the fender width. i had a picture but cant find it lol and looks weird/bad with no camber i would recommend staying in the 8 or 8.5 to be honest. but if you really want some meaty fitment +30 would probably be best and would maybe rub but * hey you only got one life to live. Link to comment Share on other sites More sharing options...
aki334 Posted April 25, 2021 Share Posted April 25, 2021 does anyone know the weight of the 17" wheels that come with base model? 17" 7.5 width Link to comment Share on other sites More sharing options...
DougKelly20 Posted April 26, 2021 Share Posted April 26, 2021 IIRC the 18s were around 26 lbs, so I imagine the 17s aren't more than a lb lighter. Link to comment Share on other sites More sharing options...
aki334 Posted April 26, 2021 Share Posted April 26, 2021 (edited) What you guys think about this wheels? Selected them mostly because of the same offset (55mm) SUPERTURISMO AERO OZ RACING 19" https://www.ozracing.com/alloy-wheels/oz-racing/i-tech/superturismo-aero they are 19" 8.5 wide - tirerack recomends 225 45 19 can I do 245 40 19 on stock suspension? will they look nice on white legacy? Edited April 26, 2021 by aki334 Link to comment Share on other sites More sharing options...
DougKelly20 Posted April 27, 2021 Share Posted April 27, 2021 I imagine they will look nice. As for the tire selection, I have 225s on 8.5s because I had them laying around...not by design. I wouldn't recommend 225s. Lip is too exposed. Go with 245s. As for the offset, I guess the extra inch probably won't be too problematic, but remember you'll still not be anywhere close to flush and you're adding width on the suspension side at that point. From all the time I've been in my wheel well recently I can affirm you likely won't foul on the perch but you might like the look better with +45. Link to comment Share on other sites More sharing options...
Milse Posted May 9, 2021 Share Posted May 9, 2021 Hi All, I have my old STi aftermarket wheels and was wondering if 18x9.5 +45 on 245/45/18 would work on stock suspension. Currently the wheels are mounted on 255/35/18 rs4s but I don't think that setup would work well. Thank you in advance! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DougKelly20 Posted May 10, 2021 Share Posted May 10, 2021 Shouldn't be a problem. Link to comment Share on other sites More sharing options...
GustOfWind Posted May 26, 2021 Share Posted May 26, 2021 Hey guys, So I’ve got a set of wheels on the way that are 18x8 +35 and was looking for opinions on tires. I saw a guy on reditt running the same wheels on 225/50/r18 tires and he confirmed that they didn’t rub but I’m wondering if I can get away with 245/45r18 tires with no rub. I don’t love the fat sidewall of the stock size 225s and The 245s would actually have a slightly lower speedo error apparently. I am on stock suspension and I realize it’ll be close but wanted to know what you guys thought, 225s or 245s? Link to comment Share on other sites More sharing options...
DougKelly20 Posted May 26, 2021 Share Posted May 26, 2021 Very similar to the last few posts in this thread. Read up, but you should be good. Link to comment Share on other sites More sharing options...
MrCobbs Posted June 8, 2021 Share Posted June 8, 2021 2020 STI Wheels vs Michelin Pilot Sport AS 4 (245/40/19) Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
iyalla Posted June 11, 2021 Share Posted June 11, 2021 Wow, that looks really good ^^ Link to comment Share on other sites More sharing options...
naimouasta Posted July 4, 2021 Share Posted July 4, 2021 Agreed. Looks good. Stock height? Link to comment Share on other sites More sharing options...
ammcinnis Posted August 7, 2021 Share Posted August 7, 2021 Huh? "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
DougKelly20 Posted August 24, 2021 Share Posted August 24, 2021 Switched from the leftover tires I had off my Optima that I finally burned up which were 225/45-18's to some meaty 245/45-18 conti extreme contact DWS06 Plus tires on my 8.5 inch +45 Enkei TFRs. Fitment is perfect. I'm lowered on BC BRs by about 1.5" and theres no rubbing at all. Glad to have more sidewall back!! It also increased the ride height a bit which I needed because frankly I was too low... Only downside is the extra weight requires more braking effort and hampers acceleration a bit. So far I'm very happy with the extra grip though! Link to comment Share on other sites More sharing options...
DougKelly20 Posted September 15, 2021 Share Posted September 15, 2021 Now with pics Sent from my Pixel 5a using Tapatalk Link to comment Share on other sites More sharing options...
Febreze Mee Posted September 16, 2021 Share Posted September 16, 2021 Wow! That looks REALLY good Doug MILKRUN - Click Here Link to comment Share on other sites More sharing options...
JRu17 Posted November 14, 2021 Share Posted November 14, 2021 (edited) Does anyone know the oem 2015 2.5 premium wheel weight Edited November 16, 2021 by JRu17 Link to comment Share on other sites More sharing options...
