halvarez430 Posted July 31, 2020 Share Posted July 31, 2020 15 legacy what ya thinks Sent from my SM-G975U using Tapatalk Link to comment Share on other sites More sharing options...
T2018 Posted August 1, 2020 Share Posted August 1, 2020 15 legacy what ya thinks Sent from my SM-G975U using TapatalkI like Sent from my SM-N975U using Tapatalk Link to comment Share on other sites More sharing options...
T2018 Posted August 1, 2020 Share Posted August 1, 2020 More pictures of the new wheels Sent from my SM-N975U using Tapatalk Link to comment Share on other sites More sharing options...
halvarez430 Posted August 2, 2020 Share Posted August 2, 2020 Niche 19in Sent from my SM-G975U using Tapatalk Link to comment Share on other sites More sharing options...
Dirtracr95 Posted September 25, 2020 Share Posted September 25, 2020 (edited) 20x8.5+45 with 255/35/20 Pirelli P Zero's Edited September 25, 2020 by Dirtracr95 Link to comment Share on other sites More sharing options...
Kay2DaA Posted September 27, 2020 Share Posted September 27, 2020 20x8.5+45 with 255/35/20 Pirelli P Zero's How's the ride and road noise of the Pirelli's? I'm running a set of Toyo Tires 245/35/20 and I'm not a fan. Your's is the most flush I've seen with 20s. My offset right now is a +35. I'm about to install a set of saggy butt spacers for the rear cause I hate hearing it bump whenever I go over any kind of bump. Have you run into that issue with your wheels? Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Dirtracr95 Posted October 4, 2020 Share Posted October 4, 2020 How's the ride and road noise of the Pirelli's? I'm running a set of Toyo Tires 245/35/20 and I'm not a fan. Your's is the most flush I've seen with 20s. My offset right now is a +35. I'm about to install a set of saggy butt spacers for the rear cause I hate hearing it bump whenever I go over any kind of bump. Have you run into that issue with your wheels? Sent from my SM-N920V using TapatalkThese Pirelli's are fantastic. I got them from a friend who works at Audi. Guy bought a new A6 or S6 and after 1000 miles swapped them out for Michelin's. The fitment is pretty spot on. I wish the front was 1/2" lower. The rear I was worried about rubbing but I guess it clears just perfectly. Rear camber is like -1.6°. If it were less negative I think it would be rubbing Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
Dirtracr95 Posted October 4, 2020 Share Posted October 4, 2020 How's the ride and road noise of the Pirelli's? I'm running a set of Toyo Tires 245/35/20 and I'm not a fan. Your's is the most flush I've seen with 20s. My offset right now is a +35. I'm about to install a set of saggy butt spacers for the rear cause I hate hearing it bump whenever I go over any kind of bump. Have you run into that issue with your wheels? Sent from my SM-N920V using TapatalkHere's some more fitment photos. Also I'm lowered on H&R springs Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
ChadDad Posted October 7, 2020 Share Posted October 7, 2020 (edited) Put on some Wedsport TC105n with HR springs, and STI Front Brakes. I am very happy with the springs I was concerned at first but the ride quality is great. Edited October 7, 2020 by ChadDad Link to comment Share on other sites More sharing options...
mind Posted October 12, 2020 Share Posted October 12, 2020 I moved on from my Legacy a few years back but have a set of winter rims and tires. What would be the best way to sell them? Link to comment Share on other sites More sharing options...
darrien917 Posted October 15, 2020 Share Posted October 15, 2020 19x9.5+27 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
darrien917 Posted October 15, 2020 Share Posted October 15, 2020 BC Racing BR Series Extreme Low with swift springs Cusco RLCA (from BRZ) PSM Rear toe arms (Also from BRZ) Gram light 57DR wrapped in 225/35R19 [emoji2956][emoji2956] Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
DougKelly20 Posted October 15, 2020 Share Posted October 15, 2020 (edited) BC Racing BR Series Extreme Low with swift springs Cusco RLCA (from BRZ) PSM Rear toe arms (Also from BRZ) Gram light 57DR wrapped in 225/35R19 [emoji2956][emoji2956] Sent from my iPhone using TapatalkLooks great man! Did you need both the LCAs AND toe arms to get proper alignment. I'm running -2.4 camber out back and I'd really rather be closer to -1 but they said they can't. Gonna some more research on here because I know it's been addressed but what camber are you running? Was the LCA part KTA216A (whiteline)? Edited October 15, 2020 by DougKelly20 Link to comment Share on other sites More sharing options...
darrien917 Posted October 16, 2020 Share Posted October 16, 2020 Looks great man! Did you need both the LCAs AND toe arms to get proper alignment. I'm running -2.4 camber out back and I'd really rather be closer to -1 but they said they can't. Gonna some more research on here because I know it's been addressed but what camber are you running? Was the LCA part KTA216A (whiteline)? The control arms: http:// https://www.systemmotorsports.com/collections/cusco-frs-brz/products/cusco-rear-control-arms-rear-lateral-links-2013-frs-brz-wrx-sti Rear Toe arms http:// https://store.partsshopmax.com/shop/FRSBRZ/MultilinkSteering/ZNC6TOE.html My camber is -3 rear and -2 front (Approximately) Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
jca1386 Posted November 27, 2020 Share Posted November 27, 2020 Apologies for the noob question. I’ve found a set of new 2020 wrx wheels for sale locally. They’re the 18” version and from what I’ve read they’re 8.5 vs the stock 7.5 I’ve got on my 17 premium. If I were to buy them and put new 235/50/18s on them am I going to have any issues or problems with clearance? Thank you! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
PATS4LIFE Posted November 27, 2020 Share Posted November 27, 2020 Apologies for the noob question. I’ve found a set of new 2020 wrx wheels for sale locally. They’re the 18” version and from what I’ve read they’re 8.5 vs the stock 7.5 I’ve got on my 17 premium. If I were to buy them and put new 235/50/18s on them am I going to have any issues or problems with clearance? Thank you! Sent from my iPhone using Tapatalk You’ll be fine should be no issues at all. Link to comment Share on other sites More sharing options...
DougKelly20 Posted November 27, 2020 Share Posted November 27, 2020 Yeah, I upgraded to 8.5s and I'm lowered with no issues. Bumping up to 245s next and I won't have any issues there either. Link to comment Share on other sites More sharing options...
d0bdish18 Posted November 29, 2020 Share Posted November 29, 2020 My "wheel math" is not strong as it's my first car, so would need your thoughts guys. I'm looking into two different wheels: 18x8.5 ET45 (On 245/45/R18) Or 18x8 ET38 (also on 245/45/R18) Which one would be less "problematic" in terms of fitment / rubbing and less speedo error? It's for 2016 Legacy, Base model, all stock. Sent from my Pixel 4 using Tapatalk Link to comment Share on other sites More sharing options...
DougKelly20 Posted December 3, 2020 Share Posted December 3, 2020 Both setups will be 0.66% smaller in circumference from stock, and cause no issues other than your speedo reading slightly faster than actual. I have the 8.5 ET45 setup with no issues. I don't think the 8 ET38 would cause issues either but it will be close. All depends how concave you want your setup to look. http://Www.willtheyfit.com is the resource I use, and then check out fitment industries' gallery for how much poke you want. Link to comment Share on other sites More sharing options...
Capt99ws6 Posted March 18, 2021 Share Posted March 18, 2021 Sorry for the nob question but my eyes hurt from looking through the thread! lol I am looking at getting a 18x8 with a 35mm offset wheels. What it the widest tire I can run without any problems? I am on stock suspension on my 15 3.6r. Thanks!! Link to comment Share on other sites More sharing options...
DougKelly20 Posted March 18, 2021 Share Posted March 18, 2021 Conservatively probably 245s. That said when I was shopping for wheels I tried to take some measurements and decided +35 was a bit too close for comfort with my 225s....but I'm lowered. So I got +45s. Later this year when I need new tires I'll be going up to 245s, but I can add (technically subtract) some camber if I need to. That said I have 8.5" rims. I'm not sure if you want to go as high as 255 on an 8 inch rim, and I'm not sure it will fit in the rear with +35, but I would check out fitment industries gallery if I were you and look at all the stretch and stance you can find in the same range, even if it's on a wrx or something similar. Link to comment Share on other sites More sharing options...
DougKelly20 Posted March 18, 2021 Share Posted March 18, 2021 FWIW here is mine on 18x8.5+45 with 225s. Link to comment Share on other sites More sharing options...
Capt99ws6 Posted March 18, 2021 Share Posted March 18, 2021 Thanks for the help!!! Link to comment Share on other sites More sharing options...
d0bdish18 Posted March 20, 2021 Share Posted March 20, 2021 Finally got my first aftermarket wheels. Fc04 18x8 ET 40 Bridgestone Turanza QuietTrack 225/50 Sent from my Pixel 4 using Tapatalk Link to comment Share on other sites More sharing options...
Capt99ws6 Posted March 30, 2021 Share Posted March 30, 2021 So would I be safe with a 18x9.5 +38mm with a 245/45/18 tire on stock suspension? Link to comment Share on other sites More sharing options...
