NYtoVT Posted February 19, 2016 Share Posted February 19, 2016 Check your tire rotation, if they're still on the car; the driver's rear is mounted backwards!! http://uploads.tapatalk-cdn.com/20160215/c3d15934008008c42fa90474d3f49b53.jpg Link to comment Share on other sites More sharing options...
SubieN8 Posted February 19, 2016 Share Posted February 19, 2016 I will do that this weekend. I am not used to directional tires. Seems to ride okay. Thanks for the heads up Link to comment Share on other sites More sharing options...
evo171 Posted February 24, 2016 Share Posted February 24, 2016 (edited) I'm eyeing this Enkei TY-5 in Pearl Black that should be available summer '16. This its the same as what Simonsez posted. Size chart is here. If I stay 18" and go for 245/45R18 tires, will 18x8.5, insert 50 work (seems close to the WRX offset 55 some of you guys have on). If I go 19" with 245/40R19 tires, will 19x8.5, insert 35 work? http://i65.tinypic.com/168c5eh.jpg Edited February 24, 2016 by evo171 Link to comment Share on other sites More sharing options...
tigger73 Posted February 24, 2016 Author Share Posted February 24, 2016 (edited) Sizes that fit/work: 18x8.5 ET45-55 (WRX/STI size - quite a few running these) 19x8.5 ET45-55 (same offset as you're running same width as above) 19x9 ET50 If you run 19x8.5 ET35 you may need to roll your guards to avoid rubbing. These will sit out 20mm more than the WRX/STI fitment of ET55. Edited February 24, 2016 by tigger73 Tigger73's MY15 2.5i build Link to comment Share on other sites More sharing options...
tigger73 Posted March 7, 2016 Author Share Posted March 7, 2016 Wheel: Miro Type 111 Specs: 19x8.5 +35 Tyres: Nankang AS-1 235/40r19 Suspension: RS-R springs, dropped 1.2 inches on the front, .5 in the back These have been posted a couple of pages back but the lowering now set it off. On point kayslay! http://legacygt.com/forums/attachment.php?attachmentid=226049&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226050&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226051&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226052&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226053&d=1457265633 Tigger73's MY15 2.5i build Link to comment Share on other sites More sharing options...
tigger73 Posted March 7, 2016 Author Share Posted March 7, 2016 (edited) Wheels: Weds SA55M Specs: 19 x 8.0 ET45 (to be confirmed) Suspension: Lowered 2 inches on H&R Lowering springs Wheels and photos courtesy of Generalxxx http://legacygt.com/forums/attachment.php?attachmentid=224664&d=1455314069 http://legacygt.com/forums/attachment.php?attachmentid=224665&d=1455314069 Edited March 7, 2016 by tigger73 Tigger73's MY15 2.5i build Link to comment Share on other sites More sharing options...
asegal17 Posted March 7, 2016 Share Posted March 7, 2016 Wheel: Miro Type 111 Specs: 19x8.5 +35 Tyres: Nankang AS-1 235/40r19 Suspension: RS-R springs, dropped 1.2 inches on the front, .5 in the back These have been posted a couple of pages back but the lowering now set it off. On point kayslay! http://legacygt.com/forums/attachment.php?attachmentid=226049&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226050&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226051&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226052&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226053&d=1457265633 Gosh that's gorgeous. I love it! Link to comment Share on other sites More sharing options...
vpdjc Posted March 10, 2016 Share Posted March 10, 2016 (edited) What size exhaust tips are those, SubieN8? Quick question for you, the factory 18"s are 50 series, any reason why you went with 45 series instead, wouldn't that make the overall diameter smaller? I'm thinking about getting a set of those and want to make sure I have a clear understanding of the sizes. Thanks! Edited March 10, 2016 by vpdjc Link to comment Share on other sites More sharing options...
SubieN8 Posted March 10, 2016 Share Posted March 10, 2016 ^ Barely noticeable really. The WRX wheels I have are 8.5. The stock Limiteds are 8. There's not as many tire choices for the 8.5 wheel as there are for the 8. So I went with an inexpensive summer tire that was brand name and looked good. I could have done 235/50/18 but that limited my choices and I wanted a wider tire. Link to comment Share on other sites More sharing options...
vpdjc Posted March 10, 2016 Share Posted March 10, 2016 ^ Barely noticeable really. The WRX wheels I have are 8.5. The stock Limiteds are 8. There's not as many tire choices for the 8.5 wheel as there are for the 8. So I went with an inexpensive summer tire that was brand name and looked good. I could have done 235/50/18 but that limited my choices and I wanted a wider tire. Got it, thanks. Link to comment Share on other sites More sharing options...
SubyBru Posted March 10, 2016 Share Posted March 10, 2016 http://uploads.tapatalk-cdn.com/20160310/2fafc492e8806c63a8839a1482327b84.jpg Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
Paradox Posted March 10, 2016 Share Posted March 10, 2016 ^ Barely noticeable really. The WRX wheels I have are 8.5. The stock Limiteds are 8. There's not as many tire choices for the 8.5 wheel as there are for the 8. So I went with an inexpensive summer tire that was brand name and looked good. I could have done 235/50/18 but that limited my choices and I wanted a wider tire. Are you sure the Limiteds are 8? I was pretty sure they're 7.5. Link to comment Share on other sites More sharing options...
ammcinnis Posted March 10, 2016 Share Posted March 10, 2016 (edited) I was pretty sure they're 7.5. You are correct. All 2015/2016 Legacy alloy wheels are 7.5 width. (Outbacks are all 7.0.) It's not clear whether the steel wheels supplied for base-trim Legacys are 7.5 or 7.0. Source: 2015 Legacy/Outback Factory Service Manual, page WT-2. Source: 2015 Legacy/Outback Owners Manual, page 12-9. Edited March 10, 2016 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
SubieN8 Posted March 10, 2016 Share Posted March 10, 2016 Are you sure the Limiteds are 8? I was pretty sure they're 7.5. I am sorry, I believe you are correct. Link to comment Share on other sites More sharing options...
Grnlantern1 Posted March 10, 2016 Share Posted March 10, 2016 I am sorry, I believe you are correct. Yes the Limited is a 7.5.. When i swapped my Wheels i used the stock tires didint have any issues, but when I get my New Wheels i plan on using 225/45/19 General GMax AS03's.. I didnt want a 245 just because they might interfere with my Fenders when I lower the Bags.. Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted March 10, 2016 Share Posted March 10, 2016 http://uploads.tapatalk-cdn.com/20160310/2fafc492e8806c63a8839a1482327b84.jpg Sent from my iPad using Tapatalk You must be going for the Storm Trooper look. What wheels are those? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
SubieN8 Posted March 10, 2016 Share Posted March 10, 2016 ^ They are the Premium wheels, partially Plasti-Dipped. Link to comment Share on other sites More sharing options...
GTEASER Posted March 10, 2016 Share Posted March 10, 2016 :lol: I see it now! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
SubyBru Posted March 11, 2016 Share Posted March 11, 2016 You must be going for the Storm Trooper look. What wheels are those? I'm just waiting when I can win the 6th Gen Photo Contest and make the challenge Star Wars related. Yes I own a set of trooper armor. Link to comment Share on other sites More sharing options...
vpdjc Posted March 16, 2016 Share Posted March 16, 2016 Wheel: Miro Type 111 Specs: 19x8.5 +35 Tyres: Nankang AS-1 235/40r19 Suspension: RS-R springs, dropped 1.2 inches on the front, .5 in the back These have been posted a couple of pages back but the lowering now set it off. On point kayslay! http://legacygt.com/forums/attachment.php?attachmentid=226049&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226050&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226051&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226052&d=1457265633 http://legacygt.com/forums/attachment.php?attachmentid=226053&d=1457265633 Not to be redundant but i'm in love with the Type 111 Limited Edition, even after lowering, are you rubbing in any way at all? Thanks Link to comment Share on other sites More sharing options...
kayslay21 Posted March 16, 2016 Share Posted March 16, 2016 Not to be redundant but i'm in love with the Type 111 Limited Edition, even after lowering, are you rubbing in any way at all? Thanks No rubbing at all but to make sure, after installing rear springs I partially rolled the rear fenders to give the tire some extra clearance Link to comment Share on other sites More sharing options...
vpdjc Posted March 16, 2016 Share Posted March 16, 2016 Would 19x8.5 et50 be almost flush? They have 19x8 et45 but I prefer the 8.5 width. Link to comment Share on other sites More sharing options...
Unsp0kn Posted March 17, 2016 Share Posted March 17, 2016 Would 19x8.5 et50 be almost flush? They have 19x8 et45 but I prefer the 8.5 width. No, offset is too high. Link to comment Share on other sites More sharing options...
tigger73 Posted March 17, 2016 Author Share Posted March 17, 2016 (edited) Would 19x8.5 et50 be almost flush? They have 19x8 et45 but I prefer the 8.5 width. You'll be 100% fine. kayslay's wheels are same spec (19x8.5) with +35 offset so "poke" 15mm more than the ET50 you're looking at and he had no rubbing at stock height. If I was getting wheels again I'd go with a 19" as there's still a lot of tyre sidewall with 18's. No, offset is too high. Maybe on a gen5 but us gen6's have a lot more room under our guards. Edited March 17, 2016 by tigger73 Tigger73's MY15 2.5i build Link to comment Share on other sites More sharing options...
vpdjc Posted March 17, 2016 Share Posted March 17, 2016 You'll be 100% fine. kayslay's wheels are same spec (19x8.5) with +35 offset so "poke" 15mm more than the ET50 you're looking at and he had no rubbing at stock height. If I was getting wheels again I'd go with a 19" as there's still a lot of tyre sidewall with 18's. It's ok, I've ordered the BBS SR 19x8.5 et45. Maybe on a gen5 but us gen6's have a lot more room under our guards. Link to comment Share on other sites More sharing options...
