1-3-2-4 Posted September 28, 2017 Share Posted September 28, 2017 I just bought these arms for my wagon. $179 shipped for L&R front aluminum LCAs. Only listed for 07-09 legacy's, not an option for 05-06. https://www.rockauto.com/en/parts/mas,CB72083,control+arm,10401 You got two of the same part number? I thought the l&r had different part numbers? Link to comment Share on other sites More sharing options...
sshole Posted September 28, 2017 Share Posted September 28, 2017 You got two of the same part number? I thought the l&r had different part numbers? You're correct. Left and right arms have different part numbers. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 28, 2017 Share Posted September 28, 2017 You're correct. Left and right arms have different part numbers. Ok just making sure I can't wait to do the suspension next Link to comment Share on other sites More sharing options...
Volta55 Posted September 28, 2017 Share Posted September 28, 2017 $116 on parts geek. com https://www.partsgeek.com/catalog/2005/subaru/legacy/suspension/control_arm.html my passenger side is shot.. will be placing an order in the next couple days for a set Link to comment Share on other sites More sharing options...
BoozeRS05 Posted September 28, 2017 Share Posted September 28, 2017 You got two of the same part number? I thought the l&r had different part numbers? Correct, different part numbers for L&R, hope that wasn't misleading. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
amp583 Posted October 2, 2017 Share Posted October 2, 2017 Are Mevotechs better than Spec B's? Have a good deal right now on a set. Link to comment Share on other sites More sharing options...
sshole Posted October 2, 2017 Share Posted October 2, 2017 I have a Spec B and installed the Mevotech arms. I can't tell a difference aside from new bushings and ooooh shiny. Link to comment Share on other sites More sharing options...
amp583 Posted October 2, 2017 Share Posted October 2, 2017 Mevotechs are still sold out. Another member posted MAS - https://www.rockauto.com/en/parts/mas,CB72083,control+arm,10401 They look very similar to Mevotechs and UltraPowers. Do you think these are also the same part with a different p/n? I have a Spec B and installed the Mevotech arms. I can't tell a difference aside from new bushings and ooooh shiny. Link to comment Share on other sites More sharing options...
kamnamurt Posted October 7, 2017 Share Posted October 7, 2017 Mevotechs are still sold out. Another member posted MAS - https://www.rockauto.com/en/parts/mas,CB72083,control+arm,10401 They look very similar to Mevotechs and UltraPowers. Do you think these are also the same part with a different p/n? In the link you provided is that for both control arms or just one? Also how are the bushings that are pre-installed on these? Thanks! Link to comment Share on other sites More sharing options...
MilesA Posted October 7, 2017 Share Posted October 7, 2017 In the link you provided is that for both control arms or just one? Also how are the bushings that are pre-installed on these? Thanks! Left and right are two different part numbers. Read posts starting around #293 going through 320 or so. http://legacygt.com/forums/showthread.php/killer-deal-lower-control-arms-245333.html?p=5648648 Link to comment Share on other sites More sharing options...
BoozeRS05 Posted October 7, 2017 Share Posted October 7, 2017 Here are said arms, left and right, two different part numbers, $179 shipped to my door. They look nice, solid rubber bushings, and light. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
sshole Posted October 7, 2017 Share Posted October 7, 2017 That rear control arm bushing (the larger one) looks exactly the same as the one that came stock on my Spec B which is why I opted for the Mevotech arms - the bushings look more substantial than the stock (and MAS) bushings. If these bushings wear out <100,000 miles, then I'll spring for the Whiteline or another bushing with added caster. Link to comment Share on other sites More sharing options...
amp583 Posted November 15, 2017 Share Posted November 15, 2017 That rear control arm bushing (the larger one) looks exactly the same as the one that came stock on my Spec B which is why I opted for the Mevotech arms - the bushings look more substantial than the stock (and MAS) bushings. If these bushings wear out <100,000 miles, then I'll spring for the Whiteline or another bushing with added caster. GOOD POINT. Anyone buy the mevos or others listed here and swap out for Whiteline bushings? On the fence if I should just swap bushings while my MAS arms are not installed. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted November 16, 2017 Share Posted November 16, 2017 Are these the same size as OEM? I've noticed a lowspeed clicking when turning, and wonder if these are messing with my CV axles. Replaced both axles and the issue persists. Link to comment Share on other sites More sharing options...
WRX USA Posted November 16, 2017 Share Posted November 16, 2017 Are these the same size as OEM? I've noticed a lowspeed clicking when turning, and wonder if these are messing with my CV axles. Replaced both axles and the issue persists. What about your wheel bearing/hub assemblies? Link to comment Share on other sites More sharing options...
Merc6 Posted November 16, 2017 Share Posted November 16, 2017 Here are said arms, left and right, two different part numbers, $179 shipped to my door. They look nice, solid rubber bushings, and light. The box and paper looks way more elegant than the Mevotechs I got. I'm most likely going to leave the arms as is when I put them on. I have way more rubber to replace already. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
funnyman06 Posted December 19, 2017 Share Posted December 19, 2017 Anyone have any input on the balljoint that mevotech includes with these? I have 2 NIB OEM balljoint's waiting to go in when I ordered these. I'm thinking of using the OEM and saving the mevotech for one of the other subaru's. Link to comment Share on other sites More sharing options...
98legwag Posted December 19, 2017 Share Posted December 19, 2017 Anyone have any input on the balljoint that mevotech includes with these? I have 2 NIB OEM balljoint's waiting to go in when I ordered these. I'm thinking of using the OEM and saving the mevotech for one of the other subaru's. The ball joint is beefier than stock. Its the STI style ball joint that has a different taper. Link to comment Share on other sites More sharing options...
funnyman06 Posted December 19, 2017 Share Posted December 19, 2017 The ball joint is beefier than stock. Its the STI style ball joint that has a different taper. From what I can tell the STI uses the same part number ball joint as the LGT. All the same, ill take that most people don't have issues with them and that they seem to be of decent quality. Link to comment Share on other sites More sharing options...
98legwag Posted December 20, 2017 Share Posted December 20, 2017 From what I can tell the STI uses the same part number ball joint as the LGT. All the same, ill take that most people don't have issues with them and that they seem to be of decent quality. I have been running them for a year. I am pleased. I wish I had taken a picture of the difference in the ball joint. Link to comment Share on other sites More sharing options...
kamnamurt Posted December 20, 2017 Share Posted December 20, 2017 I just installed these with new sway bar end links, they keep squealing when I go over speed bumps. Is this normal? When i tried to replace these lca with MOOG sway bar end links, they had a lube nipple that was extremely close to rubbing onto the lca. Anyone have any inputs on this? or is this because of the new rubber? Link to comment Share on other sites More sharing options...
kzr750r1 Posted December 21, 2017 Share Posted December 21, 2017 Did ya geese up all the parts during setup? If so give it a min. Don't remember nipple clearance issues with my Moog link install. Could be different if your LGT I guess. Do us all a favor and add some sig details about yourself and the car in question so we start off on common ground. Welcome. Link to comment Share on other sites More sharing options...
Pazuzu Posted December 26, 2017 Share Posted December 26, 2017 I just installed these with new sway bar end links, they keep squealing when I go over speed bumps. Is this normal? When i tried to replace these lca with MOOG sway bar end links, they had a lube nipple that was extremely close to rubbing onto the lca. Anyone have any inputs on this? or is this because of the new rubber?Yeah man this has been over a few times, common mistake. You can definitely install them so the nipple faces away from the lca. Ive done the install also myself so I know personally Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
HungryPillow Posted December 29, 2017 Share Posted December 29, 2017 I somehow stumbled into this thread just in time since all my bushings are pretty worn, so thanks for all the great info! I will most likely place an order for the front LCAs, just curious if anyone has found anything similar for the rears? Tried searching all over Rock Auto and eBay but couldn't find anything. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted December 30, 2017 Share Posted December 30, 2017 They come up in the marketplace for sale here semi frequently. Welcome, have a look around. http://legacygt.com/forums/forumdisplay.php/member-classifieds-2005-2009-30.html?f=30 EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
