WRX USA's 09 OBXT Build Thread
WRX USA
I purchased a 2002 WRX in October of 2001, something I had been planning to do since Subaru announced a WRX finally coming to the US. At that time I chose 'WRX USA' as my user name and I have no affiliation with the Subaru parts place in SoCal (although I am sure he hates that I have the gmail account and the California license plate). After modding my bugeye for almost 12 years, I wanted a daily driver that didn't attract as much attention and allowed me to go camping, hiking and on more road trips more comfortably. My intention was to take it easy on mods on my OBXT and go crazy on my WRX.
http://i672.photobucket.com/albums/vv87/JoshEAllen/12CA2E2D-5384-4317-80EF-DCDC64D3F884.jpg
I still have the bugeye as of February 2018.
wKHkNVT_d.jpg?maxwidth=5120&shape=thumb&fidelity=high
I purchased my 2009 satin white pearl Outback XT back in July 2013. I had been looking for 4-5 months trying to find a one owner five speed that was well maintained. I was willing to drive 600+ miles to Portland or somewhere else in the northwest where I could actually find one of these from time to time. Searching on CL one came up 50 miles away and within minutes of it being listed I had it held until the following day when I could come for a test drive. I bought it that next day and picked it up three days later, after they replaced the windshield. It had 77K miles on it and it was a one owner car and that owner lived about 15 miles from me and they traded it in on a newer Outback. Even though I had planned not to do major mods, I already had an AP V2, a Prova Si knob and a STi Genome strut tower brace. I should have known at that point that I was going to completely fail on "taking it easy" on the mods.
Here I am picking it up.
http://i672.photobucket.com/albums/vv87/JoshEAllen/IMG_6925.jpg
How it looks now:
yJxfCka_d.jpg?maxwidth=2560&shape=thumb&fidelity=high
hd2dN0G_d.jpg?maxwidth=2560&shape=thumb&fidelity=high
Power
IAG Stage 2 Tuff (#2476)
- new OEM block
- new OEM nitride coated crank
- Cosworth 1431 pistons
- IAG Spec H beam rods
- ACL “H” STD HX main bearings
- ACL “H” STD rod bearings
- Manley piston rings
ARP Head Stud Kit
Blouch DOM1.5xtr 2.4” inlet and 8cm hotside
Cobb SF intake and box
Cobb Flex Fuel Kit with Fuel Pressure Monitoring kit
Company 23 Anti-Surge EBCS
AEM 340lph fuel pump relayed to 12v source
-4 Fuel Return line
Fluidampr crank pulley
Fuelab Mini fuel pressure regulator 25-90psi
Grimmspeed TMIC w/ black thermal dispersant coating
Grimmspeed STi style hose for TMIC
GSC Beehive Valve Springs w/ Titanium Retainer Valvetrain Kit
GSC Power-Division Stainless Steel Exhaust Valves, 32mm
GSC Power-Division Stainless Steel Intake Valves, 36mm
IAG TGV Deletes (black)
IAG fuel rails anodized black
IAG fuel lines with STi FPR
IAG AOS in black
IAG air pump delete
ID1000's
IP&T V1 Filtered Oil Feed Kit
Killer B Motorsport High Flow Water Pump Housing (WPH)
Killer B Motorsport High Performance Oil Pan (EJ25Pan)
Killer B Motorsport Ultimate Oil Pickup (070-110)
Killer B Motorsport Oil Baffle Windage Tray (EJWT)
Killer B Holy Header with EWG V-Band Uppipe, Swaintech Coated
Koyo aluminum radiator
Perrin 2.4" black silicone turbo inlet
Prova Air Intake Guide
Samco ancillary, radiator and oil cooler lines
STi 11mm Oil pump
Subaru OEM water pump
Tial MV-S 38mm EWG in Black rerouted into downpipe
Tomei Poncams
Tomei Timing Belt Guide
TurboSmart BPV
Transmission/Driveline
SpecB 6MT (swapped at 114,850 miles with 63,500 miles on driveline swap)
SpecB Driveshaft
SpecB R180 Rear Diff
SpecB Front/Rear Axles
SpecB Aluminum R180 Rear Diff Mount
SpecB Clutch Slave Cylinder
SpecB Shift Linkage
Cobb Double Adjustable Short Throw Shifter
GroupN Transmission Mount
Cobb Front and Rear Shifter bushings
TiC transmission crossmember bushings (1001-01-0025)
Suspension
JDM Outback Bilstein Tuned Suspension (BTS-5056J)
SpecB top hats (20320AG01A)
SpecB dust cap (20326AG000)
JDM rear shock perch (20370AG010)
JDM rear rubber upper (20375AE011)
STi flexible front tower brace (ST2050221010)
STi flexible lower arm bar (ST2051221010)
STi front support kit (ST20106ZR000)
STi S402 flexible rear arm bar and matching floor board (ST2050321020/ST9506521010)
Whiteline 22mm front sway bar with lateral locks (BSF30Z)
Whiteline front end links (KLC32)
Whiteline 20mm rear sway bar with lateral locks (BSR39Z)
Whiteline rear end links (KLC144)
AVO HD rear sway bar mounts braces (S1104M1HT001T)
SpecB front aluminum control arms (polished and clear powdercoated)
Whiteline lower inner front bushing (W0508)
Whiteline lower inner rear bushing (anti-lift/caster correction) (KCA334)
Whiteline front roll center/bump steer - correction kit (KCA313)
SpecB rear upper aluminum lateral links (polished and clear powdercoated)
Whiteline upper inner bushing (W63396)
Whiteline upper outer bushing (camber correction) (KCA399)
SpecB Rear Aluminum Trailing Arms (polished and clear powdercoated)
Whiteline lower front bushing (W63398)
Whiteline lower rear outer bushing (W63394)
Cusco HD sway bar end link brackets (684316A, powdercoated gunmetal)
Whiteline adjustable rear lower front and rear lateral links (KTA124)
Whiteline rear control arm - lock bolt kit (toe correction) (KCA307)
Whiteline front steering - rack & pinion mount bushing (KSR207)
Cusco steering rack brace (692026ALHD, powdercoated gunmetal)
Perrin Steering Dampener Lockdown (PSP-SUS-565)
SpecB Steering Rack
Wheels/Lugs/Tires
Summers-
Enkei Raijin wheels, 18x8" gunmetal
Continental ExtremeContact DWS06 235/45ZR/18
Winters-
Subaru 2004 STi BBS wheels, 17x7.5" (powdercoated gunmetal)
Continental ExtemeContact DWS06 tires, 225/55ZR/17 (installed 11/7/15)
Spares-
Subaru JDM V7 STi wheels, 17x7.5" +53 (powdercoated gunmetal)
STi/McGuard black locking lug nuts (ST28170ST020)
STi/McGuard security lock nut set (ST28170ST060)
Brakes
04 STi Brembos (rebuilt and powdercoated white with gunmetal logos)
DBA T2 front rotors (DBA4654S-10)
DBA T3 rear "adapter" rotors (DBA4655S-10)
Technafit rear stainless steel lines (SUB-1125CL)
Stoptech front stainless steel lines
KNS Brakes rear Legacy Brembo swap stainless lines (bSWAP-100 Clear)
KNS Brakes v1.1 rear Brembo adapter brackets (KNS-005)
Porterfield R4S front brake pads (AP1001-R4S)
Porterfield R4S rear brake pads (AP961-R4S)
Motul M550 brake fluid
Grimmspeed master cylinder brace (091029)
Interior/Convenience
JDM STi/Recaro passenger’s seat with side impact airbag (mounted in USDM drivers position and modified with OEM seat heating element)
JDM STi/Recaro driver’s seat with side impact airbag (mounted in USDM passengers position and retrofitted with USDM OEM Occupany Detection system and modified with OEM seat heating element)
EDM facelift center console swap
STi parking brake lever
WC Lathewerks Titanium reverse lockout, shift boot retainer, and parking brake button
WRX dead pedal
WRX drive-by-wire accelerator pedal
WRX clutch and brake pedal
Prova yellow wide view rear view mirror (90130IT0020)
Prova Si-Drive selector knob, black (90000IP0100)
DAMD steering wheel, round, black leather with black stitching (SS358S-2)
Prova shift knob (94000MS0011)
Subaru JDM dual center console
Pioneer AVIC-8000NEX
Infinity Reference 6500CX 6.5”+ front door speakers
Alpine tweeter panel (KTX-F01LE)
Infinity Reference 6032CF 6.5" rear door speakers (with adapters from phenryiv1)
Subaru JDM Tuned by STi doorcards with Alcantara
Subaru JDM double DIN/dual climate control panels (H6217AG911)
Subaru JDM Hazard Switch (83037AG001)
Subaru JDM Clean Box
Subaru JDM rear bumper luggage cover (E1017AG000)
Subaru JDM STi door sills (ST5802021000)
Subaru JDM Alcantara covered center armrest
Subaru JDM rear all-weather cargo mat (J5017AG360)
Subaru JDM SpecB reclining rear seat with cup holders in armrest (perf’d black Alcantara/leather)
Subaru JDM rear trim pieces (with slots for reclining seat)
Subaru JDM rear seat belt guides (for reclining seats)
Subaru JDM reclining rear seat brackets
Subaru JDM black D pillars and rear gate window surround
Subaru JDM rear cargo cover/tonneau (for reclining rear seats)
Subaru OEM side and middle cargo nets
SpecB Shifter Trim
STi/Defi Performance Gauge Pack (Boost/Oil Pressure/Oil Temp)
Dynamat Xtreme and 1/2" Dynaliner on all 4 doors
Dynamat Xtreme in spare wheel well
All interior lights converted to LED
All black trunk floor (w/S402 specific floor board)
Exterior
Subaru JDM Outback D-F Bumper
Subaru JDM Outback bumper beam with lines for washer headlights
Subaru JDM Outback D-F Bumper Skirts (E2417AG090)
Subaru JDM S402 Grille (from #241)
ZeroSports Carbon Fiber Grille with badge
Subaru JDM Outback Grille
Subaru JDM S402 HID Washer Headlights (with LED turn and city lights)
Subaru JDM Outback D-F Foglights
Subaru JDM Outback Fenders
Subaru JDM Outback Flares
Subaru JDM Outback Fender Liners
Subaru USDM Aluminum hood
Subaru USDM Hood Scoop
Subaru JDM Outback rear bumper
Subaru USDM Legacy GT rear bumper beam
Liberal wagon spoiler
Liberal under panel
Subaru JDM waist spoiler (E7217AG010)
Subaru JDM power folding/heated side mirrors
Subaru JDM mirror garnishes (J1017AG070)
Subaru JDM S402 side aero panels
Subaru JDM rain visors (E3617AG010)
Valenti full LED taillights (SB1101-C5W-R)
TapTurn w/Strobepack module
Debadged rear hatch
Prova Yellow wide view side mirrors (90130IT0010)
Diode Dynamics LED fog lights (6000K)
Diode Dynamics LED reverse lights
Diode Dynamics LED switchback turn signals (amber/6000K)
K2 Twin Tube LED mirror turn signals
Primitive skid plate
Engine Bay/Dressup
Prova Carbon Intake Duct (50130TR0000)
Prova Air Intake Guide (81130FD0190)
SuperStik oil dipstick
Syms Brake Master Cylinder Cover
Grimmspeed ceramic-coated turbo heatshield (092002)
Subaru JDM accessory engine bay covers (46112AG000)
Prova oil cap (94000MS0110)
Subtle Solutions alternator cover
GroupN Motor Mounts
Exhaust
Maddad Catted Downpipe
Nameless Performance mid-pipe
JDM Prodrive wagon-specific mufflers
http://i672.photobucket.com/albums/vv87/JoshEAllen/P1110193.jpg
Wheel/Brake/Suspension:
http://i672.photobucket.com/albums/vv87/JoshEAllen/46B68B73-49E3-4502-A206-14C7FD8A8D03.jpg
Front Suspension:
http://i672.photobucket.com/albums/vv87/JoshEAllen/85D36BD4-598F-42C0-BA76-A20C48D47E4A.jpg
Rear Suspension:
http://i672.photobucket.com/albums/vv87/JoshEAllen/49447B13-FC6E-466B-9413-4FDBC84D8C83.jpg
http://i672.photobucket.com/albums/vv87/JoshEAllen/P1110364.jpg
STi S402 Flexible Rear Arm Bar (and all black trunk floor)
http://i672.photobucket.com/albums/vv87/JoshEAllen/imagejpg2.jpg
Engine Bay:
http://i672.photobucket.com/albums/vv87/JoshEAllen/180EB96D-5D04-4F0F-BBAA-2C4F2D02FA20.jpg
JDM Valenti Tails and Rear Garnish
http://i672.photobucket.com/albums/vv87/JoshEAllen/25E3C01D-840A-4FC2-80F3-8591ABF85789.jpg
Prova Mirrors and K2 Twin Tube LEDs
http://i672.photobucket.com/albums/vv87/JoshEAllen/E1AFDFC5-5A8E-4C6F-803A-A45364BAE2DA.jpg
http://i672.photobucket.com/albums/vv87/JoshEAllen/AAD166B1-5D78-4AD7-A91D-B041FD7A2678.jpg
Interior:
http://i672.photobucket.com/albums/vv87/JoshEAllen/IMG_6011.jpg
This is just my first attempt at getting this started and there will be many edits to this original post and updates and more pics along the way.
Edited by WRX USA
Nice! How does the grimmspeed cooler fit with the LGT hood scoop ducting?
It fits but there is a gap at the front edge, because of the drivetrain being lower within the body than an LGT.
This is the best place for info on GS TMIC (http://legacygt.com/forums/showthread.php/grimmspeed-08-wrx-lgt-top-mount-intercooler-interesti-212367.html). Especially the last few pages, after people have received them.
Edited by WRX USA
Very nice. A few questions, if you don't mind.
Are you still running 225/55/17 tires?
Also, are you considering blacking out your headlights or going black around the grill instead of the white surround?
Did you do all the dynamat at once? I'm wondering if you felt the doors or the spare tire well made more of a difference? I was considering doing the four footwells and the spare tire well and thought I'd ask you how much of a difference you thought the doors would make.
Thanks!
Quote
Yes, I am still running the 225/55/17 Michelin Primacy MXV4 tires that the car came with but these will be replaced with higher performance tires soon.
Quote
I'm not sure how obvious it was from my previous pics but I have wrapped the surround of the grille in matching vinyl, the "wings" in the middle are gloss black, and the Subaru badge is satin white on gloss black. I have no plans to change the grille but I do have another set of headlights that I plan on doing an HID retrofit on and clearing the corners. I am not decided on how much (if at all) I want to black them out.
Quote
Yes, I did do all of it at the same time. The doors makes the door speakers sound much better and it seems like there is less road noise. I am not 100% convinced that Dynamat that I did in the trunk did anything.
Edited by WRX USA
Thanks for the response. I did notice the changes you already did and was referring to the surround that you vinyled white.
Just in case you haven't seen, Heffernan has a similar grill, but with the surround in black.
http://legacygt.com/forums/showpost.php?p=5140992&postcount=1052
I'm jealous of your suspension and brembos.
I'm not sure if I have seen Heffernan's grille before and that is what my original plan was. I like the white on the surround but I might change things up when I retrofit the headlights. I really wish Subaru didn't give the US a completely different grille than Japan, for the facelift, because that would make my life much easier.
i think this is the first time me seeing your car! NICEE. One day Ill see ya in person.
Do the control arms make much diff for everyday driving? So nice looking and theres so much that can be done to spruce up the OB suspension! Its really the only thing i dont like about the car.
Edited by kaitanium
It's hard to quantify how much of an improvement the aluminum arms made because I replaced all of the bushings at the same time, but even if they don't they sure do look good!
Ridiculous mod list - beautiful car! Do you use the ride height, or are there plans to go low?
I use the ride height on road trips and camping, and that is why I opted for the JDM Outback Bilstein's so I could have the heigth and the best possible ride.
  • 6 months later...
It has been a while since I have updated this thread.
I am now almost at 107K miles.
I did the 105K service and installed the Gates Racing Timing Belt, Tomei Timing Belt Guide and Killer B Water Pump Housing at the same time.
Since then I have installed the Perrin Steering Dampener Lockdown (http://perrinperformance.com/i-22342620-steering-dampener-lockdown.html) and Group-N transmission mount.
http://i672.photobucket.com/albums/vv87/JoshEAllen/9FCAE791-FCC6-41C2-909F-62AEF9C84697.jpg
Edited by WRX USA
  • 2 months later...
  • 2 months later...
I have been amassing parts for some time now. I am planning both a power upgrade and an aesthetic change. I'll provide more details this week when I get a large shipment but I am pretty sure no one has done this in the US.
In the mean time, I got these mirror finishers/garnishes yesterday (J1017AG070)
http://i672.photobucket.com/albums/vv87/JoshEAllen/C6FBB97D-0AA8-4494-A7D0-6F243FCB418F.jpg
Edited by WRX USA
Any noticeable improvement with the Perrin lockdown installed? I was looking to do the same mod but wasn't sure if it was worth the price.
How much did you pay, if you don't mind? I have a garnet red pair that I don't intend to use.
