Moderators BarManBean Posted August 22, 2016 Author Moderators Share Posted August 22, 2016 Well. I replaced the plugs because they were cruddy. I also replaced the ignition coil, on the hunch that maybe a circuit was going bad as the car heats up. No dice, still stalls out while idling in the driveway. I've found a couple instances of people replacing the MAF to fix a similar issue. Anyone have a decent line on finding a used / replacement MAF? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
rhino6303 Posted August 22, 2016 Share Posted August 22, 2016 Well. I replaced the plugs because they were cruddy. I also replaced the ignition coil, on the hunch that maybe a circuit was going bad as the car heats up. No dice, still stalls out while idling in the driveway. I've found a couple instances of people replacing the MAF to fix a similar issue. Anyone have a decent line on finding a used / replacement MAF? Vacuum leak, coolant temp sensor, idle air control valve or maf. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 24, 2016 Author Moderators Share Posted August 24, 2016 Well, I think it's fixed. I ordered up a new MAF sensor and installed it and it just ran for 30min with a drive around the neighborhood. Before it was reliably stalling in the driveway after 10-15min. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 17, 2017 Author Moderators Share Posted July 17, 2017 I sold this car this weekend. Is was great, but in rapid succession I bought a fairly new truck that is deemed extremely reliable and the '97 sounds like the exhaust manifold finally gave up the ghost and cracked. I paid $700 for the car, $150 for 2 sets of wheels with all seasons / winter tires, $75 for an axle, $100 in miscellaneous parts, and probably $150 or so for the timing kit. Sold the car for $800, disclosing everything I knew was possibly wrong with it. So all in, I drove the car for about a year and a half for about $400 plus the cost of gas and some fluids. It never left me stranded and I sold it with a clean conscious. I may well keep an eye out for some cleaner 2.2s down the road, it was an enjoyable car to drive. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
