scoobydoobie Posted November 29, 2009 Share Posted November 29, 2009 ^ you got under your car with it on blocks of wood like that? sketchy Link to comment Share on other sites More sharing options...
Merc6 Posted November 29, 2009 Share Posted November 29, 2009 I paid $48 for ramps from walmart. thats nothing I seen a skittle do that but the blocks were on a curb. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
fatboyfsx Posted May 3, 2010 Share Posted May 3, 2010 Thanks to Onthewagon, who was kind enough to provide me a copy of the instructions from the first post in this thread, I'm hosting the file for others who'd like a copy: http://www.xmission.com/~gold/2005_Legacy_GT_Oil.pdf Enjoy. Thanks to both you guys! The link in the first post is still bad Link to comment Share on other sites More sharing options...
cagerhager Posted June 16, 2010 Share Posted June 16, 2010 Thank you so much for keeping this thread going. This will come in very handy! Link to comment Share on other sites More sharing options...
Merc6 Posted June 16, 2010 Share Posted June 16, 2010 The valve even w/o the nipple was great. Small stream into the pan vs "I had one too many shots of everclear" *blarf* all over the tire, driveway, and ramp. In theory that mod you only need to walk up to the car with oil, filter, funnel and something to catch the old oil with. The under $10 filter socket is optional if the filter isn't over tq. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
dgrix Posted June 25, 2010 Share Posted June 25, 2010 Did mine tonight so here they are! Click Here! Let me know what you think! why is it when I click on links it comes up with this I7.com thing? Link to comment Share on other sites More sharing options...
SlickSpur Posted June 25, 2010 Share Posted June 25, 2010 why is it when I click on links it comes up with this I7.com thing? Its not hosted any longer. gold is nice enough to host the file for everyone here: http://www.xmission.com/~gold/2005_Legacy_GT_Oil.pdf Link to comment Share on other sites More sharing options...
sikopath Posted June 26, 2010 Share Posted June 26, 2010 There is a link also @ www.pimpmyauto.com/Legacys/Docs/2005_Legacy_GT_Oil.pdf I hope they have permission! Link to comment Share on other sites More sharing options...
jjwink Posted June 27, 2010 Share Posted June 27, 2010 Ramps are faster than a jack but have obvious limitations. If you get a cap wrench, don't get the shitty plastic ones at O'Riley they stretch and slip. I'm looking forward to a Subaru, my honda filter sits 90 degrees (sideways) and rains oil down on a crossmember giving you right arm and the ground an oil shower. Link to comment Share on other sites More sharing options...
Biggu Posted August 3, 2010 Share Posted August 3, 2010 I always take a screw driver and use it to poke a hole or 2 in the top of the oil filter to allow the oil to drain out, then once its drained use the same screw driver to poke a hole in the side of the filter and use the screw driver to turn the filter out. works like a charm. Link to comment Share on other sites More sharing options...
Merc6 Posted August 4, 2010 Share Posted August 4, 2010 I always take a screw driver and use it to poke a hole or 2 in the top of the oil filter to allow the oil to drain out, then once its drained use the same screw driver to poke a hole in the side of the filter and use the screw driver to turn the filter out. works like a charm. I read somewhere you could use a solo cup and thats what I been doing. I tried and failed the screwdriver attempts. I miss the drain plug on my mazda 6 cartridge filter setup. Took a Allen key and an additional washer to replace tho. Ramps are faster than a jack but have obvious limitations. If you get a cap wrench, don't get the shitty plastic ones at O'Riley they stretch and slip. I'm looking forward to a Subaru, my honda filter sits 90 degrees (sideways) and rains oil down on a crossmember giving you right arm and the ground an oil shower. Yeah did a few changes on them and that was not a fun. I refused to do one w/o using a lift so I could run away before the no longer golden shower. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Brock Samson Posted August 9, 2010 Share Posted August 9, 2010 Solo cup method worked perfectly for me. Also installed a Fumoto, looking forward to a spotless oil change next time around. The doors to the oil filter and drain plug are missing from the plastic fascia underneath the engine =( Link to comment Share on other sites More sharing options...
TSiWRX Posted August 9, 2010 Share Posted August 9, 2010 Also installed a Fumoto, looking forward to a spotless oil change next time around. Be sure to have a large enough catch-pan (diameter wise) for the Fumoto. The first time you use it, you may not realize how much and where it dumps! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
IanB Posted August 9, 2010 Share Posted August 9, 2010 Be sure to have a large enough catch-pan (diameter wise) for the Fumoto. The first time you use it, you may not realize how much and where it dumps! That's where the one with the nipple on it is handy, just slip some hose over the end and drop the other end of the hose straight into an empty oil jug, no drain pan required! Link to comment Share on other sites More sharing options...
TSiWRX Posted August 9, 2010 Share Posted August 9, 2010 ^ You said "nipple!" <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Merc6 Posted August 14, 2010 Share Posted August 14, 2010 I has inverted nipple one. It pees 7 inches from the ramp and tire into the bucket. 90% less splatter and not so golden showers. Before, the second that drain plug came off I had 1.4 seconds to abandon ship. Brake cleaner usually gets the small drops that ricocheted out. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
TSiWRX Posted August 15, 2010 Share Posted August 15, 2010 I has inverted nipple one. It pees 7 inches from the ramp and tire into the bucket. 90% less splatter and not so golden showers. Before, the second that drain plug came off I had 1.4 seconds to abandon ship. Brake cleaner usually gets the small drops that ricocheted out. ^ I'm not quite sure what you're talking about, but it's gettin' me hot and bothered. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
VTownGT Posted March 20, 2011 Share Posted March 20, 2011 I've been wanting a fumoto valve for the Legacy and the Outback, but I was worried about the length of the standard nipple version. My google search took me to a sight called qwikvalve.com that had a version with a short nipple. (The short version was not listed on the fumoto website) I called them and bought two over the phone which got me free shipping. They arrived in three days. The valves come with a small white plastic barbed hose fitting and about 12 inches of clear plastic hose. I just installed it, so I can not advise if the connection between the removable barbed hose fitting and the valve is leak free connection. But, the shorter nipple does give some peace of mind so I am not worried about it. I had no clearance issues on the 08 Outback. I hope the 05 LGT is as easy. Link to comment Share on other sites More sharing options...
Merc6 Posted March 21, 2011 Share Posted March 21, 2011 It still tucked behind the plastic skid plate. It doesn't protrude that much more than the drain plug before. Also for the where it dumps you can open the valve slowly to control the amount that comes out. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
zarooo Posted March 21, 2011 Share Posted March 21, 2011 was about to do an oil change today, glanced at this thread, and was reminded about the fumoto. thank god. just ordered, and i'm just going to wait a few more days to do the change. Link to comment Share on other sites More sharing options...
Brock Samson Posted March 22, 2011 Share Posted March 22, 2011 I have not had a chance to change my oil since installing my Fumoto, and am very excited. Does anyone happen to know the I.D. of the plastic tubing you need to stick on to the nipple? I know what I have lying around is not big enough. Link to comment Share on other sites More sharing options...
flyer27 Posted January 8, 2012 Share Posted January 8, 2012 the solo cup tip is awesome. used it today and greatly reduced my spillage. Link to comment Share on other sites More sharing options...
famaya26 Posted May 18, 2012 Share Posted May 18, 2012 Hey guys im doing my oil change tomorrow and was wondering if I should use 10w-30 since I live live in Texas and our average temp during the summer is 90+? Link to comment Share on other sites More sharing options...
pillboy Posted May 18, 2012 Share Posted May 18, 2012 What does the manufacturer recommend for those ambient temps? The answer might be in the owner's manual. It is still ugly. Link to comment Share on other sites More sharing options...
forestir Posted May 18, 2012 Share Posted May 18, 2012 Synthetic 10w30. Link to comment Share on other sites More sharing options...
