Inigo Montoya Posted April 24, 2007 Share Posted April 24, 2007 This past weekend I changed out Both the Tranny Fluid and the Rear Diff Fluid on My 06 5MT, just a couple of things to note about the change. 1. You do need the T70 Torx bit for the front, but just use a 1/2' ratchet for the rear, I used a couple of extensions for the top bolt since the exhaust gets in the way. 2. Filling the tranny, this took me a bit to find, I removed the engine cover, and the dipstick is on the turbo side, I removed this then used a funnel with a short length of tubing to refill the tranny. Glad I had this around, because you could not get a bottle down there and pour, too cramped and the turbo blocks your sight. 3. For the rear end, get one of the little pumps they sell at any auto parts store, I used Redline, so it doesn't fit into the bottle, but there is no good way to pour fluid into the rear end, either have one of these or get a longer piece of tubing for your funnel. Summary: Tools I used- T70 Torx 1/2" ratchet 2 extensions for said ratchet equaling about 10" long Funnel with about 2 ft of tubing for fill purposes Pump from auto store for filling rear end Phillips head screwdriver for removing engine cover Ramps and jackstands so my fat a$$ could get under the car Link to comment Share on other sites More sharing options...
bluesuby Posted April 24, 2007 Share Posted April 24, 2007 I use Mobil 1 in the raer diff because the bottle is shaped for easy filling...and Mobil 1 isn't so bad a fluid either. Link to comment Share on other sites More sharing options...
rallispec Posted April 25, 2007 Share Posted April 25, 2007 i used a funnel with a long ass tube for the rear end. btw - how many metal filings were on your drain plug magnet?... Mine had a little more stuck to it than I was expecting. I switched over to redline - and so far I haven't noticed a huge difference. It did help out in the wifes Mazda6 though. Link to comment Share on other sites More sharing options...
deneb Posted April 26, 2007 Share Posted April 26, 2007 I noticed a few filings on my drain plug when I changed out my fluids at 60k. Dunno if it's anything to worry about though. I was using 75W90 Valvoline dino in the tranny and rear diff, I put in 80W90 Valvoline durablend this time, since it was on sale. When warm, shifting seems slightly smoother with a little less gear whine; but when cold, it's tougher to get the tranny into first gear. Luckily it rarely gets below 30F where I live. Link to comment Share on other sites More sharing options...
Inigo Montoya Posted April 26, 2007 Author Share Posted April 26, 2007 I used redline for both of the fluids, gear oil for the rear (very different color, and 75W90NS for the front. I did have some metal on the magnets, but nothing I was overly concerned with, most were like fine grit. Hard to tell if it improved my shifting since I just did a short shifter last wed, that made the biggest difference. Link to comment Share on other sites More sharing options...
ilh Posted May 5, 2007 Share Posted May 5, 2007 I just did this myself today as part of my 30K. I used Red Line 75W90NS in the 5MT and 75W90 in the rear diff. What in the world did those gorillas use to tighten those rear diff plugs?!? Unbelievable how hard those were on (significantly more than lug nuts), which is pretty silly given they are not load bearing in any way. Given what many others were finding on their plug magnets, I was rather surprised to find only very fine metallic sludge, no significant chunks of any kind. This is my first gear oil change at 30,003 miles. On my test drive afterwards, I was glad my shifting is no worse than stock and probably a touch better. Actually, my car has always shifted very smoothly for me, and I do rev match 95% of my shifts, but I was a little worried about non-stock gear oil even though I've used Red Line in the past in other cars. I believe my 2nd gear whine was significantly reduced with the Red Line vs. stock. This gear oil should do quite a bit better in the New England winter compared to the stock non-synth. I also replaced my air filter and flushed my brake fluid (from ATE SuperBlue to Typ 200 which is yellow but otherwise the same--you can see when you start bleeding the new fluid) to complete my 30K. I had the dealer flush the coolant with a $40 coupon from my local dealer a couple days ago. (I'm in the middle of an oil change interval, so that will come later.) --Lee Link to comment Share on other sites More sharing options...
rallispec Posted May 6, 2007 Share Posted May 6, 2007 the rear diff plug was EXTREMELY hard to get off on my car as well -- I actually had to use the hydrolic jack in combination with the breaker bar to free the rear plug.--- I think they used some type of locktite or liquid sealant on it. Link to comment Share on other sites More sharing options...
lhsa Posted May 7, 2007 Share Posted May 7, 2007 you didn't use the liquid gasket sealant on the bolt? Link to comment Share on other sites More sharing options...
rallispec Posted May 8, 2007 Share Posted May 8, 2007 you didn't use the liquid gasket sealant on the bolt? nope - didnt have any on me when i did the swap. The bolt was still so gunked up with the crap they put on it from the factory though, I dont think I'll have any problems. Link to comment Share on other sites More sharing options...
Legacy05 Posted May 8, 2007 Share Posted May 8, 2007 You know, I used 75W90NS for both the front and rear. Link to comment Share on other sites More sharing options...
rallispec Posted May 8, 2007 Share Posted May 8, 2007 You know, I used 75W90NS for both the front and rear. I think that should be fine. Link to comment Share on other sites More sharing options...
Legacy05 Posted May 8, 2007 Share Posted May 8, 2007 Well ... I would say it has been, car has been driving great heh. Link to comment Share on other sites More sharing options...
rallispec Posted May 10, 2007 Share Posted May 10, 2007 4 in the front, 1 for the rear. Link to comment Share on other sites More sharing options...
kp1095 Posted May 12, 2007 Share Posted May 12, 2007 Just took my 05 in for a dash rattle TSB and had them change the front/rear and MT fluid and they only charged me $131.00 to do everything, not a bad price for the mess and not having a lift at home. Gold Rush Subaru in Auburn,CA Great service/prices K Link to comment Share on other sites More sharing options...
RAPTR Posted May 31, 2007 Share Posted May 31, 2007 Now the front diff is the exsactly the same fluid as the transmission on a MY05 AT, correct? Link to comment Share on other sites More sharing options...
TRS Posted May 31, 2007 Share Posted May 31, 2007 Now the front diff is the exsactly the same fluid as the transmission on a MY05 AT, correct?On an '05 5eat, both the f & r diffs use GL-5 75W90, and the AT uses IDEMITSU ATF HP. Link to comment Share on other sites More sharing options...
deneb Posted May 31, 2007 Share Posted May 31, 2007 TRS is correct. DO NOT put AT fluid in your front diff. On a manual transmission Legacy, the tranny/front diff both use GL-5 75/90 oil (as well as the rear diff). Auto LGT needs the GL-5 oil in front/rear diff only. Link to comment Share on other sites More sharing options...
Guest Posted May 31, 2007 Share Posted May 31, 2007 Now the front diff is the exsactly the same fluid as the transmission on a MY05 AT, correct? Link to comment Share on other sites More sharing options...
jazzymt Posted May 31, 2007 Share Posted May 31, 2007 FWIW - there were no "chunks" when I changed my diff oils (@30k miles), but the rear plug had quite a bit of fine metal sludge on it - probably 3/8 to 1/2" thick across the whole plug. The oil was also fairly black - I think it was low from the factory. Front diff oil looked more or less ok & only about 1/4 as much metal filings on the drain plug as the rear. I know the manual diff plugs are in a different location than the automatic, but I managed to fill my rear diff by just squeezing the bottle with the tip in the fill hole from below. Once I got down to about 1/3 the bottle, I refilled with another & squeezed the rest in until full. [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
TRS Posted May 31, 2007 Share Posted May 31, 2007 FWIW - there were no "chunks" when I changed my diff oils (@30k miles), but the rear plug had quite a bit of fine metal sludge on it - probably 3/8 to 1/2" thick across the whole plug. The oil was also fairly black - I think it was low from the factory. Front diff oil looked more or less ok & only about 1/4 as much metal filings on the drain plug as the rear.When I changed my diff fluids a couple weeks ago (27k miles) they were pretty much in the the same condition. Rear diff fluid was black with a surprisingly large blob attached to the drain plug magnet, while the front fluid still looked pretty good and there was a much smaller layer of sludge on the magnet. I replaced with Red Line 75W90. I did a drain and fill on the AT too, and that fluid looked pretty fresh. I refilled with Subaru IDEMITSU ATF, along with a can of BG ATC+. Link to comment Share on other sites More sharing options...
bosco Posted May 31, 2007 Share Posted May 31, 2007 no one is using the Subaru Extra-S 75w90 that unclemat recommends? bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
jazzymt Posted June 1, 2007 Share Posted June 1, 2007 no one is using the Subaru Extra-S 75w90 that unclemat recommends? boscoNo...wut dat? I just put in Valvoline full synthetic 75W-90. It better kick some butt too @ like $10.50 a bottle. [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
bosco Posted June 1, 2007 Share Posted June 1, 2007 No...wut dat? I just put in Valvoline full synthetic 75W-90. It better kick some butt too @ like $10.50 a bottle. sorry. bosco http://www.legacygt.com/forums/showthread.php?t=62614&highlight=Extra-S+75w90 Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
2006Specb122 Posted June 9, 2007 Share Posted June 9, 2007 Just took my 05 in for a dash rattle TSB and had them change the front/rear and MT fluid and they only charged me $131.00 to do everything, not a bad price for the mess and not having a lift at home. Gold Rush Subaru in Auburn,CA Great service/prices K Great! Thanks for the advice!!! I'll definately check them out this week! I just got home from another dealership in the same area and was a little surprised at the high prices. I asked for a quote on various items that I listed in the 30k service thread today. But the Font and Rear Differential fluid change was quoted to me at $300. If I can get it done for HALF the price in Auburn then I'll be going there for sure! Just don't know those people but hey for that kind of savings I'll get to know them. Thanks! I love legacygt.com OH... what fluid did they use up there in Auburn? The dealer I went to today said they use MOC full synthetic but I've never heard of it and I'd like to researh it before putting it in my car. Thanks Link to comment Share on other sites More sharing options...
jazzymt Posted June 10, 2007 Share Posted June 10, 2007 Um...are you guys talking about MT vehicles? I assume you must be since 2006Specb122 has got to be a MT. Would you pay $131 for an oil change? $300 is beyond insane. Changing the diff oil & transmission oil on a MT is as easy as an oil change (it is an oil change) and it uses about the same amount of oil, which costs about the same as engine oil & there's no filters to change. IMO - you're getting taken if you pay more than $50 for the whole 9 yards (ok, $80 if you're talking synthetic). Us AT folk are in a bit of a different position since it would take like 12 quarts of spendy ATF to "flush" the system, plus 3 qts of gear oil for 2 differentials, but all you have to do is drain & refill two gear boxes (tranny & rear diff) and you're done...? [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
