vlad_b Posted November 7, 2011 Share Posted November 7, 2011 Changed my fluids with SuperTech 75w90 from Wallmart. Oil cost - $35. Took me about an hour with no lift and few beers inbetween. Wonder what my stealership wanted $250 for... Link to comment Share on other sites More sharing options...
Blow Posted December 12, 2011 Share Posted December 12, 2011 Looks like a good weekend evening project for me this weekend Link to comment Share on other sites More sharing options...
Subyroo651 Posted December 12, 2011 Share Posted December 12, 2011 Looks like a good weekend evening project for me this weekend I would definitely pick up one of these, I did the job without it and it was the worst experience I have ever had working on a car!! Nasty gear oil all over me and the work area. I m talking about just using this to refill the Diff since the area doesn't allow you to use the bottle. Fluid Suction/Pump Gun Link to comment Share on other sites More sharing options...
chaz517 Posted October 13, 2012 Share Posted October 13, 2012 Changed my tranny fluid w lucas 75w90 any reason that was a bad idea? Lot of ppl use redline i know. This was $12.95 a quart thanks Link to comment Share on other sites More sharing options...
GTPpilot Posted October 13, 2012 Share Posted October 13, 2012 I would definitely pick up one of these, I did the job without it and it was the worst experience I have ever had working on a car!! Nasty gear oil all over me and the work area. I m talking about just using this to refill the Diff since the area doesn't allow you to use the bottle. Fluid Suction/Pump Gun For the rear diff ? Just take the spare tire out, remove the rubber bung from bottom of well, and run tubing down to the fill port, put on a funnel on the tubing and filler 'er up. Easy as pie. Link to comment Share on other sites More sharing options...
Dbl_D718 Posted October 14, 2012 Share Posted October 14, 2012 ^ Good thinking there. I used a pump myself and I would say it was probably easier/quicker than taking the spare out and doing it your way. But if you don't have a pump and you've got someone to watch under the car to tell you when it's full, your way is pretty smart. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
GTPpilot Posted October 14, 2012 Share Posted October 14, 2012 I can't take credit for it though. It was mentioned earlier in the thread. :-) I just prefer it due to ease and the ability to make sure the diff is full. Hey you check the air in the spare once in awhile anyway. Link to comment Share on other sites More sharing options...
vlad_b Posted October 15, 2012 Share Posted October 15, 2012 ^ Good thinking there. I used a pump myself and I would say it was probably easier/quicker than taking the spare out and doing it your way. But if you don't have a pump and you've got someone to watch under the car to tell you when it's full, your way is pretty smart. Using pump is messy business. I'd say filling through the hole in a trunk is easier and faster. I don't keep spare or tools in a trunk, but how long does it take to take it out... 30 seconds? Link to comment Share on other sites More sharing options...
branab3 Posted January 4, 2013 Share Posted January 4, 2013 I used redline for both of the fluids, gear oil for the rear (very different color, and 75W90NS for the front. I did have some metal on the magnets, but nothing I was overly concerned with, most were like fine grit. Hard to tell if it improved my shifting since I just did a short shifter last wed, that made the biggest difference. Which short throw kit did you get? I was looking at them and wasn't sure which was a geometric short throw or just a shorter lever Link to comment Share on other sites More sharing options...
Gasaraki Posted May 22, 2014 Share Posted May 22, 2014 OK so I can use the Amsoil 75W-140 Gear Oil in my tranny? How come they have separate auto tranny fluid then? Is the Sever Gear 75W-140 too much for my 08 5EAT or should I use the 75W-110? I'm going to start doing some autocross stock class so I want to change out all my fluids. Link to comment Share on other sites More sharing options...
shiby Posted May 25, 2014 Share Posted May 25, 2014 OK so I can use the Amsoil 75W-140 Gear Oil in my tranny? How come they have separate auto tranny fluid then? Is the Sever Gear 75W-140 too much for my 08 5EAT or should I use the 75W-110? I'm going to start doing some autocross stock class so I want to change out all my fluids. Iim not an expert but from what I've been reading and understand, do not put the Amsoil 75W-140 in your tranny if you have a 5EAT Autos do have separate tranny / diff fluid.. sounds like you knew that tho Regular ATF in tranny Amsoil or whatever you want in front diff dont know if what you have is good/bad.. im going with subaru extra-s myself with my front diff when i do fluid change on my 5EAT Link to comment Share on other sites More sharing options...
Max Capacity Posted May 27, 2014 Share Posted May 27, 2014 OK so I can use the Amsoil 75W-140 Gear Oil in my tranny? How come they have separate auto tranny fluid then? Is the Sever Gear 75W-140 too much for my 08 5EAT or should I use the 75W-110? I'm going to start doing some autocross stock class so I want to change out all my fluids. NO. the 5eat takes a different automatic tranny fluid, they have a fluid for that. http://www.amsoil.com/mygarage/VehicleLookupPage.aspx?FromIndex=1&url2=2005+SUBARU+LEGACY+E The sever-gear 75w-90 only goes in the front and read diff's. I have used the that but now use Extra-S in both my cars. I do use there European 5w-40 Full SAPS in both engines and there filter doing oil changes at 7000-8000 miles. I have had Blackstone Lab do oil analysis on both cars. I do 85% of my driving at highway speeds. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTW-97 Posted October 25, 2015 Share Posted October 25, 2015 Here's a vote for Red Line 75W90ns. Our '97 GT wagon is approaching 170K miles and has had a third-gear gronk for years. I'd asked at the dealer and other shops about changing to different gear lube and everyone had the same answer: It's a tranny problem and Sube's juice was the way to go. So I finally swapped in the Red Line a week ago and the shifting issue has simply disappeared! Goes in and out of every gear easily and smoothly, although you can still get a little complaint from third if you push it. Even my wife notices how much better it shifts. I'd long ago figured it was synchros that weren't up to the task but am now pleased and surprised it's not. Good stuff! Link to comment Share on other sites More sharing options...
